Question about Saeco Vienna De Luxe Espresso Machine
Will not power on
Made one cup this morning and no power when I went to make second cup. Plugged in with power to outlet and service door is closed. Did it short out? Any suggestions?
  • 25 Answers
Has thus happened before? If it hasn't, then maybe you've used it like that everyday making two cups and maybe if it needs batteries or other things like that, you could replace it. But, if it doesn't work, you could always buy a new one.
Posted on Nov 28, 2013
I have GE GLDT696TSS. The dishes are not clean and one time noticed water leak from the back of the washer.
You should check the water outlet - probably discharges into your sink through a garbage disposal - the water outlet is likely plugged and water can not discharge down the sink. You can remove the hose and clean it out.
Apr 06, 2014 | GE GLDT696TSS Builtin Dishwasher
Gh9115xe went off completely sometime after a cup of coffee was reheated. Now, nothing works. The outlet is live.
probably not
there is a glass fuse under the outer case near the circuit board
if that is blown it is from a short so you may have to take it in for a diagnosis
Apr 28, 2017 | Whirlpool GH9115XEB / Q 850 Watts...
I have a DeLonghi Caffe Elite DC78TCG which has stopped working. I push the button and nothing happens, it appears the thermostat is working what else could it be? The unit is getting power.
Had the same problem with mine. I think it was due to mineral build up. I put about 1/4 cup of white vinegar and 2 cups of water into the water chamber and let it sit for about 20 min. I placed a measuring cup where the carafe goes then I repeatedly plugged and unplugged into an outlet. When first plugged in I could hear the internal relay click on then click off a second later, as soon as I heard the second click I unplugged then replugged the power cord. Repeating this started to heat the water vinegar mixture, still no power light at this time. After doing this until the two cups flushed through and then I was able to use the power button to turn on. Ran another couple of water pots through and now I have my coffee maker working again.
May 16, 2011 | DeLonghi Caffe Elite DC78TC Coffee Maker
My monitor doesn't go on anymore. Las night I had a pop-up appearing on the screen. I closed my computer and started over again. I'm sure I didn't turn off my monitor. Everything went well until this...
First, check to make sure the power cable is plugged properly in the back of the monitor and into the surge protector. You can try a different power outlet, but if you're still having the same problem and the light isn't turning on, it's likely you've either blown the fuse inside the monitor, or you had a power surge and blown something inside the monitor. This happens when you don't use a surge protector and just plug the monitor into the wall.
That said, if the above doesn't work then you have a hardware problem with your monitor and it needs to be serviced.
Jan 11, 2011 | Computers & Internet
I was photocopying with it this morning. After running out some copies, the led blink and power went off till now it refuse to come on.
Unplug the machines from the outlet. Also make sure it's not plugged into a surge protector.
- Plug the machine into a different outlet.
- If still no power, plug the power cord into a completely different outlet (move the machine to another location if you have to).
If still no power most likely the power supply will need to be replaced.
Oct 21, 2010 | HP LaserJet 3050 All-In-One Printer
Won't power on.
SAME exact thing happened to me just this morning! No power whatsoever, like it wasn't even plugged in. I was so happy I registered it online when I got it. I called them today, told them what was happening. They made me move it to another outlet while on the phone, then plug a can-opener or something into same outlet, when that worked, put me on hold for about 30 seconds, and told me since I am within my year warranty, they are sending a new one! All I need to do is send the K-cup holder to them (but new machine already on the way). Give them a call! Get it replaced! Hope this helps
May 26, 2010 | Keurig B50 Coffee Maker
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
Sharp Microwave Model R-1830: No power
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open oven thermal cutout (TCO) on the top of the oven cavity / body or an open thermal fuse on or above the magnetron.
These should read closed (virtually zero) on a continuity check.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it went dead or when you plugged it in or opened or closed the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site but the best place to order Sharp parts is Tritronics.
Oct 12, 2008 | Microwave Ovens
Saeco Vienna De Luxe Espresso Machine Logo
26 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
