To remove motor to renew brushes
Remove motor from bosh wff1201
  • Washing Mach... Master
  • 2,113 Answers
Most washing machine motors have no brushes. They are induction motors. And they are made so cheaply that they are welded together hence they cannot have the bearings or many other parts worked on. They may have a centrifugal switch that can be rebuilt or replaced.
Posted on Nov 28, 2013
4 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: wff1201 washing machine
You have to take the back off and remove the motor
Posted on Feb 27, 2008
early1234
  • 871 Answers
SOURCE: Hotpoint Aquarius 1100 WD61P (analogue) washer dryer, sparking motor (and stopping)
you seem to know what your doing. yes you do have to remove the motor in order to remove those carbon brushes, while your at it, you can also adjust the screwing/bearings of the bolts to hinder the machine from moving a lot.
Posted on Mar 17, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosh WFX2867 Carbon brush replacement
The worn out brush could certainley cause the trip to operate.
The best way to remove motor is to lay washer on it's side, and undo the 2 screws that hold the motor in place, then lever back off the mounts.
Remove the rear cover first and drive belt.
Hope this is if some help to you .
Please rate my solution.
Thankyou.
Posted on Jan 23, 2010
Why is my bosh drill stoping and starting
needs brush cleaning when the brushes in the motor get a little dirty they tend to work intermittently
Jan 15, 2015 | Bosch Drills
BOSH EXXCEL 1200 EXCEL IS HAVING LOUD CRACKLING NOISE WHEN SARTING. THIS IS BEFORE THE DRUM STARTS TO TURN.
It the motor there are carbon brushes in there when they wear down they don't touch commutator... on motor what u here is arcking u shud b able to re place them u will need a model number and make, ..or remove motor and take with u to get right brushes if the moyor is badly burnt u will need to replace it if u continu to use like this it will only get worse
Oct 12, 2013 | Bosch Water Heaters
Thankyou.
Jan 23, 2010 | Bosch Washing Machines
Bosh classicxx drum wont spin . any ideas
Maybe. Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl vote me 'very helpful' for the free help, thnks!
Jan 09, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch WFE 2021
I suggest that you check the brushes in the motor for wear.
Remove rear panel, remove drive belt, undo bolts securing motor, unplug motor lead and earth wire.
Lever motor back, keeping hold of it, and remove.
Check the brushes, they are at the opp end to the motor pulley, if there is less than 8mm left, then replace brushes.
I would also check the pump filter, and clean if req'd.
Please rate my fixya solution.
Thanks.
Feb 08, 2009 | Bosch WFE 2021 Front Load All-in-One...
Malber P21 - works slower and slower
hi from uk from what you describe /symptoms this is sure to be the motor brushes are worne very low and req renewing this is not beyond the d i y novice and the 2 x brushes for the motor here in uk cost approx £5 and easy job to renew if you remove rear panel off machine then remove motor you will see how it looks and secures just like a car alternator and also belt adjustment is same the brushes will be self explanitary of how they are renewed once motor is removed ? hope this helps/inspires you and will save you $$$$s by diy
Dec 02, 2008 | Malber P21 Front Load Washer
Drum Does not Rotate
the carbon dust that you mention ? on the drivebelt will//may have come from the electric motor carbon brushes especially as you sy machine is 4 yrs old you can diy inspect the brushes by removing the rear panel to access motor unplug the socket from motor then slacken belt and remove belt from pully remove the motor you will see location f brushes x2 opposit each other and normally held in position ont armature of motor by coiled pressure clip like watch spring and brush has wire embedded in it and other end a push on terminal? when these brushes wear down normally the fist indication is fast spin slows then eventually no rotation of drum? over a period of time? SO easy diy to renew brushes if as above worne down /not contacting armature? cost approx £5 here in n/west uk worth investigating and diy saving ££££s $$$$s? and i hope you have good luck hope this helps/inspires you?
Oct 26, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
How can i remove the carbon brushes to check if they need renewed.I have a Hotpoint Aquarious model no WMA34. Much appreciated Chris
you will need to remove the motor, Isolate the supply by unplugging the machine, remove the rear panel, slacken the motor fixing bolts, remove the drum belt, now remove the motor bolts and drop out the motor, un-plug the motor connections.
The brushes are at the rear usually housed in plastic one on each side, disconnect the single wire and carefully remove the housing (2 torx screws), taking care not to break or loose the brush as it is spring loaded,a typical new brush will protrude 30-40mm from the housing a worn brush will be much shorter 8-15mm and just make contact with the motor commutator. replace if necessary, check the comm for wear, refit in the reverse order.
Apr 24, 2008 | Washing Machines
Wff1201 washing machine
Feb 27, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
