Question about Dryers
Replace belt on aqualtis AQCF852 - Dryers
Ariston aqualtis aqlf9d
PLEASE URGENT!! I have the same washing machine WMW-5812.ER when i press the power on it does not start up why? Please help children getting back to school this week....pleaseee....
Jan 04, 2014 | Washing Machines
Hot too put a belt on a aqualtis dryer
What is the model number of your unit?
Nov 17, 2012 | Washing Machines
Hotpoint aqualtis error code F04
Indesit (Hotpoint Aqualtis, Ariston) 'F04' states 'pressure switch jammed empty, check pressure switch, wiring and module connections'.
It is not that unusual to find it cured by having the connections gently pulled apart and replaced, thus 'cleaning' the contacts back to correct operation ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 05, 2011 | Washing Machines
I am looking for a manual for hotpoint aqualtis AQCF 852 BU. Can you help please?
I have the same dryer and went on the Internet and typed "Hotpoint Aqualtis" on Google. One of the alternatives is "Instruction Booklet" This when printed is the Manual for the dryer, in full.
Aug 25, 2011 | Hotpoint Dryers
Hotpoint aqualtis giving H20 error, looks like fill problem, but cannot see anything stopping the water flowing into the machine.
i have hotpoint aqualtis, it washes & empties but then starts flashing when ready to rinse. any suggestions?
Dec 04, 2009 | Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
A hotpoint aqualtis aqxx149pm spinning loudly
Hi, This is a common problem with the hotpoint range. It will be the main wash bearings that have failed and need replacing. This is a very easy process but is quite time consuming. Remember tho change everything that is; Bearings, and bearing spider and front tub seal as you dont want to have to do it again in a short time or have leaks coming from the front.
Good luck and get back to me if you need any further help....................
Jan 02, 2009 | Washing Machines
How do you replace a belt on a hotpoint aqualtis washing machine as the motor does not appear to have a bolt that allows movement and belt is very tight?
The belts that come on a hotpoint aqualtis washing machine is a stretch belt there is no adjuster for it but there is a little trick. TO HELP YOU SOLE THIS YOU NEED A BOWL AND A KETTLE. FIRST FILL THE KETTLE WITH WATER THEN PLACE YOUR BELT IN THE BOWL AND ONCE THE WATER HAS BOLIED POOR THE HOT WATER IN IT LEAVE IT FOR 5 MINS THEN TAKE THE BELT OUT BUT BE CAREFUL NOT TO BURN YOUR SELF NOW GRAB THE BELT AND PULL IT BY THE BOTTOM AND THE TOP BY DOING THIS BELT STRECHS ENOTHGH TO FIT ROUND THE FLYWHEEL AND MOTOR ALWAYS HOOK THE BELT FROM THE MOTOR FIRST THEN ROUND FLYWHEEL I RECOMMED WEARING GLOVES WHEN DOING THE JOB KEEP ME INFORMED ON HOW IT GO'S NOFFIE......
Apr 08, 2008 | Washing Machines
Dryers Logo
23 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
