Computer says that mouse works properly and everything is all right, except it won't move. It doesn't react properly. It's like the wireless mouse and it's stick won't communicate properly. what shall i do?
Have you tried to add a mouse pad under it. I have a capricious mouse myself that has to be on a pad to work fine. If you don't have a pad just try it on a dark surface, no glass that's the worst one...
It can also be a simple battery matter, distance is also important depending of the communication technology in use.
good luck
?· If you plugged into the mouse port, restart your computer manually.
?· If you plugged it into the USB port you may begin using it.
?· When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven
