Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore range 790-74232D, which ofifices go to which burner when converting from natural gas to propane
Need to know what color orifice goes with what burner
SOURCE: convert kenmore gas range to propane
You unscrew the orifices in the range and screw in the new ones.  In the oven you adjust the hood around the bake orafice by screwing it down.
Posted on Jun 08, 2008
SOURCE: Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Posted on Jan 05, 2009
jumptrout51
  • 3361 Answers
SOURCE: Can a kenmore gas stove be converted to propane
Yes.
If you have the owners manual it may tell you the location of the conversion parts that are probably included with the range.
Posted on Mar 12, 2009
  • 57 Answers
SOURCE: Need to convert from natural gas to LP. How?
I converted a gas range several years ago, and all that was required was that I had to 'seat' all of the orfices - or tighten them down so that they are completely seated (do not overtighten!). It has been working great for years!
Posted on Sep 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: I just bought a newer
Remember this: Crank down and flip. You must tighten down all the top and the oven valve orifices and open all the hutters and flip the nut on the regulator. crank down and flip.
Posted on Jan 14, 2010
Conversion of Kenmore Elite Gas Range 790.7523 from Natural gas to propane.
each burner has a natural gas jet or (orifice) as you pull them out, one atb a time. You should be able to color coordinate them at that point. the jets will be at the end of each gas line right before the burner. and each burner gets one. I haven't seen the model you are referring to. but the ones i have changed out in the past, usually the hole is the same size for all the burners no matter the size of the burners. I hope this helps. good luck with it!
Jun 17, 2015 | Kenmore Kitchen Ranges
Convert maxitrol regulator#rv47cl natural to propane gas
Some gas ranges cannot be converted. If your model can be converted it normally requires flipping over the regulator diaphragm and also changing orifices for all burners, surface and oven. Most modern new appliances come with the LP orifices located on a card attached to the regulator.
Nov 18, 2013 | Kenmore 72132 / 72134 Gas Kitchen Range
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
I have a Frigidaire Stove, Model # FGF316ASA. It was changed from propane to natural gas. The oven works well. The burners, however, will only burn a low flame. Is there a solution for this?
When converting an appliance from propane gas to natural sometimes a technician will drill the orifice to a larger size rather than replace the orifices. Either way is fine, but sometimes the orifices don't get drilled to the correct size. The regulator must be on the propane setting if it is a convertible regulator. If your oven is working fine.... the top burner orifices probably need to be checked that they are the correct size. A simple fix.
Tom
Aug 11, 2010 | Frigidaire FGF316 Gas Kitchen Range
Kenmore gas stove can it be changed to work for propane
Yes, your gas range can be converted to propane. Your owners manual will give you step by step instructions. Since there are many different models, there are different procedures involved to convert to propane. On some models you must change the top burner orifices where other models have adjustable orifices. The oven burner has an adjustable orifice(same with broil burner if there is one). The range regulator must be adjusted to stay open all the time because your propane system has its own regulator.
Mar 21, 2010 | Kenmore Kitchen Ranges
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Propane coversion of kenmore 790 gas range
Most gas stoves are shipped for natural gas .You need to check the orifice on each burner to see if they are for natural gas or propane.If you ordered propane the stove should have been shipped with the orifices.They may be in a bag with your stove documents.
tk46
Jul 13, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Burner flame height adjustment
All ignitors will always arc whenever one of them does.
I haven't worked with propane systems much, but it seems you may need the propane pressure regulator adjusted.
If the problem is only with the power burner, I would ensure that particular orifice was actually changed. The hole in a propane orifice is smaller than for natural gas.
Jan 08, 2008 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Nat gas to propane conversion
With the gas turned OFF, you will need to find the gas regulator on the range. It will located in the back of the oven along the bottom somewhere. It's usually a square shaped valve with a nut on top of it. The gas valve orifice is located under the nut. All you need to do is remove the nut, take the orifice out, flip the orifice over and re-install to convert from one type of gas to the other. It should be marked which side is LP (propane) and which side is for Natural Gas. LP will have a smaller orifice opening than Natural. You will want to make sure the orifice size you are using is facing UP, then screw the nut back on the regulator. You will also have to do this for all the surface burners (if you haven't done so already). You will know if you have the orifice turned the wrong way because the flames will be too high, the oven will get way too hot and there will be soot everywhere. Hope this helps you.
Aug 11, 2007 | Sears 61301 Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
