Model capf3636c6aa I have a Goodman capf3636c6aa, The heater stopped working and when I look at the window in the bottom door, the red indicator light blinks three times.
  • 10 Answers
SOURCE: garage door indicator light blinks 5 times
this probably means you have a bad photo eye if you happen to have to doors side by side may be picking up on other sides photo eye just switch sides from left to right, however if the lights are coming on but does not mean that photo eye is not bad it has a small circuit board inside of it...
Posted on Apr 05, 2009
welcomejee
  • 10594 Answers
SOURCE: red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
Posted on May 13, 2009
  • 148 Answers
SOURCE: RED BLINKING (6TIMES) ON FURNACE
THE ROLL OUT SWITCH IS LOCATED IN THE BURNER COMPARTMENT MOST CAN BE RESET
Posted on Jul 20, 2009
SD Tech
  • 14553 Answers
SOURCE: Sony xl 5200 door close safety switch
not sure if this helps---some of these sets had a problem---the three blinks usually means door not closed properly--remove door and look carefully at it--if it is warped from the heat---the plastic peg on the back of it will not engage the lever(it is a safety switch that prevents the set from working if the door is removed) look behind the door where the plastic peg is--if it is your problem you just have to use something not metal to move the lever and then while in place turn the set on---if it comes on normal--order a new door---they are about 5 dollars plus shipping--if you need direct help email me with the exact model number--if this has been helpful give me a vote------
etower.766@netzero.net
Posted on Aug 13, 2009
  • 534 Answers
SOURCE: Red light blinking three times in a row
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
Posted on Aug 21, 2009
Solid red light on a goodman furnace but unit works ok
Sounds like you have no problem. A continious light might just mean "normal operation" check the diagnostic chart on the door.
Jan 11, 2014 | Goodman Heating & Cooling
CAPF3636C6AA where do I put the filter?
This model numbers associated with this post are for a heat pump system. Usually the filter is not located in these units but is located in the bottom of the air handler or furnace box. if it is not there then look either in the metal duct next to the air handler box or in the return grills in the living area of the home. I hope this helps:)
Oct 02, 2013 | Goodman CPLE24-1 Air Conditioner
I have a janitrol gmp050-3 and when the heat turns on, the vent blower comes on, however the burners are not igniting. i thought that perhaps the gas valve might need to be replaced. any suggestions?
After the vent motor comes on does the glow plug ignite. If it doesn't ignite it is either the glow plug or the
pressure switches are opening up. Can you take top door off, whether ignitor light or not, you should be able to hear gas going in for a few seconds. If can't hear gas, probably pressure switch.
There is a small glass window in bottom door. Can you look through there and see blinking red light, normally look up inside to see light. Is a code list inside lower door.
Jan 24, 2011 | Goodman GMS90703BXA Heater
Goodman furnace model # GMNT100-4B On vacation neighbor checked house house filled with gas. He shut off main and furnace. Came home turned on gas to everything except furnace. All good. Furnace will not...
from my experience with goodman units ,it could have been a gas supply problem there are so many protective sensors that i dont think it is the unit by the way is it electronic ignitor or pilot
May 14, 2010 | Goodman GMS90703BXA Heater
Goodman furnace model # GMNT100-4B On vacation, neighbor checked house, house filled with gas. He shut off main and furnace. came home turned on gas to everything except furnace. All good. Furnace will...
Solid red typically means bad controller. Try unplugging the furnace, wait about 30 secs, then plug it back in. The possibility that the controller was sending voltage to the valve even when there was no flame is a bad sign. If the controller starts the furnace, watch it very closely and see what it does. If the solid light comes back on, it's time for a new board.
Mar 24, 2010 | Goodman GMS90703BXA Heater
Indication light "RED" on continuously during operation. Unit fires up, heats up and blows hot air. Why is LED "RED" on when unit shuts down?
not knowing wich one is on, this red light could be your power indicator light..
it stays on during any operation,
you should be able to see it through the sight glass
if it were flashing,,,, there would be a problem
Oct 13, 2009 | Goodman GMS90703BXA Heater
Jul 20, 2009 | Goodman GMS90703BXA Heater
Goodman gmp050-03 heater
Either yourself or a Heating specialist will have to replace the gas valve.. Once installed you will plug unit back in which will reset power board and should work fine
Dec 23, 2008 | Goodman GDS80904BNA Open Flame Heater
AIR or Heat wont come on/ goodman GMP075-3
If there is no blinking light, then the unit is not seeing a call for heat or cool. My guess is a lose or broken wire in the thermostat circuit. Try and putting a jumper across the red and white heat terminals inside the furnace and manually closing the door switch. If you get heat, it's telling you there is a wiring issue. If you get nothing, it's a bad circuit board.
Jun 08, 2008 | Goodman GMS90703BXA Heater
Goodman Furnace m/n GKS90453BKAC
A constant red light (not blinking) indicates that the thermostat is not calling for heat. Of course you know it is but just to be safe, jump out R and W on the board. If it continues to do the same as you indicated, replace the board.
Dec 05, 2007 | Goodman GMS90703BXA Heater
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
