Question about Grilling
1996 Onan Propane 2500 Microlite Generator often will not start & dies when microwave is started?
Have installed new spark plug in the Onan & new propane regulator and new propane pigtail hoses, but the Onan turns over well but often refuses to start, and when it does start, the Sanyo Microwave often kills the Onan Propane Generator? Any troubleshooting advice?
    Top Expert:
  • Grilling Master
  • 43,969 Answers
Microwave ovens need to be connected to a separate, dedicated line.
Posted on Nov 28, 2013
4 Suggested Answers
  • 3 Answers
SOURCE: coleman instastart propane stove regulator wanted
Check to see if Coleman has an attachment to replace the regulator, so that you can use a five gallon cylinder with your stove and your own regulator.
Posted on Jun 29, 2008
gcken
  • 140 Answers
SOURCE: Kenmore Gas Grill 141.155401 issue with Propane tanks
Posted on Apr 14, 2009
heatman101
  • 43501 Answers
SOURCE: I have a new Weber Genesis E-310 Liquid Propane
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 06, 2010
Testimonial: "Thanks for the great hint. This solved my problem."
Gen starts then shuts down
Check rotor skip rings for cleanliness, rotor brushes. Stator resistance, rotor resistance. If ok then change control board
Apr 30, 2014 | Onan MicroLite 2500 & 2800 LP Gas...
My generator will turn over but wont start
Our motorhome Onan 5000 Marquis generator will turn over and try to start but fails everytime we test. We have primed, gas and oil are fine and we have new spark plugs. We also changed the gas filter on the generator. Any suggestion? Thanks, Loretta
Mar 30, 2014 | Watts Onan Portable Generator - 4000 ,...
Onan Propane Generator Problems
Is the generator coming up to proper speed? A cycles (hertz) (should be 60 in USA) meter will tell.
If it is up to speed, see if a UPS unit is made powerful enough to power the microwave. That will handle the initial starting load from the microwave.
UPS units are handy to power stuff while you are getting the gen going.
Nov 28, 2013 | Onan MicroLite Generator, 2500 Watts / LP...
2500 lp starts, then stalls
Unit is over fueling, did you change fuel pump for non OEM part? fuel carb needle maybe stuck with gum
Nov 05, 2013 | Onan MicroLite 2500 & 2800 LP Gas...
My Onan 2500 Microlite LP starts when cold, but soon quits until it gets cold again. I think that the fuel inlet valve needs and adjustment. How is this done?
I would not adjust it, I would say the unit has sat and carb is gummed up. Flush with sea foam and run for as long as you can under heavy load
Oct 08, 2013 | Onan MicroLite 2500 & 2800 LP Gas...
Is it safe to use a soft/hard start capacitor on my new Dometic Penguin 11,000 btu A/C ....Model # 640312.30X
No, the capacitor is not integral to the load of the generator, it is only used to start it when it turns on. It takes virtually no voltage from the system to recharge itself. The demand of the unit is not related to a start capacitor. Also it will not harm your unit to install one capacitor over another, they make them so if the connectors fit, they work. Just hook up the leads correctly so you don't discharge it on yourself.
Aug 27, 2012 | Dometic Rooftop RV Air Conditioner
I have a 1996 lance camper with a 2500 onan generater lp cant get the spark plug out can you help
Spray the plug base with a good penetrant and give it time to seep into the threads and work.
Failing that you can sometimes carefully heat the head around the plug with a small hand torch and get the head to expand enough to enable you to break the spark plug loose.
Apr 12, 2011 | Watts Onan Portable Generator - 4000 ,...
Grilling Logo
147 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
