Question about Maytag Atlantis MDE7400AY Electric Dryer
Changed from 3 prong to 4 prong wont run
When first pluged spark from back of dryer and now it will not run at all
  • 371 Answers
You wired the plug wrong so that you just shorted out the dryer with 220 volts going where the ground should have been.
Unless you supply more details, as to how you wired the prongs, can't be more specific, but before you even try to use the receptacle to the house wiring, you should get a certified electrician to look at it or you could burn down your house, which is a bit more damage than your fried dryer.
Sorry for the bad news, but the Good News is that you are still alive.
Posted on May 09, 2009
Why doesn't the timer count down? The dryer runs & heats but the Timer doesn't move. I replaced the Timer block but nothing changed. Is this related to a bad sensor?
go bak to 4 prong. why did u change it out? souns lik this isa 220 unit and not a 110? chk the book that came with the unit. lol.
Jul 22, 2014 | Maytag Dryers
Dryer does not run in new house
did it have P N E,E or 3 phase ?? if P,N E,E did you connect both Earth wires??
Feb 18, 2014 | Dryers
Maytag Neptune dryer went from 4 prong to 3 prong...cabinet light works but dryer we won't star
It's not wired right. You're only getting 110 vac to the machine which is why you are seeing some lights but no operation. Make sure when you went to the three prong plug you connected to both 110 vac lugs and common.
Feb 17, 2014 | Dryers
DRYER: Switched a 3 prong to a 4 prong and heard a pop when pluged into the wall. I then noticed my hot and cold wire were mixed up. Fixed the switch and nothing works now. Breaker switched off and on many...
Hi - why did you convert the plugs in the first place? In elctricity theres no such term as hot or cold wires. Besides what do you mean by a 4 prong or 3 prong? electrical equipments are designed to operate on 3 pin single phase power or a 4/5 pin three phase systems.
the voltages in both systems are totally different pending on where you live - 110v or 230v for a single phase or 230v - 415v three phases.
A single phase cannot be converted to the three phases or vise versa unless you use sophisticated electronics to do so. Unless you know what you are doing you can modify the 3 pin to opertae safely on a 4 pin by choosing the correct conductors in relation to the three wire conductors in the 3 pin plug.
The sad story for you is this will be a rather expensive lesson - I wont be surprise if the extra voltage has zapped some of the components in your machine.
THE BEST ADVICE I CAN OFFER YOU RIGHT NOW IS TO EMPLOY THE SERVICES OF SOMEBODY TO HELP YOU OUT - ALTERNATIVELY AS YOU STATED "BUYING AN OVER $1000 DRYER"
Jul 09, 2011 | Dryers
Got a used dryer had a 4 prong my house is 3 prong, changed the 4 prong to 3 prong plugged in and wont turn on, what do i do?
There is a difference between how a 3 prong and a 4 prong power cord is installed. Please read the following link:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have the power cord installed correctly and still do not have power, please check for 220-240 VAC at the wall receptacle. If you require additional assistance, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Aug 05, 2010 | Kenmore 64902 Electric Dryer
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
Dryer not working
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
Oct 05, 2007 | Roper REX3614KW Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
165 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
