Question about Velocity Micro Cruz Reader R101 Tablet PC
Reset password pattern - Velocity Micro Cruz Reader R101 Tablet PC
I got locked out of my kurio
If the tablet is connected to the internet, tap on forgot password or pattern then enter gmail account to receive an email with the correct password/pattern you set.
Below are steps to recover from being locked out. The first is the most extreme. The second is less extreme. And the third is probably the preferred method.
Firs, t the extreme reset. You lose your data but it returns it to factory default condition, i. e. right out of the box.
Kurio Extreme 2 Factory Reset
Secondly, the soft reset.
Kurio How to Perform Soft Reset
Thirdly, a Kurio password reset:
Kurio Password Reset Kurio 4S Kurio 7S Kurio 10S
Aug 28, 2017 | Tablets & eReaders
How can I reset my tablet?
    1. Here's how to execute a factory reset:
      1. Turn your tablet off and remove the SD card, if there is one.
      2. Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
      Forgot your tablet's password? - TechAdvisory.org
      www.techadvisory.org/2013/03/forgot-your-tablets-password/
    Feedback
  1. Forgotten Pattern, PIN or Password on an Android device
    acer.custhelp.com/.../forgotten-pattern,-pin-or-password-on-an-android-...
    What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
Nov 29, 2015 | Tablets & eReaders
Forgot pattern password
hard reset by recovery options
Nov 22, 2014 | Tablets & eReaders
Change pin number
hard reset by recovey options
Nov 14, 2014 | Tablets & eReaders
AX109JC20130709
You do not say what type of password was set and if you have forgotten it or just want to reset from a known password..
If you just want to change your gmail login password
- Go to google.com/accounts on the tablet browser
- Sign in
- "Change Password"
- Go back to the Home Screen on the tablet
- Open the GMail app, clicked on Menu, then Refresh -- you will get a sync error
- Wait for a notification to re-enter your password (a triangle with an exclamation point in the tablet notificaiton bar and/or something in the gmail screen)
- Enter the new password
This simple solution sometimes works:
Turn it off.
Turn back on.
When you get the warning triangle in the notification bar, open the notification.
You will then get a login screen.
Input your new password.
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for goole a/c details or security for pattern lock.
tap forgotten pattern and on next screen enter goole account details. Then next screen allows you to choose a new screen lock option.
Locked with PIN or password _Try Screenlock bypass pro from play store.
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
Face unlock - you were asked to provide a pattern or PIN backup when you set it. Just bypass and enter PIN or pattern.
Good Luck
Aug 06, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Forgot my password to get into my android table MID M729 the pattern on the top of the tablet
Normally, with Android devices, if you enter the wrong pattern five times in a row, the device will give you an option to enter your Google account information (e-mail address and password). Once you have done this, it will let you reset your security pattern.
If this doesn't work, the next best thing to try would be a firemware The firmware update process will wipe the root of the device (but leave your SD card and books intact), basically resetting it to factory settings, before you even set a security pattern.
Should this fail to work, contact Velocity Micro Support by calling +94756523353
Dec 28, 2012 | mid Archos M729B Android Tablet
Velocity Micro Cruz Reader R101 Tablet PC Logo
24 people viewed this question
Top Velocity Tablets & eReaders Experts
steve morris
steve morris
fred capra
fred capra
Are you a Velocity Tablet and eReader Expert? Answer questions, earn points and help others
