Yaesu ftc 1903. I have no labels on the lower three switches. What are their functions? The left one is a keyboard lock..and the rest?
Well I also lost the little tag plate.
Left indeed is a keyborad lock.
On my FTC-1903 the middel and right toggle switch does not seem to have any effect.
The middel one switches between "busy - manual - ...?..." and the right one between "USA-International". I guess the right one switches to a preset order of channel allocation, different for USA or other countries.
On mine swicthing middel or roght switch does not seem to give any effect.
So I would like to open up the set but would like to do so with the help of a schematic drawing.
Any source to find that?
jan
ON3ZTT
Hydraulic pump assembly; valve 1, valve 2 and motor
The hydraulic lines and the cylinders
GMLAN communication to the Body Control Module (BCM)
Open/Close request circuit to the driver and passenger window motors
Power and Grounds
Folding Top Main Power Fuse 30A
Folding Top Logic Power Fuse 20A
Ground G301 for the FTC module and G305
Folding Top Open/Close Switch (S15 and S16)
Rear Compartment Limit Switches
Rear Compartment Lid Release Switch (S3 and S4)
Rear Compartment Lid Release Switch-Front Hinge-Left (S11 and S12)
Rear Compartment Lid Release Switch-Front Hinge-Right (S9 and S10)
Folding Top Front Location Pin Guide-Left (S17 and S18)
Rear Compartment Lid Release Switch-Left (S19A)
Rear Compartment Lid Release Switch-Right (S19B)
Rear Compartment Partition Position Switch (S20)
Folding Top Front Location Pin Position Switch (S13)
Folding Top Front Latch Actuator Position Switch (S14)
Hall Effect Sensors
Folding Top Header Latch Cylinder Sensor (S1)
Rear Compartment Cylinder Extended Sensor (S2)
Your best bet is have the system checked for DTC'S - diagnostic trouble codes ! If it showed a message top not secured there is a DTC stored in the control module ! there are 24 possible DTC'S
Wand Removal & Installataion
Fig. Steering column shroud removal for the Cherokee
