Question about HP Televison & Video
I have an HP lc4776N TV. Turned TV off and next time I tried to turn it on the blue OFF light changed to gold (ON) but then immediately turned to blue light (OFF), I have tried it all - plugging and unplugging, checked all connections to be tight, alternate power source etc. Cable works fine in another room. Why won't my TV turn on and stay on?
  • 29 Answers
It looks like the power supply is damaged open it up and check for bad caps.
Posted on Nov 28, 2013
SOURCE: insignia lcd tv 32"
have good tec replace if nessary, The inverter module
Posted on May 10, 2007
SOURCE: No image
Had the same problem, it is a problem with a surge in the motherboard...mostly from the TV overheating.
Posted on Jan 27, 2008
  • 208 Answers
SOURCE: Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Posted on Mar 29, 2008
  • 22 Answers
SOURCE: My 32' Magnavox LCD TV won't turn on
it sounds like the internal fuse blew out it normaly a 5 to 15 amp fuse the you can pick up at any auto parts store if you are in the philladelphia area i have someone who can come fix it for you
Posted on Dec 02, 2008
  • 33 Answers
SOURCE: My Hitachi P50H401 50 inch Plama TV stopped
very common issue. if your hand you can repair it yourself.
for more info on this set please check out http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
if will tell you how to trouble shoot this tv. these tv's are known for two caps in the power supply to go bad and they need replaced then you have to test the sdr boards if they are bad you need replacement boards or you can send them off to be repaired. the link for the repair guy is on the page. this guy also sells the repair on ebay but if you contact him directly i beleave the price is lower. just tell him you were send over by home theater shack.
Posted on Feb 22, 2011
I have a Samsung UF55F9000AFXZA television and about a month ago it started taking a little time turn on and seemed to take longer each time i turned it on. Now it wont come on at all, but it tries. when...
with the fault worsening slowly it points to failing capacitors on the power supply Board which is not uncommon for this brand, there are many repair kits available for this brands power supply boards if you feel you are capable of fitting them try Here:
TV Repair Kits MBTV Electronics
or you could consider replacing the whole panel, a bit more expensive but less technical expertise required, shop Jimmy is the largest supplier of replacement boards:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 12, 2016 | Samsung Televison & Video
Why does it turn on for a second, then immediately turn off?
It is possible that the replacement t-con board is defective
Oct 15, 2015 | HP LC4776N 47 in. LCD HDTV
Our samsung hp-T5064 lost power and now will not turn on at all. The day before it lost power and turned back on 3 times. The next day after a lound pop on lower right side it shut off for good. No...
The tv power supply board is dead.That the board,where the power a/c plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Nov 08, 2010 | Samsung HP-T5064 50 in. Plasma HDTV
HP LC4776N power supply problem
Tries websites like Shopjimmy.com,Ebay.com to research refurbish power supply board to buy.
Jul 21, 2010 | HP Lc4276n 42 in. LCD Television
Why does my ,hp lc4776n, screen come in and out
hello,,,open the back cover of your tv check the power supply section .to identify the power supply section ,it is the pcboard where the ac main supply is connected..there is a connector there that is connected to tha cpu board....resolder the terminal of the connector and tighten the connectors same to the other end..2nd the supply of the inverter board..resolder the terminals and tighten the connectors...the inverter board is the board where the backlights are connected .power supply of the backlights...be carefull it is a high voltage section..its input voltage is from 12vdc - 24 vdc.output is 300 up vac...back light is the bulbs that illuminates the screen of the tv...when it is busted your screen will appear black..
good luck hope this helps you...
please rate my help tnx.
May 29, 2010 | HP LC4776N 47 in. LCD HDTV
Element tv.. model # ELCHS261 stopped working
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
Jul 10, 2009 | Element Electronics FLX2211B 22 in. LCD TV
My hannspree tv wont turn on i hav tryd switchin it off at mains
Hi
maube you have lost contact in your remote wiring! please check the remote area and power oscillation area.
Thanks!
Jun 07, 2009 | Hannspree (K206-10U1-005) Television
Televison & Video Logo
75 people viewed this question
Top HP Televison & Video Experts
Computer Links
vbalag
Level 1 Expert
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
