Question about Frigidaire GLEQ2152ES Electric Dryer
Error code Ad - Frigidaire GLEQ2152ES Electric Dryer
  • Official Brand Answer
  • 4,342 Answers
Hello Rachael, thank you for your inquiry!
Typically error code AD indicates that the Auto Dry option has been selected. Typically when using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting another option or resetting your dryer. You may either unplug it or flip the household breaker off for approximately ten minutes. Turn your dryer on then select a normal cycle. Your appliance should resume normal operations. If this problem persists, your dryer may possibly have a faulty heating element, blower assembly or a communication problem with the control panel. This is not a normal DIY job. You may want to connect with a local servicer to determine the exact diagnosis. I hope this helps explain the error code you are receiving.
Posted on Dec 02, 2013
Frigidaire affinity dryer code ad
Hey Cindy, thanks for your submission!
I see that your Frigidaire dryer is displaying an error code of "ad". The "ad" error code will display with the "Auto Dry" cycle has been selected. If you did not select the auto dry cycle I would suggest performing a reset on your dryer and you can do that by disconnecting the power cord for at least ten minutes. Once power has been restored to the dryer and if the error code is still persistent you may need to have a replacement control panel or wiring harness installed. I would recommend having electrical parts replaced by a professional technician this will prevent any personal injury. Best of luck! -Matt
Mar 08, 2016 | Frigidaire Dryers
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
My frigidaire dryer GLEQ2152ES0 runs but no heat ?
Good Morning Friend,
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# GLEQ2152ES0. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Dryers
Ad error code
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# AGQ7000E. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 06, 2014 | Frigidaire AGQ7000E Gas Dryer
Dryer says ad stops mid dry
Good Afternoon Imadesigner Custom,
I see that you are receiving an AD error code on your laundry center, model# FEX831CS, and your dryer is stopping mid-dry. I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your dryer, if it is still showing an AD error code, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 21, 2014 | Frigidaire FEX831CS Top Load Stacked...
Frigidair affinity dryer error code Ad
AD is not actually an error code, but is typically considered an Air Dry setting or feature on the unit.
Aug 06, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Have a canon ir-5570 w/ error E00000-0010 will not allow me to reset code Any ideas? Tried the reset procedure of ad.funct 2 & * adfunc will not go into mode
press ad.funct. then press 2 & 8 keys at the same time,
then press ad. funct. , copier display shows setup mode go to (function)
tab and press clear error.
Aug 20, 2009 | Canon imageRUNNER 5570 Copier
Error "AD" when drying
thats not an error code error codes are f codes eg. f01 f02 thats a cycle code for auto dry are you having any promblems other than the display
Mar 26, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
192 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
