Question about Empire Direct Vent Wall Furnace; Modulating Hydraulic Thermostat Control (14,000 BTU) - MV-130 Heater
Small explosions hi I lit the pilot and waited till it stayed on after letting go the pushdown pilot switch I turned the switch to the on position and went to the thermo and turned it up for heat I then heard the normal pop and then an small explosion I turned everything off and relit the pilot and tried to start again with the same results next I thought about a blockage so I took apart the gas line from the main valve body to the pilot area and cleaned it then when trying to lite the pilot while holding down the pilot switch I noticed way too much gas flow like it was wide open what did I do wrong
  • Empire Master
  • 17,093 Answers
What is the make and model of the gas valve? They are not made to be taken apart and so the springs might be in wrong or the calibartion screws set wrong. At this point you probably are going to end up having to replace it.
Posted on Nov 28, 2013
2 Suggested Answers
  • 252 Answers
SOURCE: pilot won't stay lit
Your unit has a "vent safety limit switch" which is a high temperature limit. It gets hot enough to trip over time because you do not have proper venting. It is a safety switch and SHOULD NOT be disabled - instead find and fix the venting problem(chimney bad?)!
Posted on Mar 27, 2009
American range fryer will not light...the knob you turn to light the pilot light will not turn.you can push it in but won't turn.please help
From the Owners' manual:
LIGHTING
1. Before attempting to light this appliance, the door if so equipped, shall be open.
2. Turn the appliance manual gas shut-off valve to the OFF position.
3. Turn the combination gas control knob to the OFF position.
4. Turn the thermostat control to the OFF position.
5. Wait 5 minutes.
6. Turn the appliance manual gas shut-off valve to the ON position.
7. Turn the combination gas control knob to the PILOT position.
8. Light the pilot with a match while depressing and holding the combination gas control knob until the pilot remains
lit upon releasing the gas control knob.
9. Turn the combination gas control knob to the ON position.
10. Turn the thermostat control knob to the desired temperature to turn burners ON.
11. Ensure that the door is closed during operation.
12. For complete shut-down, repeat steps 2, 3, and 4.
It won't turn any further until the pilot is lit and stays lit.
Jun 14, 2014 | Kitchen Appliances - Others
Oven pilot will not stay lit
Strange to hear about a pilot-flame. Is it an old oven? Commercial unit? Look for a small valve at the end of the pilot gas-line and see if it is shut off. If it's on, okay. But, is gas getting there being blocked elsewhere? There may be a flame safety-switch, a sensor by the pilot, or some other thing that has a release button for lighting the pilot. You hold it in until the sensor heats up, and then it will stay lit. After that, there may be a re-set button to get gas to the main burner element. Basically, you have to trace lines back until you find the hindrance. CAUTION:With all gas appliances, you have severe danger of causing an explosion, and untimely death, or injury, so if you have any doubts, get a qualified guy on it! (It takes a while to grow a beard back, too.)
Jan 05, 2014 | Garland Ovens
The pilot light is not on how do I switch it back on?
Turn the gas valve off all the way, make sure you don't smell gas and wait an hour or so. The gas valve should have an on setting and a pilot light setting. Turn the gas valve to pilot light and you should be able to push the vlv button down. At this time hold a flame to the pilot light outlet. It should light and when it does keep holding the vlv down for about 15-30 seconds. IF you let off of the vlv and the pilot light goes out, you may have a faulty sensor. IF it stays lit when you let off the vlv. back your face away from the unit and turn the valve to the on position. Operate the cooker as usual making sure that the burner does indeed light when called for. If the pilot light will not stay lit, make sure the sensor is enveloped in the flame. If the flame is too small you may have to change or clean the pilot flame outlet. To replace the sensor, remove it from the mount by the pilot outlet(once it has cooled) then follow it back to the control valve and remove it useing a line wrench. YOu should be able to get one at the nearest hardware store.
Aug 23, 2012 | Cars & Trucks
How to I start my heater
If it is this heater, then you must:
1- turn the toggle switch to the ON position.
2- Turn the gas valve dial to the PILOT position.
3- Depress the pilot button while pressing the ignitor until you see a flame. Continue to depress the pilot dial for about 30-60 seconds.
4- let go of the button, and the pilot flame should stay lit. If it does , then turn the gas valve dial to the ON position.
5- Set the temperature and your done.
Apr 27, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Im calling for heat from the thermastat and control panel, the boiler light and and the fan is running, but no matter how many times i keep re trying the pilot and burner will not commence, is there...
I would check to make sure control on gas valve is in on position and pilot is lit if you have a standing pilot. If you have a spark or hot surface ignitor make sure they are trying to lit pilot. If you have standing pilot model and pilot lit is not on. Turn control on gas valve to off,wait five mins. then turn to pilot. Depress botton and try to light pilot. If it lights hold down for a couple of mins. then release.. If pilot stays lit turn control to on. If thermostat is calling for heat this should bring main burner on. If pilot does not stay lit then replace thermocouple. Hope this helps. Thanks
Nov 16, 2010 | Heating & Cooling
How to light the pilot on a dearborn room heater
Turn the knob to PILOT. press the knob down. Light the pilot and hold the knob till the pilot stays lit by itself. Then advance the knob to the ON position. Turn up the thermostat.
Jan 02, 2010 | Heating & Cooling
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
I need help relighting the pilot light on my Marco mfg gas fireplace-model # 794015c
First, turn the wall switch to the off position. Second, turn the key all the way tcountercockwise to the open position. At the front of the unit, below the hearth opening there is a black front access panel. Should have a little recessed part. pull it out and expose the gas valve. Turn the plunger/knob that says off, on, pilot to the pilot position. You'll knw your in the pilot position when it lines up with the indicator (usually a red or black mark on the gas valve body). If you are in the pilot position, you will be able to push in the pilot (it will feel springy). Push the plunger in and then push the red button (piezo ignition button) in until it makes a snapping sound. You may have to do this several times because the air has to bleed out from the pilot tubing. This should light the pilot BUT wait. DO NOT LET GO OF THE PLUNGER ONCE THE PILOT IS LIT. You need to keep the plunger depressed for about 30 seconds and then let it go. After 30 seconds let the plunger go and verify the pilot is lit. If not try the last step over. After the pilot is lit, you may turn the plunger/knob to the on position. Now go back to the wall switch and flip it on. If it doesn't come on tap it hard. Sometimes dust can actually prevent it from making good connection. I work on fireplaces for a living and coincidentally worked on this model today. Simple as pie.
Dec 28, 2008 | Heating & Cooling
Pilot ligting instructions
many of the newer furnaces don't have a standing pilot. look to see if you have a gas valve with a knob on top that says off pilot and on. look to see if a tube the size of a pencil comes out of the valve and goes down by one of the burners, look to see if there is a little gold piece of metal tubing protruding down to the opening of the larger tube . that is where you place the match. i prefer to use a grill lighter. safer and positive flame. turn knob to off wait 5 minutes for any gas to disipate. be sure your incoming gas valves are all open . usually at the meter and one at the furnace. usually the handle is in line with the pipe when open. from the off position, turn the knob on the furnace gas valve to pilot position and push down on it as you turn. this lets gas flow to the pilot tube by the burner where you have you flame starter lit and waiting. once pilot lights hold down on button for 3 minutes or less. longer is better to be sure the thermocouple senses flame . then gently release the downward pressure and the pilot should stay lit and you gently turn knob to on. if pilot goes out you may have a bad thermocouple. be especially careful if its lp or propane as that gas does not disipate like natural gas and can virtually lay on the floor till ignited. also consider having the heat exchanger checked by a pro with a carbon monoxide detector. they do crack after a few years and can be deadly when they do. good luck
Nov 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
66 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
