Question about Symantec Norton Internet Security 2009
Installed Norton 2009, now only boots BSoD 0x00000024
After the installation of Norton 2009, the family computer only boots to the BSoD with the error:
0x00000024 0x00190203 0x86B8ADE8 0xC0000102 0x00000000
This occurs both in Safe Mode and running Windows normally. I'm suspecting a registry error, based on some basic Ask Jeeves researching, but what's the fix?
    President:
  • 423 Answers
1 delete norton from your hard
2 run tune up utilities 2008 and execute the registry cleaner
3 open the registry and search anything which have relation with norton for exp : norton 2009 enter
delete the left keys and search them by pressing f3 then delete
reboot the computer instal the antivirus and everything will be allright
rate this if its helpful ;)
Posted on May 30, 2009
I bought a ep43-ud3l mobo that I installed with windows, after moving some files from my old hard drive windows became corrupted , boot up resulted in BSOD, erased windows bsod, formated HD BSOD, removed...
pls check the cpu compatibility. one time I tried to install 64bit , but could;t install. 32 bit was ok. check the video adapter and remove it and try it with on board vga
Jul 17, 2017 | Gigabyte GA-EP43-UD3L Motherboard
Virus MS AntiSpyware 2009
HI,
Your PC has been effected with spyware.You can try using a spyware software like webroot 2008 to remove this.
This is the only solution to fix this thing.
Dec 30, 2008 | Computers & Internet
Initially a gateway pentium 4 with XP got a boot sequence failure with BSOD 0x000024a. left it plugged in for a couple of hours, now the boot sequence fails with a BSOD 0x000021. What next?
STOP error 0x24 means a problem occurred in ntfs.sys, the driver file that allows the system to read and write to NTFS drives. STOP code 0x00000024 may also display "NTFS_FILE_SYSTEM" on the same STOP message.
Seems your hard drive is experiencing problems causing this error to occur.
Feb 16, 2010 | Gateway 400VTX-3501335 Notebook
I have installed the norton 2009 disk weeks ago but forgot to enter product key. how can i do that now?
Open Norton from your system tray
Click My Account
Click on Activate Norton...
Enter the Product key
Oct 07, 2009 | Symantec Norton Internet Security 2009
Norton antivirus 2009
try to upgrade nortons virus data file on norton's main menu
Sep 17, 2009 | Symantec Norton Antivirus 2009 CD 3 User...
I installed norton antivirus 2009 with antispyware,nowi lost some files i keep getting a windows exeplorer error message then my start screen froze up also i cannot use my system restore
boot into safe mode then try restore or boot from your windows disc to repair previous installation. Don't use norton, resource hungry invasive software. plenty of good free ones like antivir
Aug 02, 2009 | Symantec Norton Antivirus 2009 1-User -...
Cant install norton
today quick heal is most successs antivirus if you want to install
Downlaod from here
http://download.cnet.com/Quick-Heal-AntiVirus-Plus-2009/3000-2239_4-10838310.html
Tehn update it from internet .
Then scan boot time.
Jun 23, 2009 | Norton Internet Security 2005...
Bsod, error code:0x00000024, hdd problem booting xp os
Can you do this
Boot from the Windows XP CD.
Watch for a Press any key to boot from CD... message similar to the one shown above.
Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console
Select your OS and enter password (if needed)
When you reach the command prompt type the following and then press Enter:
expand d:\i386\hal.dl_ c:\windows\system32\hal.dll
Using the expand command as shown above, d represents the drive letter assigned to the optical drive that your Windows XP CD is currently in. While this is most often d, your system could assign a different letter. Also, c:\windows represents the drive and folder that Windows XP is currently installed on. Again, this is most often the case but your system could be different.
If you're prompted to overwrite the file, press Y.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Apr 24, 2009 | Sony VAIO VGN-T170P/L Notebook
Attempted to upgrade Vista to SP1 on an E-machine, during install, Norton reinstalled, upon rebooting - BSOD so I don't know if SP1 issue or Norton, or both. Using VISTA disk, the bar progresses and then...
Try booting into safe mode.
If you can, I suggest getting rid of Norton. The drivers are not compatable with vista.
Vista has a ton of issues and many types of softwhere will not run or work.
If you want a good virus software, use the new software from Microsoft.
Feb 21, 2009 | E-Machines eMachines Desktop PC
Norton Internet Security 2009 Causes Blue Screen of Death.
Hi there
Thats Norton for you! this is a very heavy and memory hungry program, it takes control of your computer and if you have not got enough system or virtual memory it will cause the pc all kinds of problems. To fix this either upgrade the system memory or don't use Norton, use AVG free instead, its a lighter program and lets you have some speed back over the internet.
good luck and thanks for using Fixya!!
Feb 11, 2009 | Symantec Norton Internet Security 2009
Symantec Norton Internet Security 2009  Logo
262 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
