Question about Seiko Mantel Clock
How to set chimes to coordinate with time? - Seiko Mantel Clock
  • 2,113 Answers
If there is a slight error between the two move the hands back or forwards to meet the correct time (if possible)
Posted on Nov 28, 2013
How do I make my clock chime the correct number of times?
whenever the battery is weak the chime changes....whenever you change battery the clock chimes to the last time it chimed so...try setting your clock to next hour of chime n then move the hands of clock to next hour n your clock will chime accordingly.....
in this way waiting for chime to finish ...set to clock to present time ....waiting for it to chime every time the minute hand passes 12
Dec 09, 2015 | Home
My Gazo GF Clock won't chime on hour at all
When you are setting your clock, when you go pass the hour you have to let the clock chime completely, if you do not do this you can damage the time sequence..You have to reset the chime cable or belt...but anytime you set your clock when you get to hour let it chime completely before continuing on...Try also going around with hour hand onetime and let it chime, if it will chime at all, if not you can get a manual download online. Clocks like yours has websites and support who can help you...I think it just needs the chimes reset.
Dec 17, 2014 | Home
How do set the chimes after changing the batteries
Move the hand to set time, but make sure to stop on every hour and let the clock chime the hour completely before moving to the next hour. That will set the time and sync your time with your chimes.
Nov 08, 2014 | Home
Can gps coordinates be used with TomTom go live 750
If you mean, can you enter latitude and longitude coordinates on your GO 750 LIVE GPS device .... yes.
First you'll want to set your unit to accept coordinates. From the main menu, tap Change Preference, then select "Set Units" and select a Latitude and Longitude format in the "Coordinate display" screen, and then tap Done.
To navigate to a location using latitude and longitude coordinates, follow the steps below:
  1. From the Main menu, tap Navigate to...
  2. Tap Latitude Longitude.
  3. Enter the coordinates and tap OK.
May 09, 2013 | Tomtom GO 750 LIVE GPS Receiver
The chime of my Howard Miller mantle clock are not w/the actual hour set.How can I reset the chimes? Daylight Savings time has messed me up.
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Nov 06, 2011 | Seiko Mantel Clock
Magellan explorist 100 is 2 hours out on time and I don't know how to reset it.
Go to Preferences and select Restart GPS. Then select Enter Coordinates and set your local time (no need to change coordinates so just press enter till you get to the time field). Hit Escape and now the time should be correct.
Jan 01, 2011 | Magellan eXplorist 100 GPS Receiver
Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
May 18, 2010 | Seiko Mantel Clock
I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMINSTER LINDEN MANTEL CHIME CLOCK
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Apr 05, 2010 | Seiko Mantel Clock
Whitting and Westminster Jean luis Electronic clock
I found my own solution through trial and error. I set the dials to 12 00 and then move the dials to show just over 5 minuites to 12 ( 1155) the alarm melody start and chimes for a number ( in may case it was one.) then i moved the dial back to 1200 and then reset it again to 1155 or just over. Each time the alarm chimes an increasing number
I had the clock chime settings on the back of the clock to the middle setting (chimes on 24 hours)
I carried out this until the chime was right for the time i was working ( in my case it was 1730) so when it reached 5 chines I then set proper time and left it. The next chime was correct
Jan 09, 2009 | Seiko Mantel Clock
Home Logo
60 people viewed this question
Top Seiko Home Experts
k24674
Jimmy Accardi
Are you a Seiko Home Expert? Answer questions, earn points and help others
