Question about Datalogic Quickscan M2130 - Barcode Scanner
Not scannd Since yesterday we have created our barcodes, that we use for our shop only, and all worked good, but today we have created some new barcodes that does not work any more. Our scanner has a strange behavior: codes since 123456789978+ value automatically calculated are perfectly scanned, from 123456789979 onward codes do not work. Is there someone who have any suggestions to solve our problem please? Enrico.
  • 279 Answers
SOURCE: Scanner isn't scanning all the time
It doesn't sound like a power issue. Most likely it either needs cleaned, or it needs the laser recalibrated or replaced. Try cleaning the glass for starters, and then hold the scanner about two inches from a white piece of paper. You should get a solid, bright red line. If the line is distorted you need to recalibrate the laser. If it's dim, the laser unit is going out. The laser can be replaced, but I don't know if it's one of those things where the part plus labor costs more than replacing the scanner.
Posted on Aug 28, 2007
  • 58 Answers
SOURCE: Datalogic QS6500BT barcode scanner and 2D codes
Usually some symbologies are disabled at default.
i think you need the manual and scan the barcode to enable it for scanning.
the links is:
https://easeofaccess.scanning.datalogic.com/public/marketlit/Send.aspx?file=R44-2816A
it's chapter 6-191 or page 279 in pdf.
you have to begin with scanning "Start" en end with scanning "END"
becarefull with printing this page and not the whole manual. there are 336 pages.
good luck
Posted on Jan 16, 2009
sleepy_user
  • 140 Answers
SOURCE: Cannot get the datalogic qs6000 to scan 39 or 128 barcode
Sounds like you need an updated driver for your POS scanner.
Other than that, try checking the scanners setting your software and make sure it is set for 39 and 128 bar codes. There is usually a setting that will specify what codes the scanner is going to read.
You can always shoot an email over to the datalogic guys and see if they have any more input on the situation.
Posted on Jan 23, 2009
SOURCE: The scanner is scanning but no data is transmitted to the PC
I also purchased a Symbol LS4071 and when I connected this scanner (purchased at a great discount through eBay) to my computer using the keyboard wedge (with a ps2 connection - the round connector - the connector is split like a "Y") I received the error message that my computer could not recognize this external hardware. I went to barcodediscount.com and ordered the usb connector for this scanner as usb connections are usually recognized. The part # for this connector is STI85-0200R. It cost 72.55 with shipping, but I received the scanner at such a wonderful price that I thought I'd chance it and try it with a usb rather than a keyboard wedge connector.
The computer immediately recognized the usb connection, and the usb connector comes with a manual with codes to enable proper scanning, but still no luck getting the data into the computer. So I called Symbol's technical support department. The technician told me to remove the rubber "boot" at the bottom of the hand held scanner (not the scanner base) by pulling on the front of it (where the 2 little round circles are). It's tough to remove, but keep at it. Then gently remove the battery and unplug it, then plug it back in and reattach the base. He said this would reset the battery. Voila!!!! Sucess!!!!
If your scanner's keyboard wedge connection is recognized (a little popup window will say that it is a Symbol barcode scanner and that it is installed and ready to use), try taking the battery out and putting it back in to reset it. Hopefully this will also work for you. Symbol's technical support # is (800) 722-6234.
Posted on Mar 23, 2009
SOURCE: To use the Gryphon D100 barcode scanner to work with windows XP
Thanks guy's. Overcame the problem by scrapping the whole idea and leaving it up to our "IT" experts. A resolution will be forth coming in due time by purchasing a whole new inventory system. Their solution.
Posted on Apr 02, 2009
When I turn on my processor, it begins to beep 6 times repetetively and my monitor remains blank. The fans are still functional and this problem did not exist until today (yesterday it was fine).
THE PROBLEM MUST BE WITH THE RAM. JUST REMOVE AND CLEAN WITH A CLOTH AND INSERT IT AND PRESS IT FIRMLY. THIS SHOULD WORK,.
PLS REPLY OR COMMENT. THANKS
May 20, 2011 | Computers & Internet
How to enable an enter for the ms4407 scanner
Create barcode with number 7013 in any program that can create Code128 barcode. Print it out. Check manual page 12-5 and scan <Data><SUFFIX 1> barcode and after that printed barcode witn 7013 number. It works with my MS4407.
Dec 27, 2010 | Zebra MiniScan MS4407 Barcode Scanner
SPACE problem. Hello i have Symbol LS 2208. I need remove space/gap from this code 09/ 5864 I tried to create rule for this (remove all spaces) but it wasn´t work - the scanner scaned no data. I use...
Hello, if all your barcodes have the same structure, it will an easy task. You would need to scan following barcodes from ADF chapter in the Product Reference Guide located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Create New Rule Send Characters Up To Space Character in Alfanumeric Section Skip Ahead 1 Send All That Remains Save Rule
This will by all scanned barcodes send all characters up to the space character, skip the space and send the rest of data.
Oct 22, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
Create a barcode for F1 and F2 using Labelview
If you have created your barcodes as "F1" and "F2" you will have to create two Advanced Data Formatting rules with the LS2208 Product Reference Guide. This link will take you to the manual. Print only the barcodes you need from the list below then scan them in the order they are listed:
Begin New Rule
Specific String at Start
F (from the Alpha-numeric section of manual)
1 (from the Alpha-numeric section of manual)
End of message (from the Alpha-numeric section of manual)
Send F1 Key
Save Rule
Begin New Rule
F
End of Message
Send F2
Save Rule
That should do it!
May 06, 2009 | Symbol LS2208 Handheld
Barcodes not scanning
Very possible you have a bad printhead. If you have a bad dot in your print area, it can cause barcodes to not scan. Look to see if you have a blank vertical line running down your label.
Dec 31, 2008 | Epson TM T90 Printer
New DVD w/message the DVD is not blank!!
I have a new HP Pavilion Ultimate - d49967 - Desktop PC. The program is HPs "Create backup copies of your files/folders."
When I try to format the disk the dialog box does not appear to allow choices. I then tried to use the disk and that is when I was told the "disk is not blank." I purchased the package containing the disks yesterday and opened the package today.
Thank you for your help. Silly Clown
Jan 22, 2008 | Computers & Internet
Datalogic Quickscan M2130 - Barcode Scanner Logo
16 people viewed this question
Top Datalogic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Datalogic Office Equipment and Supply Expert? Answer questions, earn points and help others
