Question about Kitchen Ranges
Error code f03 viking
Error code
3 Suggested Answers
TAGTEL
  • 16 Answers
SOURCE: wd640 hotpoint washer dryer - error code F03
This indicates that the wash thermistor is "Open Circuit" and I think it is situated on the heater assy at the back of the machine.
Check the wiring and contacts between the thermistor and the PCB. If you still get the fault it could be the Thermistor ( which means replacing the heater ) or a faulty board.
If it is under 5 years old - Call Hotpoint as you have a 5 years Parts Guarantee mind you the call out is £89.98 but thats cheap if it happens to be the board!
Posted on Mar 16, 2008
  • 57 Answers
SOURCE: Washing machine has a F03 code when it starts to rinse
Hi I would advise you to check the filters in the water valves and check them for being open circuit
Posted on Jul 18, 2008
Just replaced motor on the Aquarius hotpoint
F03 Front thermistor open or
short circuit.
• Check security of module connector J12;
• Test from connector pins (approximately 500 Kohms);
• If open or short circuit, test thermistor and wiring between
thermistor and J12 to locate fault.
Sep 16, 2014 | Washing Machines
F03 DISPLAY ON MY NV-SD300 PANASONIC
go to panasonic.com/vcr and give them the model/serial # and ask what the F03 error code means and they can give you a solution for the problem.
Jerry
Aug 27, 2012 | Panasonic Televison & Video
Error code F03 flashing and beeping
hello,
what this error F03 code mean is an indication of over flow of water from the sensor reader temperature which might cost a chance of loose wire connection on the water temperature.
what you are to do to fix up the problem is to open (unscrew) the washer and then fix up the wire that have loose it position then clean up all liquid around the wire and the panel and (screen).then couple it pack make sure all power supply are OFF before doing this .
thank you.
Jun 12, 2010 | Bosch WFMC 3200 Front Load Washer
Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
Front load frigidaire washer w/ error code F03....doesnt want to drain. Tried spin/drain, delicates, and normal and all end up with F03!! Please help!!! Thanks Royce
The F03 code is a problem with your water system. your inlet valves may have failed.
Open up the bottom panel and you will find a tech sheet that explain the codes and gives trouble shooting techniques. here is the service manual, good luck, hope this helps......
http://frigidaireservicetips.com/pdf...icControls.pdf
Jan 06, 2010 | Frigidaire GLTF2940ES Front Load Washer
I bought a Whirlpool double oven AKZ161 and error code F03 appear
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
Aug 17, 2009 | Ovens
F03
Good morning.
Error code F03 means that the wash thermistor is open circuit, this means that the water is not getting hot.
You need to fit a new thermistor first of all, if that does not solve the prob, then you will have to fit a new heater element as well.
You will normally find the element and thermistor located at the rear of the m/c.
Access it by removing lower rear panel
To get the parts, go to-----www.hotpoint.co.uk
Plz rate my solution.
Thanks.
Jan 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
Panasonic DMR-EZ47V Error Code F03
I saw this same issue. I would unplug and plug in the DVD and it would still show error code F03.
It turns out that one of my kids had shoved a couple of small objects inside the VHS opening and it was blocking the operation. I removed the objects and it works fine.
This error code is not listed in the manual that came with the DVD player.
Dec 21, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Jul 18, 2008 | Kenmore 46462 Front Load Washer
Error F03
F03 is a loading mechanism error. look for something obstructing the loading arms in the mechanism - a label from a tape, a piece from a broken cassette, etc.
May 08, 2008 | Panasonic AG-DV2000 Mini DV VCR
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
