Question about Toshiba 32BV502B 32 in. LCD HDTV
Tv wont turn on but theres sound
The tv power is connected, is off a s far as i know. When i touch the on button, there's a sound but no other response from the tv, no lights or screen flashes
    Top Expert:
  • Toshiba Master
  • 74,251 Answers
Check and replace its backlight inverter board. To get more details, http://electronicshelponline.blogspot.com/
Posted on Nov 29, 2013
4 Suggested Answers
SOURCE: Toshiba 42HP95 Plasma tv
toshiba plasma 42hp95 tv will not turn on red led lights blinking
Posted on Feb 23, 2009
  • 4090 Answers
SOURCE: Flashing power button tv won't turn on
yes call the tech and have the power board replaced. In future have the TV plugged into an anti surge board to protect it ( and you from expensive repair.) I suspect you will need a new power supply fitted
Please rate the help to keep us online
Posted on Aug 17, 2009
tvservice306
  • 458 Answers
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Posted on Oct 02, 2009
My dynex tv wont turn on! the strom knocked out our power, now the power is back on the tv wont turn on from remote or tv power button.
Lightning is a weird beast, and can do strange things to a TV. Sounds like the set took a hit. If there is a fuse then check it on a volt-ohm meter for continuity while it is out of the circuit, and if it is an open circuit, replace it. If there is a circuit breaker, then reset it. If these don't work, look for obvious scorching on the circuit board (assuming you know how to avoid electricution, otherwise do not touch). Lightening can literally jump around on a circuit board, so there is no way to know what part of the set was effected by the strike - the lightening will not always burn out the first circuit it touches, but will burn out something further into the circuit. The most obvious place to look is around the transformer and rectifier circuits. If a capacitor was hit, it may be swolen or discolored; resistors will scorch, and the worst thing is that transistors and IC's often show no damage - in fact, any part might be burned out and not show visible signs. If nothing is obvious (like scorch marks) and the fusing is intact, there are too many possibilities to begin listing them all. The fact that it won't turn on at all sounds like it is probably a power circuit, but, not necessarily. FYI turning a set off during a lightning storm does not protect it, you have to unplug the AC power cord and the line that feeds the signal into the set. Even circuit protection devices (lightning arrestors) may not protect against a close strike. Maybe the techs at Best Buy can supply more suggestions (Dynex is their brand).
Aug 29, 2011 | Dynex DX-L42-10A 42 in. LCD TV
Wont turn on just flashes.wont turn off just flashes...Is there a reset button??All of a sudden it just stopped and started flashing no warning.
First try to turn off PC by holding power button for more than 5 seconds. Make sure first that your PC is clean inside and CPU is properly connected to motherboard (before you touch inside your PC touch some metal to discharge electrostatic). If it needs cleaning use canned air and paintbrush. Check how memory is connected. Check the Power Supply voltage, if it's ok, first turn PC off,then you can check power button by disconnecting ATX 20 or 24 pin power connector from motherboard and connect paperclip edges to any green to black wires it has to power on your PC. If it's still flashes it's more likely PSU or motherboard issue.
Jan 15, 2010 | HP OfficeMax - CPQ SR1638 NX-B Desktop....
Password protected and wont power up and cant connect to itunes
here's how:
1. Turn on your iPod (in my case it would only get as far as displaying the Apple logo
2. Hold the power and home buttons down (the iPod will power off after 10 seconds, but keep holding those buttons down)
3. After the iPod powers off, release the power button (but keep holding the home button down)
4. After a couple more seconds, you should hear that magical “ding dong” that means the iPod is coming back alive, and that Windows has detected it. You may even see a little “New hardware” popup in Windows. It is now safe to release the home button, and your iPod is in DFU mode.
5. Now iTunes will see it as a DFU’ed iPod and should ask you to automatically restore its firmware.
6. iTunes has to download the new firmware, and it takes a while, so go make a sandwich.
Jul 25, 2009 | Apple iPod touch
Can't program emerson tv control volume or to turn it off.used all codes.not working.all other controls work. Thanks,ladybrd
If this is a new Emerson flat panel lcd tv from Walmart, there is a chance that the remote just wont work. I've had problems with these Emerson's often with all dish network remotes. you can try doing a search on the remote itself though. Turn your tv on manually, then push the tv button on the remote and hold it until it flashes, then hit the tv power button on the remote, then push the up arrow button continuously (not to fast though) until the tv turns off and then push the # button (below the 9 button) and the remote should work. There are some new tvs' that these remotes just wont program. I hope yours works.
Jul 22, 2009 | DISH Network IR Remote Control
Touch screen mp4 player wont turn on.
How about when it's connected to the computer or mains? If it powers when it is but not once you disconnect, then the battery is dead and needs replacing. This is soldered onto the main board so needs to be done by a competent person but is fairly inexpensive.
If it doesn't power up when you connect to a PC or mains then it is a connection problem (check the cable, iPod and USB sockets) or a logic board problem.
I hope it is something simple for you. Otherwise I would find an iPod repair specialist near you (I'm too far away).
All the best
Sean
PiDigital
Dec 16, 2008 | Apple iPod touch
Tv wont turn off or change chanells,sound up or down with remote or the side of tv
check the power supply and HOT if good ,re solder your tv maybe there's a lose connection
Sep 10, 2008 | Samsung DLP HL-P5663W 56" TV
Picture on tv isn't appearing and controller not connecting
The only easy fix i know is to turn the console off and then press the power button until you hear a second beep. Hope this helps.
Mar 15, 2008 | Sony Playstation 3 (PS3) Console
Tv wont turn on
same "standby light" problem, with TV not turning on.
Jan 13, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Help
open it up then plug it in. when you press the power button see if one of the large white boxes (there are six in a row) lights up red.
Sep 29, 2006 | RCA RT2360 System
Toshiba 32BV502B 32 in. LCD HDTV Logo
21 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
