Question about pcb Tnph0857 Main Board Panasonic Motherboard Tc-l42u22
Panasonic tv turns off then blinks 12 times
Tc-l42u25
Panasonic viera tv model #TC-L42U25 Had a lightning strike tv went off. Hit power button it comes on no picture or sound then turns off and flashes code 12. Is there any hope? Thanks,Patrick
Most likely your A board, which is the main circuit board. Best to call a technician for that. This may help.
http://electronicshelponline.blogspot.com/2012/05/panasonic-plasma-tv-blinking-codes.html
Apr 21, 2017 | Panasonic Televison & Video
Panasonic viera tc-p65vt50, lite blinks 12 times and then starts over.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Jan 22, 2015 | Panasonic Televison & Video
How do i get audio out for my headphones
If the TV has a headphone socket, you can use it to connect your headphone. If not, you can't. Refer its user manual for more details about it. . http://electronicshelponline.blogspot.com/
Oct 19, 2014 | Panasonic TC-L42U25 42" Class Viera U25...
What is causing the Panasonic Viera C22 series TV to power down and blink 12 times?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Jun 17, 2014 | Panasonic Viera C22 Series TC-L32C22 32"...
First timer here. Panasonic Have a tc-l42u25 with power light blinking 12 times. Can hear a loud whining sound from it upon powering on but it stops the power light is flashing. What could this be? I read...
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. If you're sound in electronic, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 28, 2013 | Televison & Video
Panasonic TC-L42U25 Will not power on. It turns on and you hear a loud whirling noise then it shuts off and the power light blinks 12 times. I read someone thought it was the power supply but when they...
Check its backlight inverter board. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 28, 2013 | Panasonic VIERA Televison & Video
WHY MY panasonic tc-50ps14 IS BLINKING A RED LIGHT 11 TIMES AND HOW I CAN FIX IT?
I have a 10 blinks and 12 blinks for that set, 10 says it possible SC board, and 12 says
Unplug the TV and disconnect connector A11 from the A board. Plug in the TV and press the power switch
Does the TV power up and
stay on?
No
Yes
If the speakers wires
are not pinched,
Replace
the speaker
Replace
the A board
Jan 16, 2011 | Panasonic TC50PS14 Plasma TV
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
May 14, 2010 | Panasonic Televison & Video
pcb Tnph0857 Main Board Panasonic Motherboard Tc-l42u22 Logo
Top pcb Computers & Internet Experts
David Payne
David Payne
Are you a pcb Computer and Internet Expert? Answer questions, earn points and help others
