Packard bell device
0EM7GRUB 0.4.4 2009-11-18 Memory:631k/3326m,Menuend:0X45DFD
SOURCE: packard bell easynote m5262
This is hard you have to take the laptop apart to get to the ram. but you have to remove the screen to get to the case screws.
Posted on Dec 08, 2007
  • 14 Answers
SOURCE: Trying to identify the memory module on an Packard Bell EasyNote
www.crucial.com
Posted on Apr 05, 2009
SOURCE: Upgrading Memory on Packard Bell MIT GHA20
If you look along the top edge of the escape/function/del keys, there are several small plastic tabs that hold the keypad in place. Use a very small flat head screwdriver to push these back from one corner across to the other, gently lifting the keypad as you go. When you press back the last tab, the keypad should just pop out but take care as it's connected by a cable at the bottom edge of the keys. The RAM slots are located under a thin metal cover under the keypad. You'll need a very small philips head screwdriver to undo this. After installing RAM, replace the metal cover then pop the keypad back in, bottom edge first and just press down the top edge and the plastic tabs should snap back into place. Hope this helps!
Posted on Jun 09, 2009
donfwhite
  • 122 Answers
SOURCE: packard bell imedia S1710 memory problem
No it is not normal for Win7... it should be the opposite... Win7 Memory Management is better than any other systems. I would do maintenance... clean out temp files and clean and defrag the registry. Glary Utilities works great for that or CCleaner. Then Defrag. Maybe just a false message caused by a bad temp file. If it continues I would have issues with the Hardware and seek a warranty replacement. Side note: turn off or uninstall products on the system you won't use.
Posted on Dec 31, 2009
  • 553 Answers
SOURCE: packard bell l4 beeps on start up for aBOUT 5 SEC
When your computer starts up it runs a series of test called the POST (Power On Self Test). When test is complete it beeps to let you know if the hardware is OK or if there is a problem. One beep means the hardware passed the test with no problems. If your getting more than one beep you'll have to check with your manufacture to find out what it means. Go to their web site and search "POST error codes", this should give you the information you need.
Posted on May 22, 2010
Packard bell s3270
You can have a much as 8GB (2x4GB) RAM in the device. Here is a video that explains how to access the RAM. Good luck!
How to upgrade memory in Packard Bell OneTwo Computer
Apr 17, 2014 | Acer Computers & Internet
How to insert an sd card on a packard bell windows vista home premium computer
Windows logo button ('Start') > Computer > Removable devices.
DOUBLE-click on the file name to the right of - Removable devices
Regards,
joecoolvette
Mar 21, 2013 | Packard Bell Computers & Internet
Packard bell 6700 outer cover removal
I would suggest going to the Packard Bell Support web site then select your country followed by selecting your model of computer which will then give you access to any available documentation to help you with upgrading memory etc.
Jan 12, 2012 | Packard Bell iMedia 6826 (P481000502) PC...
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
I have two laptops - a Sony Vaio and a Packard Bell Easynote. The Hitachi HDD connects fine to the Sony via the USB - showing immediately in 'My Computer'. However, this is not the case with the Packard...
You might be using a lower version of OS in your packard bell computer. You will need to download and install a device driver for your hitachi HDD. Im not sure of the HDD model that you have but you can try searching the driver for the packard bell Operating system
Oct 25, 2010 | Computers & Internet
Usb on packard bell function slow (type usb 1.0)
This is normal. USB 1.0 is a lot slower than USB 2.0...why are you using USB 1.0 on a system that has Vista x64? Is it because of the device? Change the device...
Jan 12, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
I need to open up my packard bell Ixtreme computer to insert memory .. how do I do it
Most documentation for a Packard Bell iXtreme would be here. To upgrade, repair or replace your memory, this document could detail the steps involve including opening the case.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 27, 2008 | Packard Bell Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
