Question about Toshiba PSAFGU-058002 Notebook
Computer shuts down for no reason- fully charged
A215-6804 shutsdown for no reason
  • Toshiba Master
  • 5,660 Answers
1.I suggest your laptop is getting too hot. When the processor becomes too hot, it shuts off. (BIOS turns it off, actually)
This is a fail safe feature, to keep the processor from burning up. (Literally! Like on fire!)
Processors usually become too hot, when the Air Intake Duct is clogged with foreign debris. Dust/Dirt/Lint/Food Crumbs/Carpet Deodorizer, you name it, is 'inhaled' through the Air Intake Duct.
With the laptop on, you've probably noticed that there is an opening the laptop brings air in, and an Exhaust Duct that heated air comes out of.
You may also have noticed that the Air Intake Duct is located on the bottom. Sometimes it's on the side, near the Exhaust Duct. A very poor place as the above stated foreign debris is easily brought into the laptop.
Add to this, that there is a small fan at the end of a funnel like opening, bringing the air in. The funnel like opening is called a Cooling Tube. The large size of the Air Intake Duct that you see, usually narrows down to a Cooling Tube that is the width of your finger width, and about half as thick in height. At the end of the Cooling Tube is a filter made up of a porous sponge like material. (Synthetic) This traps all of the foreign debris.
Laptops have a poor cooling design to start with. All of the hardware components are crammed into one small box, and there is a little fan to blow air over the components. Very inefficient!
To help rectify this, you could purchase a can of compressed air for computers, and try blowing the Air Intake Duct out. (NOT the Exhaust Duct!)
AC adapter removed, (Charger), and battery removed. Break the plastic lock tab off of the can of air's trigger mechanism. (It's on top) Insert the plastic 'straw'. Laptop held up on it's side on a table, with one hand, can of air in the other.
Bring the straw about 1 finger length away from the Air Intake Duct grille. NO closer than this, at this time! Start at the top left corner of the grille, and spray air across. Squeeze the trigger in all the way as you start, let go when you are at the end of the other side.
Drop down a row. The distance you drop down is up to you. Your 'Guesstimate' will be pretty accurate. Go across again. Keep going down until you are at the bottom.
Now bring the straw back up to the top. This time, put the straw right against the grille. BUT, this time use Short Bursts! Squeeze the trigger in all the way, BUT let go quickly!
You are using Short Bursts now, because of the small fan inside. The fan is only designed to spin so fast. Spinning it faster than it was designed for, can lead to premature failure of the fan's bearings!
(The fan's bearings will go out before they're designed to, and the fan will stop spinning)
While using the can of air for a length of time, you may notice that the air pressure seems to drop. This is because the air is coming out so fast, that the outside air's moisture is freezing. You'll see frost on the top of the can. Just let the can sit for a while, and warm up, then you can use it again.
You'll also note that tipping the can of air will cause propellant to come out. You're supposed to keep the can level while using it, but when doing a good job, this becomes hard to do. It's okay, just refrain from tipping the can a lot.
I suggest bringing the laptop back to it's normal position, and propping one end up with a book. This will give time, for any of the propellant that came out of the can, and went into the laptop, to dry out.
Give it about 10 minutes or so. When you are satisfied the laptop is dried out, reinsert the battery, and then plug in the AC adapter, (Charger) Give the laptop 2 minutes, then turn it on.
2.Listen to make sure the fan is spinning, and is bringing air into the Air Intake Duct. The fan may have quit in the first place, and this could be the problem.
You may also want to invest in a Cooling Pad. There are expensive ones, and inexpensive ones. Some of the inexpensive ones will do the job just fine. Here are some examples of Cooling Pads,
http://www.xoxide.com/noco.html
Posted on May 09, 2009
    Problem Solver:
  • 3 Answers
If the screen is blank with only the pointer you may need to flash your bios. I had that problem, and others too. I got the bios upgrade from Toshiba.
Posted on Jun 11, 2009
Charging light flashing orange, but computer is fully charged.why won't it shut off..been doing this for 3 days?
How old is the battery? Is it the newer Ion type you find inyour phone? It is a common problem for a battery to get as fully charged as it can be an still be charging. Because the capacity of the pack is no longer as high as it was new. Not sure if this is your problem, but open battery case, check contacts, make sure they are clean, inspect battery to see if there are bulges, etc. does the battery still run the computer as long as it did before, if so battery might not be the problem. Changing battery packs have solved all my problems in the past. Also do a complete shut down, many people just let computer go to sleep an never restart. Sometime windows just loses drives an for no reason. Check all these first.
Mar 19, 2015 | Acer Aspire One D255 Netbook
Tip
How to get the most out of your iPod battery
When you first get the iPod make sure to fully charge it. Then only charge the iPod when it is so dead that it will not stay on long enough to play anything. Then allow the battery to charge until a screen appears saying fully charged. This may seem redundant but it ensures the batteries capacity will be maximized for as long as possible. There are only about 1800 charge cycles in an iPods battery life. This may seem like a lot of charging ability but when you wish to keep the iPod for more than a year and a half it becomes more realistic that it is not.
Above all else, never ever remove the iPod from the computer without ejecting it first.
If you are for some reason unable to properly eject the iPod, first shut down your computer before removing the iPod.
on Jan 14, 2010 | Audio Players & Recorders
Gps shuts off regularly
From what I've experienced, repeated restarting, and frequent shut downs, can be traced back to a defective power cord, and/or a low battery state. Garmins operate best with a full battery charge, regardless their connection to external power.
If you can get it to connect to your computer, and can see it as a device with removable storage, right clicking on it's icon, and select "properties" to show you the battery-charge state detected.
Mine won't charge when connected to the computer for some reason, and won't boot even if left for a few hours, but if I connect it to a dedicated usb charger, (the kind that plugs into an A/C outlet with a USB port) it will begin to charge. After fully charging it returns to normal operational state. If it still can't charge it may need a new battery...
Apr 06, 2014 | Garmin nuvi 2455LMT
Tomtom
My 2 year old TomTom gps Via 280 will suddenly not turn on
Jan 16, 2014 | Tomtom GPS
Laptop will not complete power up with new fully charged battery.
This would surely indicate an issue with the mainboard of your computer since even after replacing the battery you are unable to get the battery to be recognised and the computer shutsdown automatically so what you could do is contact technical support and setup a repair for your computer.
May 31, 2010 | Acer Aspire 3690-2196 Notebook
Purchased a new Dell Inspiron 6000 (9 cell) battery
You just want to refresh battery from the BIOS. There problem will be solve
Mar 15, 2010 | Dell Inspiron 6000 Notebook
The PSU fan does not run, computer shutsdown.
Check the CPU fan, it may be faulty and causes the CPU to overheat and shut down.
Sep 02, 2009 | E-Machines eMachines Desktop PC
Computer just shuts down for no reason. fully charged
Myself, my fiance, and my brother all have satellites and all three of ours have had that problem at one point or another. The problem with my computer was that it was overheating causing the shut down. Is the top of your computer hot to the touch when this happens? If so, I'd recommend propping it up on something to allow the air to escape from the cooling fan on the bottom of the unit. I hope this helps you.
May 09, 2009 | Toshiba Satellite A215-S4747 Notebook
Laptop won't power up!
disconnect the battery and just keep the ac power connected. hold down the FN button and hit the power button. if some lights falsh and the computer shutsdown in 4 - 5 seconds its a bad motherboard. If you get other light lemme know. Call dell tech support and get a dispatch made if system shutsdown right after the lights flash. You can also try the chat support at www.dell.com/chatsupport
keep a phillips screw driver handy when you call as they might as you to disconnect the hard drive, CD drive and other cards like thememory card and wireless card to check if they are not causing the issue.
Rate if helpful.
Sep 24, 2008 | Dell Inspiron 1501 Notebook
Garmin 320 shuts down
I suggest you take it to the store. Probably an internal errorr
Mar 02, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
Toshiba PSAFGU-058002 Notebook Logo
525 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
