Question about Xerox Phaser 8500N Printer
Taking out the toner
The ink is running low on our printer, a black toner cartridge has been added into number 4 but there are now 3 toners in the 'tube' how do I take these out?
    Novelist:
  • 208 Answers
Run a screw into the ink stick and slowly slide it up and out.
Posted on Dec 04, 2007
SOURCE:
If one of the cartridges is low should it still print
if you need to replace the printer, i would suggest to buy compatible toner, you will save some money doing this. the technology for compatible toner has improved greatly in recent years, you should have no problem using it. i usually buy my ink toner from this website:
Brother Toners Inks Cartridges or
Amazon com Online Shopping for Electronics Apparel Computers Books DVDs... if they have something with prime. Watch this video
it might help you print with empty cartridge :)
Jun 18, 2014 | Brother HL3040CN Laser Printer
Hi i cannot print any documents ive typed with words or school information it keeps saying STATUS:TONER LOW ??
Based upon your question, which is a bit vague, you must have a laser printer. What the printer is telling you is it has insufficient toner (some incorrectly mis-state "toner" with "ink". Laser printer = Toner. Inkjet printer = ink) for the print job to occur. If you have a laser printer which prints in only black (black and white), then you can try this:
Black only: Open the toner access panel on your printer, remove the toner cartridge (it will easily pull out), and GENTLY shake the toner cartridge from side-to-side . What you're doing is allowing toner (ink?? It's more of a powder-like substance which consists of ground-up plastic) to shake evenly to the bottom of the cartridge. Then, put it back in. IMPORTANT: This will not work for long. You need to get a new toner cartridge soon!
Color: If you have a laser printer which can print in color (based upon your description, it sounds like this is NOT the case. If you have a color laser printer, it would display to you that a particular color is out of toner), then do the same thing as described above... but for EACH toner cartridge.
It still doesn't work: If this does not work, then you're out of toner (Ink... sigh). You MUST replace your toner cartridge which is out of toner. If there was another way to do it, I would tell you. When you're out, you're out.
Please let me know if you have any further questions by doing a REPLY to this answer. I'll be happy to help!
Oct 01, 2011 | Office Equipment & Supplies
I have a Toshiba Dp85F Fax machine and need to replace the toner cartridge...I do not know what model number I need to replace it with. Please advise
Ink, Toner & Accessories for DP-85F Printers, Copiers & Faxes Select from the list below Compatible or Original ink and toner cartridges that work with your DP-85F.
TOSHIBA TK-18 Compatible Black Laser Cartridge, TK-18
  • - Condition: Compatible
  • - Page Yield: 6000
  • - Color: Black
  • - Printer Technology: Laser Cartridge
  • - Item Number: TK18-70
- OEM Part#: TK-18, TK18
Item #: TK18-70
MSRP: $114.99
Price: $38.99
Toshiba DK-18 DP-80/DP-85 Drum Unit
  • - Page Yield: 20000
  • - Color: Black item-color-black.gif
  • - Printer Technology: Drum Unit
  • - Item Number: DK18-70
- OEM Part#: DK18, DK-18
Item #: DK18-70
MSRP: $114.99
Price: $39.99
Toshiba DP85F Toner Cartridge, Black
Toshiba TK18 Toner Cartridge, Toshiba TK-18 Fax Toner
$73.59
Nov 29, 2010 | Toshiba DP-85F Fax
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Toner is not out of ink but it lights up, refusing to print
In most cases cartridges have a special chip that remembers the toner cartridge serial number an amount of pages printed from it. This means, that even though there still might be some toner left in the cartridge, the chip's counter reaches it's predefined limit and informs printer, that the toner has run out. Just like that, suddenly.
It may also be the case, that the chip loses contact with the printer's electrical terminals - try reseating the cartridge in the printer. If that doesn't help, it's time to replace it I'm afraid.
Usually the printer will inform "toner low" for some time before it becomes "toner out" and refuses to print. If you get "toner low", then it's time to purchase a new cartridge to have it ready.
Oct 27, 2009 | Fujitsu Office Equipment & Supplies
What colour is K on low ink
Toner K low refers to the black toner.
May 15, 2009 | Epson Aculaser C1100 Printer
Printer
You will need to manually reset the toner cartridge.
If the Toner Low or Toner Empty message does not automatically clear after a new cartridge is installed, do the following to clear the message manually:
  1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
  2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
  3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
  4. Press ENTER. The operator panel will display [YES].
  5. Press ENTER. The toner warning message should be gone.
  6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
  7. If problem persists, there may actually be a problem with either the toner cartridge or the SCX-4216F.
Jul 14, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Xerox Phaser 8500N Printer Logo
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
