Question about Kustom 12 Gauge 16W 1x12 Guitar Combo Amp
Can't find the fuse on my Kustom 12 guage amp
I have a Kustom KPM8420 PA mixer and the monitor channel comes through both the monitor and main speakers and vice versa. The two channels are not separate.How do I fix that?
On the back panel there is a section labelled Patch Bay
There are 2 small switches which assign each Power Amp to either Monitor or Main Output.
It would seem you have them both set the same at present. Set one to Monitor and one to Main, and use the corresponding Power Amp outputs direct to speakers.
Note you can send signal to external amps or powered speakers from the preamp outputs. This is really handy.
Download and print the manual from https://www.manualslib.com/manual/90516/Kustom-Kpm-8420t.html
and keep it with the mixer.
( Of course don't send speaker outputs to other amps or powered speakers )
Sep 11, 2017 | Kustom Music
Kustom seinna 16 amp. reverb quit working. is their a fuse
Not separately on the reverb circuit. Timee to take it to the shop.
Mar 02, 2017 | Kustom Music
How do i replace fuse in kustom kpc10mp powered monitor
Remove the power module from the cabinet. You'll find the fuse on the circuit board.
Feb 14, 2016 | Kustom KPC10MP 10" Powered Monitor Speaker
How to replace fuse in kustom kpc10mp powered monitor
Remove the power module from the cabinet and you'll find the fuse on the circuit board.
Hello. Where is the fuse located to be replaced in my Kustom KPM4060 Amp. Thanks Shawn.
I have the same problem with my KPM 4080 amp. I have no clue where the fuse goes. I'm sure mine also needs a fuse replaced.
Mar 11, 2015 | Kustom Music
I have got a kustom KPC10mp and i am trying to hook it up to a kustom non- powered and i cant get no sound thru the monitor , Can this be done .The line out dont make no sound when it is connected to the...
In a word, NO. The line out is line level audio... it has NO power amp and cannot drive a non-powered speaker. I have both of these cabinets myself. You need to use an amp with the non-powered speaker. When using an external amp you will need to make sure you phase the two speakers correctely... you could just reverse the speaker leads of the non-powered one if needed.
Sep 11, 2011 | Kustom KPC10MP 10" Powered Monitor Speaker
Kustom Profile One Blowing Fuses
likely a failure in the power supply or in the final power amp stage. Keep putting fuses in to "cook" out more parts to increase the repair expense... DON'T !!! Take for repair as a fuse isn't going to fix the problem.
Feb 08, 2011 | Music
I have my first ever electric guitar with a kustom dart 10 amp. I understand that the amp has to be plugged in to the mains through a power cord, but the kustom dart 10 brings none. Is this normal.?
No, there is a cord. OFTEN the cord is buried in cavities in the plastic foam or in cavities in cardboard like spacers in the original box. For some small amps the cord is permanently attached and is coiled up in cavity behind the speaker.
Jan 06, 2011 | Kustom Dart10FXA 10W Guitar Combo...
Kustom 12 Gauge 16W 1x12 Guitar Combo Amp Logo
65 people viewed this question
Top Kustom Music Experts
Michial Gueffroy
Are you a Kustom Music Expert? Answer questions, earn points and help others
