VIZIO M470VSE VIZIO LIGHT ON BOTTOM COMES ON OR IT FREEZES ON START UP PLEASE HELP!!
2 Suggested Answers
  • 19 Answers
SOURCE: my vizio wont turn on but the vizio organge light
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. Hope this works for you.
Posted on Apr 03, 2010
Removing the back of my Vizio flat screen model M470vse
If you wish to get some details; check the site linked here. Pull up older posts.
Disassemble procedure to many popular devices are given with illustrations.
Sep 22, 2016 | Vizio Televison & Video
My Visio tv model #m470vse won't play at all it comes on shows a symbol and go blank
See this :
Free Vizio Flat Panel Television User Manuals ...
tv.manualsonline.com > ... > Vizio > TV and Video Vizio
Products 1 - 50 of 490 - Vizio Flat Panel Television E SERIES. Vizio HDTV User Manual. Pages: 0 Saves: 0. See Prices Buy or Upgrade ...
Sep 25, 2015 | Televison & Video
How to fix vizio tv
The backlight is LED and not likely to fail, it is most likely the main, modular power supply causing the problem.
Look inside for a block assembly with larger components and several connectors that is bolted onto a larger panel.
These are purchased from other sources, not made by Vizio.
Look into the guts of this assembly for cylindrical components with plastic foil and an aluminum top, mostly mounted vertical to the board.
Examine the tops of these for any dome-like appearance; this is a sign of failure since these should be flat.
They are inexpensive (one reason they fail) and this failure can be prevented by spending another dollar or two in the manufacture of them.
Replacements can be had but unless a couple of parts are added (by the maker or a smart tech) the same failure will eventually occur.
Dec 26, 2014 | Vizio M470VSE 47" LED TV 1920x1080, 120...
My son spilled milk on the top of the case on the TV. There is now a black line that run straight from top to bottom that is very thin but noticeable. Do you guys think something has burned out? Can it be...
There is a flat ribbon cable that goes from a connecttor on the bottom edge of the screen on the back of the TV(with back cover removed) To a board on the TV. Milk probably got in the connector. The flat cable can be removed from the bottom connector and cleaned with a damp cloth. Put a tissue or paper towel in the connector to dry out the contacts. Reassemble everything and check the picture. If it's ok then close up the case on the tv. If it doesn't change then components on the board the flat cable connects to are bad and the board has to be replaced.
Oct 01, 2014 | Vizio M470VSE 47" LED TV 1920x1080, 120...
Why won't Vizio Tv come on?
Most likely it's a capacitor fault.
Google "Capacitor bulge" and then search Youtube for your make and model to see if anyone has done an instructional video. You'll need to be comfortable dismantling the unit and be able to use a soldering iron. If this isn't you then take it to a repair shop.
Sep 16, 2014 | Vizio M470VSE 47" LED TV 1920x1080, 120...
Need help connecting a funai dv220fx4 to a vizio m470vse?
Sounds to me like you got the component leads correct but not the composite (video).
See in the link for downloading the manual :-)
Funai 50 years of Excellence in Consumer Electronics
Apr 23, 2014 | Vizio L37 Television
If you have a scart socket on the TV it would be much easier to use this
Sep 12, 2017 | Vizio L37 Television
My vizio remote wont stay in place when i go to settings
I had same issue and it turned out that the actual channel down button on the side of the TV itself was stuck. Popped it out with a knife (IKR) and that fixed the issue. Works fine now
Feb 06, 2014 | Vizio Remote Control M470VSE p/n:XRT302
Need to program xrt302 to operate vf552xvt
ic onida sltone02 r2j101/2ha-a97fb 929z01 sarvice cod
Sep 22, 2013 | Vizio Remote Control M470VSE p/n:XRT302
Televison & Video Logo
294 people viewed this question
Top Televison & Video Experts
