Cant get the software to installe
I plug the mp3 pearl into the usb port and the software is suppost to pop up to start installation and it doesnt. so i go to the my computer area and i cant find the drive letter associated with the player
  • tbock86
    tbock86 May 11, 2010
    Is this unit powered on when you attempt this. Did it come with a CD?
    Problem Solver:
  • 12 Answers
It sounds like either the USB cable itself is bad or the USB port is bad. Try the USB cable in all the other USB ports on the computer. If it still does not work, try a USB mouse and see if it works. If it does then there is a problem with the USB cable provided with the MP3 Player. If the mouse does not work, then there is a problem with the USB ports on your computer. My assumption is that it is a bad cable.
Regards,
Mike
Posted on May 09, 2009
Rca pearl th1602-a I turn it on all I get is the pearl emblem and it wont turn off. I have to pull the battery to stop.
My solution to a Pearl TH1602-A stuck on the pearl screen:
Download the firmware upgrade from RCA's website, run it.
RCA PEARL FIRMWARE DOWNLOAD window should open.
Remove battery from Pearl, keep out.
Press PLAY and hold while plugging into USB port,
when "initializing" progress bar moves, let go off play button.
On my windows, it installed some software and asked me to reboot. After the reboot I re-ran the Pearl firmware file and about 30 seconds later the start button was now available.
Click it. However, You will loose your music on the internal storage.
Oct 07, 2009 | Audio Players & Recorders
Has a code 10
one way is to try a different port
The other way to solve a USB error code 10 in A. Click on Start
B. Right Click on My Computer, click on Properties
C.Click on the Hardware tab
D. Click the Device Manager button.
E. Expand Universal Serial Bus controllers section.
F. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
G. Restart the computer, and allow the computer to reinstall the USB controllers.
H. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
You may want to do this in safe mode as well.
Sep 13, 2009 | RCA Pearl TH1102 MP3 Player
My computer doesnt recognize my sansa express and it used to
check usb cable and make sure that the cable is connected properly .
Try connect to other usb port .
Hope it helps
Jul 17, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
RCA pearl 1602-A won't register when plugged into USB port.
When my computer wouldn't recognize my Pearl, these are the steps I followed after downloading the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1
remove the battery,
start the program,
hold the play button while plugging into usb,
release the play button when the term "initializing" replaces "searching",
click the start button to replace the firmware.
You might want to try leaving the "format data" box unchecked the first time. If that doesn't work and allow you to backup your music, bite the bullet and format the data area.
After I did this, my pearl started normally, and my computer recognized it again. It also fixed my aac-error problem.
Jul 02, 2009 | RCA TH1602 MP3 Player
My pearl th1602 is froze
Remove battery, press and hold "Play" button when inserting into USB port. Run the firmware update and should be able to re-initialize the device, start the update with the "Format" option checked. Worked for me.
Feb 24, 2009 | RCA Pearl TH1102 MP3 Player
PC won't recognize
Either 1) the USB port on the laptop is not a USB 2.0 port, and therefore is too weak to power the mp3 player
or
2) The hold/lock switch is engaged
or
3) you plugged it in without installing the installation software
Jan 14, 2009 | RCA Pearl TH1102 MP3 Player
TH1602-A
I had decided to reload the firmware. Initially this did not work as the device could not be found. I then found a mention that if you reset the device and then as you plug it into the USB port hold the Play button in... you should see it find new hardware (ROM initialzing). After this I had to reboot. It still wouldn't start but now I was able to load the firmware and it came up fine after this. This method does format the drive so everything is lost (not even the initial software was on it).
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=2557
Nov 16, 2008 | RCA TH1602 MP3 Player
RCA Pearl TH1602 Frozen?
I had the same problem, usually plugging it into the usb port on the pc and verifying the files on the player, then disconnecting the player will solve the problem. Other times i have to reformat the player, if you do that, you will have to put all your music back on. It's a pain, this has happened to me 4 times, I've only had this thing less than 6 months! It was inexpensive, I guess you get what you pay for, but I like having a AAA battery instead of having to remember to plug it in to the pc to recharge every 15 hrs.
Oct 17, 2008 | Teac MP-111 MP3 Player
RCA PEARL MP3 Player
mine is doing the same, i updated the driver and it still is not working.
Sep 23, 2008 | RCA TH1101 MP3 Player
RCA PEARL
First, make sure that your OS is compatible - if you have Vista, you must go to RCA's website and get a new version of the software.
If you have XP:
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard
Jun 30, 2008 | SanDisk Sansa e260 MP3 Player
90 people viewed this question
 Grubhead
Grubhead
