Question about Sceptre X37sv-Naga 37 in. LCD Television
Sceptre 40 tv dead - Sceptre X37sv-Naga 37 in. LCD Television
I turned on my sceptre 40 in TV by hand not the remote I got shocked now it changes the HDMI on its own
Danger Danger. Take it to a technician straight away. Its shorting and could hurt you!
May 08, 2015 | Sceptre Televison & Video
Tv antenna signal
You have to go into the menu on the tv remote that came with your tv and change the setting from cable to antenna.
Apr 09, 2014 | Sceptre Televison & Video
My Sceptre TV randomly changes input sources
i have a sceptre Lcd tv model x40 the red light is on but when you push the power button it will not come on
Dec 31, 2013 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Sceptre x32
sorry grave yard,usless
Oct 27, 2013 | Televison & Video
Sceptre tv, no sound no picture
In other-words it is dead. Check its main power regulator board. Replace it.
Jan 09, 2013 | Sceptre 32 X320BVHD 32 LCD TV
Sceptre TV unexpectedly changes input source away from HDMI
My sceptre tv just started randomly changing through input modes, sometimes once or twice before stopping and sometimes it continues
Jun 30, 2012 | Sceptre X405BV-FHD3 40 in. LCD HDTV
I have a 40" LCD
okay the IC in the video circuit is bad replace it.it has a open in the IC the applying voltage is not filtering out properly to the rest of the circuit.if you are not a tech kindly have a tech do the repair cause you can cause damage.good luck.
Sep 23, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
Sceptre 40" 1080P LCD HDTV Display Upside Down
Power problem
Check out ebay for the part.
My 3 year Sceptre 27" died. Local TV tech said it was the power module. Charged $25 for the diagnosis and wanted $190 to fix it. Took it home, popped the screws and the module almost fell out. It's a simple plug'n'play!!! Found a new module on eBay for $65 shipping included.
Jun 03, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
Scepter X37sv-Naga LCD
The Sceptre TV do use the Sony codes. However, the cheap universal remotes do not have the buttons needed. The Volume Up/down and channel up/down are controlled with the circle of buttons (arrows) in the middle of the remote.
You can get an OEM remote from Sceptre. They still have them available. Sceptre is in California.
Jan 04, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre X37sv-Naga 37 in. LCD Television Logo
13 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
