Question about Beverage-Air MT27 Beverage Cooler Commercial
I need to know where all the terminal connection go since i don't have the manual
I have a 20 year old electric dryer that normally works great. All at once the dryer stopped heating, but otherwise works normally. I took the dryer apart, checked continuity of the heat coil, hi limit...
The problem is the terminal block, Vibration with the cord not being fastened to the block tight enough caused overheating at the block and it failed. Replace it.
Jul 19, 2013 | Dryers
Want to know how to install a d frost o matic model 8145
1) Copy following links for defrost timer resources, explanation, manual, general description and illustrations:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
http://waterheatertimer.org/images/8145-20-wiring-600.jpg
2) Generally:
Power wires connect to terminals 1 and N.
Heater turns ON during defrost cycle, so heater connects to NO terminal 3, and to terminal N
Refrigeration fan motor is OFF during defrost cycle, and ON during refrigeration cycle, so it connects to terminal 4, and to terminal N.
Limit switch, which is the pressure or temperature sensor, connects to to terminal X and to terminal N. When defrost cycle pressure or temperature reaches set point, the limit switch activates, and this causes 8145 timer to reset, and then defrost cycle ends.
Jan 30, 2013 | Hardware & Accessories
I need to know how to hoop up my wireless connection for Panasonic Blue Ray
you don't hook it up directly with the wireless internet connection, you hook it up with the machine you will be viewing it with (i assume it doesn't have a viewing screen). Hook it up with your tv or computer. Match color coded terminals.
Sep 02, 2012 | Computers & Internet
Need help installing a Hunter 44277 thermostat. Instruction manual here: http://www.hunterfan.com/Support/Manuals-and-Parts-Guides/ Wires I have are as follows: Blue: C Black: E White: W2 Yellow:...
Your wires Hunter thermostat
Blue C
White E
Black E
Yellow Y
Orange O
Red R
Green G
Since i don't know what brand heat pump you have, i am assuming you have a cool active reversing valve, therefore the orange wire will connect to the "O" terminal. If you have a heat active reversing valve the orange wire would be connected to the "B" terminal. You will know it is wrong when you turn on the system in cooling mode and it blows hot or warm air. Another way to know quickly is to go out to your outside unit when you turn it on in the cooling mode and feel of the suction line(the large copper line coming out of your condensing unit) and see if it is cool. If it is, great. If it is hot then you would have to switch the orange wire to the "B" terminal.
Hope this helps.
Sep 04, 2011 | Heating & Cooling
I have a intrermatic r8816p101c that some one removed need to put new one back dont know how i have 2 red wires coming from pump and to red wires coming of the wall witch has a on and off switch how do i...
You have Intermatic 240Volt sprinkler timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8816p101c%20-%20english.ashx
Timer relay has 4 wiring terminals: from left to right 1 2 3 4
Red wires from switch connect to terminals 1 and 3
Red wires to pump connect to terminals 2 and 4
Since circuit is 240Volt, red wires from switch can be connected in either order. Same with pump.
Rain sensor terminals don't have any wires, unless you but separate rain sensor.
Parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Aug 10, 2011 | Intermatic Hardware & Accessories
Hello Fixya.have a rfrigeretor Vestel (made in turkey). the terminal box (conected to the compressor) have been damage. need to know how to reconect again the wires to the plugs on the terminal. i'm...
The terminals of the compressor could have burnt and so depending on how the connections are damaged the points could be soldered or connected.
First of all clean the terminals properly , use a emery paper to clean the existng terminal part or the wires to the motor. Now use good wires to solder and connect to a ceramic terminal to which the wiring can be given.
make sure that the connections are insulated before the fridge is powered.
Tip:
Use good cleaning solution to wipe all dirt. Buy ceramic connection strip from any electrical store if the terminals are damaged.
Use a good soldering iron to connect the wires to the terminal.
The wires to the motor must be then connected to the terminal strip and strapped using a wire tie.
Jul 25, 2011 | Refrigerators
I have a wurlitzer cd-carnegie jukebox and want to know can and how to add extra speakers ?
Speakers are connected to the output transformer assembly. It is a unit with two transformers and many screw terminals. There is a big red L on one transformer and a big red R on the other. If you don't have a manual, I can email you the connection diagram for the output transformer assembly. Please email me, tech@wurlitzer-ohio.com.
Dec 29, 2010 | Wurlitzer Jukebox CD Player
Can my jukebox play stereo
the esm 5.1 is on a lot of nsm models if you need the manual email me at
philhemmings@hotmail.com
i will posta dvd disc with manual and service guide for free on some models there is a switch for mono/stereo
Aug 17, 2009 | Wurlitzer Jukebox CD Player
Hafler 9505 amp, has noisy output in mono.
Hi Don,
When you bridge the outputs , do you connect only to the ( + ) speakers terminals for your output. This is what the manual says to do.
Let me know
Scott
Apr 07, 2009 | Monster Cable MPA3250SS 3-Channel...
Beverage-Air MT27 Beverage Cooler Commercial Logo
18 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
