Question about Norelco 7800XLCC Electric Shaver
Need replacement batt for 7800XL - Norelco 7800XLCC Electric Shaver
HQ8 or HQ6? What is the correct head replacement?
These Philips Norelco Replacement Shaving Heads HQ8/52 are compatible with the following series: 7100 series, 7200 series, 7300 series, 7700 series, 7800 series, 8800 series, PT/AT700 series and PT/AT800 series. They are sturdy and durable and provide for a smooth finish. The Norelco razor heads keep your shaves close and comfortable and are easy to replace.
Norelco HQ6The Norelco HQ6 is men's replacement heads. The Norelco HQ6 is made up of stainless steel and contains 3 cutters. The Norelco HQ6 works with all Quadra Action razors. HQ6 Features:Replacement Heads Stainless Steel 3 Cutters / Combs
Norelco HQ6
Oct 14, 2015 | Head Health & Beauty
My bike will not run on batt power only charge already replaced batt
Needs statter replaced or regaltor replaced charge battery start bike put a voltmeter on battery to see how many volts is charging shouid be 13,50 try that MOPAR KENNY
May 22, 2011 | Suzuki GSX 600 F (Katana Motorcycles
Shaver will not hold a charge. Is there a battery replacement or would it be cheaper to buy a new shaver?
You will find the correct battery for model 7800XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
For shaver disassembly, see shaveroutlet.com video at link below
http://www.shaveroutlet.com/philips_norelco_shaver_disassembly
For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Jan 17, 2011 | Norelco 7800XLCC Electric Shaver
How do I remove the back panel so that I may replace the batteries?
You will find the battery for model 7800XL at shaveroutlet.com. See link below
Model 7800XL has 2 screws on the back. Remove the screws to take off the outer cover. You will then need to remove 3 more screws on the inner back cover. This inner cover has a tight seal and you will have to pry it up a bit to get it off. You can then access the battery and circuit board
Oct 06, 2010 | Norelco 7800XLCC Electric Shaver
Red light blinking then turns off new batteries
In order to clearly determine the fault the model of your KODAK camera is needed
However hope this will help:
If your cam use AA batt.:
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 01, 2009 | Kodak EasyShare C360 Digital Camera
Ready light keeps flashing red. Replaced with a new battery from Kodak today but did not fix problem. No picture in LCD.
If the correct recommended batt supplied from KODAK didn't solve the problem Then a repair is recommended.
Info on batt:
Remove the battery
Contact KODAK:
Oct 30, 2009 | Kodak EasyShare LS443 Digital Camera
Flashing battery light on the dash
check batt volts if under 13volts batt needs replaced.
one other test u can do is to check alternator by undoing neg batt cable when car is running, if car dies alt is bad. cars dont need batt to run just to start :)
Sep 24, 2009 | 1985 Volvo 740
I replaced the alt and batt on my 2001 chevy 2500, now the red batt light flashes on and off. The volt meter reads normal.
Its probably something as simple as loose sensor that needs reconnecting, but drive the car down to any auto repair shop and they can do a Free OBD and tell you exactly the problem.
Aug 09, 2009 | 2000 Chevrolet 2500
Don't know how to get my battery out of my sidekick II?
The device does not contain a user repl battery.The batt is rechargable and is recommended that you charge it nightly.It uses an internal lihtium ion batt.They say contact cust care due to fluid that may leak from the internal batt can result in injury to skin and eyes?? Theysay cust care for assis if you need repl batt.http://www.wirefly.c...
Jul 26, 2008 | T-Mobile Sidekick II
Norelco 7800XLCC Electric Shaver Logo
23 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
