Cannot get my PROSCAN model PLT7810K to connect to WIFI thru my Netgear 600 router
SOURCE: Problem connecting Ipod touch to WiFi
What password are you entering on to the ipod touch?
Posted on Jan 05, 2009
PABLOCSA
  • 1124 Answers
SOURCE: Connecting Netgear Wireless Router to @Wire Wireless Router
You don't need to connect your netgear, you have only to connect your computer to the 2Wire (is wireless also) - If your computer ins not wireless Only you have to do is insert a wireless PCI card in your computer or and USB wireless device and connect to the 2Wire Wireless Router
Posted on Feb 11, 2009
redhaze89
  • 854 Answers
SOURCE: Netgear 824, security = intermittent WiFi connectivity
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jul 13, 2009
anandg27
  • 1272 Answers
SOURCE: iPhone keeps dropping wifi signal on Netgear DG834G router.
Hi, please perform the below steps to configure settings on the router:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router, usually with http://192.168.0.1 or http://www.routerlogin.com.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5. Click on WAN setup from left menu. Check the box for 'Disable Dos Protection'.
6. Set the MTU size to 1400. Click apply.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jan 08, 2010
SOURCE: I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Posted on Jan 18, 2010
HOW DO I CONNECT MY EXTENDER THROUGH WIFI
It need to be wire connected to another router, once it has an IP you can access the device with a web browser and configure wireless access pretty much with the same information as your actual wireless access point, same network ID and key.
Aug 13, 2014 | NETGEAR CONSUMER New - Netgear Wn2500rp...
I can connect to internet from cable modem but not thru Router Belkin Surf N300. I can get wifi thru router
I'm confused? If you connect a Ethernet cable direct fron the Belkin to the computer, will it connect? What does it say in Network and Sharing Center on computer, What is the computer and the OS? I think you have a Computer issue. Post Computer Make,Model, and the OS.
Dec 26, 2012 | Belkin Computers & Internet
I just got a Canon Pixma MG5370, Im running an XP cp to network thru Netgear N300 then thru DSL, the N300 dangles a Netgear 8 port wired Switch. I cant get the dam printer to connect correctly to print,...
Set a static IP on the Canon printer
e.g.
IP: 192.168.x.x
Subnet mask: 255.255.x.x
Gateway: 192.168.X.1
DHCP should always be enabled on the router for your other devices to work.
Nov 01, 2012 | NetGear N300 Wireless Router
I have broadband with a wireless router but it wont connect without an ethernet cable, I cannot seem to find a wifi driver on the pc to enable me to use my wireless router
As you have mentioned that you have a desktop PC . So you need a wifi lan card to access the wireless router. Then you can access the internet through your wifi router. You can buy a wifi lan card for the same and go for Netgear GA311 for the same. Hopefully it will help you.
Jun 15, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
How do I connect my netgear router to my desktop internet to use with my laptop. Followed instructions but when cable is disconnect from my laptop I can't connect to the internet
First Connect the Desktop with Netgear Router with the Ethernet cable. Open the Netgear GUI and configure a Wireless Network. Once its configured, switch On the WiFi switch from your Laptop and try to connect your Laptop. Make sure your laptop has an in-built Wifi adapter, if it doesn't then you would need to buy an USB based Wifi Adapter.
Also if you want to use the Internet with your Desktop PC without being connected with the Netgear Router then make sure it has Wireless connection capability.
May 10, 2010 | Computers & Internet
How do i pair my iphone to my netgear router? the model number is dg834gu v5
Are you trying to connect WIFI? "pairing" is a bluetooth function. If the router has not already been configured for WIFI, then your iphone should see a local wireless network called Netgear. You should be able to connect to it with your iphone simply by selecting it and answering the security question. If it has already been configured, you should make sure it was setup for WPA or WPA2 (NOT WEP) When it was configured, it should have been setup with a passphrase (key code, encryption key) which you need to intially provide on your iphone to make the connection. Its pretty straight forward.
Apr 16, 2010 | NetGear DG834G Router
Can't connect to netgear wnr 2000
conect to netgear then shut down and turn it back on.
May 27, 2009 | Acer TravelMate 5520 Notebook
Connection wifi problems with ds and netgear
it might be a WEP password which is located on the botom of the router.
Jan 03, 2009 | NetGear WGR614 Wireless Router
Computers & Internet Logo
284 people viewed this question
David Payne
David Payne
