Question about Xantrex Technology Statpower Prosine 1800 Hardwire Transfer
Power save feature on prosine 1800w inverter
When I turn inverter on I get a message on the remote display that reads "power save off" and then very soon after I get beeps, and it reads "system shutdown". All elec units are off and batteries are fully charged. Any ideas please?
I've got exactly the same problem, same inverter, am told its an internal hardware problem, if you was able to fix yours could you let me know how? any advice greatley appreaciated,
cheers, Rob lordrobertj@gmail.com
Posted on Oct 11, 2010
My Prosine 2.0 display panel displays Panel Fault: Memory error and the display error as well as all lleds are off. The unit looks as if it has no power to it. I reset (power off.power on) the prosine and...
This is a know and widespread problem with the Prosine 2.0, yet when you call Xantrex, they want to charge you to return, repair and/or replace the remote panel. Shame on you Xantrex.
Sep 06, 2010 | Xantrex Technology 806-1800 Prosine...
Where can I buy or get a Prosine 2.0 remote repaired ?
Nowhere (if not under warranty for replacement). They are a known problem. Prosine inverters are almost impossible to repair (Even one of their local authorized repair shops said even they could not do repairs on the Prosine although it was relatively easy on other models.) Have to order the display from Xantrex directly and they don't have many left. from
Mar 25, 2010 | Xantrex Technology Statpower Prosine 2.0...
Xantrex Prosine 1800i "DCDC Shutdown" when connecting AC Load
Hi Schnupfy,
Well, it may be advertised as 1800 watts, but that is a peak. While the 230 VAC may be dead on target, don't expect it to run a mig welder.
Sustained high output is totally dependent upon the power source. What it's doing is protecting itself. DCDC Shutdown indicated 'An overload or system Fault'
Possible problems that would cause this:
  • The load is too high (what is the load?)
  • The power source is intermittent or weak
  • The power source is run through a distribution panel or isolator (Voltage drop)
  • The wiring from the 12VDC source is too long for the gauge used
Click here for a PDF copy of the manual. It is quite well documented.
BEST REGARDS,
MIKE
Dec 18, 2009 | Xantrex Technology Xantrex Xantrex Prosine...
My prosine 2.5 charger inverter intermittent
First try blowing it out the unit with compressed air to see if there is large amounts of accumulated dirt inside, look for black soot on the center of the air outlet side.
Intermittent problems are the hardest to troubleshoot.
If you need more help contact me at sunyout@gmail.com
Thanks.
Sep 14, 2009 | Xantrex Technology XANTREX PROSINE 1800...
Prosine 2.5 fault 195
This internal fault code can mean so many things, but basically it more than likely has some internal parts that the smoke is no longer inside. They can be repaired however, email sunyout@gmail.com to discuss further.
Thanks, Bob
Oct 20, 2008 | Inverter Electronics - Others
Xantrex Technology Statpower Prosine 1800 Hardwire Transfer Logo
257 people viewed this question
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
