Question about Crate And Barrel Dripless Turkey Baster
Baster will not suck juices up - Crate And Barrel Dripless Turkey Baster
  • 2,113 Answers
Here in Canada you can replace those for $1 at a dollar store
Posted on Nov 28, 2013
How do i drain the gas from my Rigid 3000 psi pressure washer with Subaru engine?
Then the next easiest step is to use a turkey baster and suck it out through the fill hole.
Jul 13, 2015 | Psi Garden
How do I get standing water to drain from bottom of dishwasher
I usually get a wet/dry vac and remove the drain hose from the air gap and or garbage disposal and suck it out that way. I have also seen people use turkey basters. Towels work great too. What is wrong with it?
Mar 16, 2015 | Bosch Dishwashers
What type of power steering fluid does a 2002 buick lesabre take
I've found that SeaFoam TransTune works wonders and often quiets pumps that are a bit noisy. If the fluid in it is particularly dark you will want to suck out as much as you can with a turkey baster before refilling it.
Feb 20, 2015 | Buick Cars & Trucks
Car battery corroded, terminals white. Jumped car but doesnt rev. Must it be alternator or could a dud battery suck the juice from alternator to stop car reving?
I would take the battery out and have it checked, or, you might want to invest in a modern battery charger that can also check the charging system as well as desulphate lead acid cells.
Jan 26, 2015 | Cars & Trucks
Drain some transmision fluid
Suck it out with a turkey baster with a long hose attached, or a siphon kit for a gas tank.
Apr 20, 2014 | 2001 Mitsubishi Diamante
2002 dodge dorango very bad squeaking noise when driving and turning wheels coming from the front end
steering pump or belt. make sure steering reservoir has correct amount of fluid and is not black. if its black you might try sucking whats in reservoir out with a turkey baster or syringe and refilling with fresh fluid.
Aug 12, 2013 | 2002 Dodge Durango
Change fuel
Suck it out with a hose ... remove the tank and dump it ... pump it with a pump ... draw it out with a turkey baster. This isn\'t difficult.
Jun 01, 2013 | 2006 kawasaki KX 250 F
Ge profile bottom freezer
i used a turkey baster to blast hot water through the drain to the pan took a few tries but it worked. sucked up all the old water first then gave it a good hard shot.
May 16, 2013 | Refrigerators
Does it have a fuel tank drain?
I am guessing that you have a fuel tank under the seat. If so, there is no drain. It has to be sucked out somehow. I had to do this for a neighbor recently on his JD, and I used a turkey baster to **** it out and put the fuel in a bucket. It works, just never be able to use the baster again for cooking, but they are cheap to buy anyway. When you get all the fuel out look down and make sure that it is clean of stain, varnish, or debris. You may need to rinse with fuel to get it out, shooting and sucking with the baster. This system works, I know for a fact.
Now you need to purge the fuel line of bad fuel. You do this by finding the fuel pump on the engine. It is the round, black thing on the side towards the back but not on the back. It has three hoses, fuel to the pump, fuel from the pump and a line that uses changing pressure in the crankcase to operate the pump. Find the line between the fuel pump and the carb. This line will most likely have a fuel filter in it also. Remove the line at the fuel filter and redirect to a bucket and turn the motor over with the key to operate the pump and flush the bad fuel from the line. Before putting the line back on a fresh fuel in tank, replace the fuel filter and drain the fuel from the carb and clean the bowl of the carb. If you are lucky, you may get away without a carb teardown for cleaning.
I hope this helps, if any more questions about this, just reply and I will get back to you.
If you find this really helpful, please rate.
Jul 16, 2011 | John Deere 22HP VTwin 48" Riding Mower
My nephew has put diesel in the wrong tank on our mower!
Hi!
No big deal:) easy to fix that problem! you engine isent damaged in any way.
Just remove the diesel from the tank, make sure all diesel is out.
Fill the tank up with the fuel it takes, restart it. It might take a moment for it to start, but it will start sooner or later,dont give up, it need to get all the diesel out from the tube and that can take a couple of minits.
Good luck
Nic
Apr 09, 2009 | Garden
Crate And Barrel Dripless Turkey Baster Logo
558 people viewed this question
Top Crate And Barrel Home Experts
Donni Steen
Tom Chichester
Are you a Crate And Barrel Home Expert? Answer questions, earn points and help others
