Question about Motorola Mobility RAZR V3x Cellular Phone
Installing new battery
I want to install a battery for my new phone.It seems to have a paper cover but i tried to unwrap it before installing at it seems to be stuck firmly. It appears that perhaps i need to leave it on? seems weird? There's no obvious tear tab to remove cover.
  • 490 Answers
Sir their is no need to unwrap that cover coz its a paer sheiled of ur battery if u wil remove it ur battery may collapse with metal
Posted on Oct 18, 2007
SOURCE:
Can the battery case cover of an Olympus SP550 uz be easily obtained & easily replaced?
The cover on the camera is cracked or the battery case is cracked. If it is the battery that is cracked replace it immediately. If its the camera attachment that is cracked Gorilla Tape works wonders :)
DO NOT USE THE PHONE IF THE BATTERY CASE IS CRACKED!
Sep 13, 2014 | Olympus SP-550 UZ Digital Camera
How do I install the batteries
If your two-way radio batteries seem to be wrapped in a cellophane you may not need to unwrap them. Many rechargeable batteries are simply a group of cells held together by cellophane/plastic wrapping. If it appears the battery contacts are exposed and will touch the appropriate place in the radio, do not unwrap. If still questioning this, please post back with your radio model and possibly the battery part number. Someone knowledgeable will likely respond.
Best regards.
Dec 27, 2013 | Radio Communications
I have a VeriFone Omni Vx510 - I keep getting a paper out message when trying to process a transaction. There is paper in the machine.
If the printer does not work properly:
• Check battery status or terminal power connection. The printer will not print if
there is an insufficient charge remaining in the battery to complete the print
operation. (For Vx610 terminals only.)
• Check if the printer is out of paper and that the roll is properly installed. Open
the paper roll cover and install a new roll of printer paper or ensure that the roll
is feeding from the bottom.
• Verify that the printer roller and paper roll dust cover are properly installed.
• If the problem persists, contact 775-358-2922 hope this help : - )
Sep 13, 2011 | VeriFone (M19755014US1) Magnetic Card...
I have the cover open on my canon pixma mx410 cannot seem to figure out how to get the old balck ink cartridge out??
Is the power on? Close the cover (lower the scanning unit by raising it first then let it down gently) and make sure the all-in-one is plugged in. Then turn it on with the power button. Wait for the unit to stop its warm-up and self-test then reopen the cover. The cartridge carrier should move to the installation/replacement position.
Then pinch and lift up on the lid of the right side cartridge cover. (The cover is an angled piece with one side going down into the front of the cartridge carrier; you need to press in enough to get the tab to unlock from the carrier.) Now lift up the current black cartridge.
Unwrap the new cartridge and remove the orange tape. Carefully place the new cartridge into the slot without squeezing it or banging it against the sides of the cartridge slot. (The label should be up and towards the center of the printer.) Then push the locking cartridge cover down until it snaps into position. (Make sure that it is fully down.)
Then close the cover again.
I hope this helps.
(if the cartridge carrier doesn't move when the printer is on, try reaching over and sliding it when the printer is off. Look for foreign objects in the cartridge carrier path and remove anything (including small scraps of paper) that may block the travel. I recommend using a flashlight to check for foreign objects.)
Sep 01, 2011 | Canon Pixma MX410 All-In-One Printer
I've just bought a new kodak printer ESP3250 last week, and installed everything and got it set up fine. It was printing fine after I installed it but suddenly stopped after I had printed a few sheets. The...
Sounds like there is a sheet of paper jammed in it. Try taking off the roller access panel in the back (not the access panel by the cartridges). Make sure to only use clean sheets with proper humidity level to avoid jams. Also fan the sheets before feeding to disperse any static.
Mar 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
AT first when you turn it on all lights would come on and stay on. Now typewriter would not come on at all. Power cord seems OK. Installed new batteries.
It probably needs a new board or power supply. You might try removing the cover over the board and look for staples or paper clips.
DickyO
Sep 10, 2009 | Lexmark Wheelwriter 1500 Typewriter
Xerox 3001 Copier. I installed new toner and the
Paper must cover the center to hit the sensor. If paper still goes through without stopping, the paper drive clutch is faulty.
Aug 25, 2009 | Xerox 3001 Copier
Cant open battery cover
Hello!
Very simple solution. All you have to do it flip it over to the back cover is facing you, there is either a tiny button to push and then you can release the cover. Or you need to press firmly against the back and front and push up/pull down until the cover slips off!
Please rate FixYa!
Jan 12, 2009 | Cell Phones
How to install sharp photocopier AR5320E on vista
just bought a brand new AR-5320E, unwrapped the whole thing and the paper manual only tells me about how to install the printer drivers, and make photocopies, I've inserted the cartridge and poured the dark powder developer stuff into the chamber, but still it's not making any photocopies, and I can't find a single manual or instructions booklet anywhere to tell me what's wrong!! can you help? I've been reading about toner's etc, but it only came with the black powdery stuff
Oct 08, 2008 | Sharp Office Equipment & Supplies
Motorola Mobility RAZR V3x Cellular Phone Logo
52 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
