Question about Microwave Ovens
Ge spacemaker xl jvm1340
I had a burnt out light under the microwave so I decided to replace both light. What a difference! Then a day later neither light works. The clock & inside light both work. What's the problem? Can I fix it?
  • Microwave Ovens Master
  • 2,113 Answers
If you had too high a wattage the excess heat may have melted the wires or ruined the switch.
Posted on Nov 28, 2013
Testimonial: "Thank you for the response. Any other ideas? I used the bulbs called out in the manual-tubular 40 W bulbs."
Tulip
SOURCE: GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Posted on Sep 21, 2006
fridgetech
  • 473 Answers
SOURCE: GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Posted on Oct 10, 2007
SOURCE: GE spacemaker xl 1400, lights on bottom won't work
To Person who answered Best Solution above,
This worked nicely thank you.
After removing my circuit board the long silver strip was intact, however where it makes the turn about quarter inch, the solder or foil seam had a break in it which I filled-gap with solder.
My guess is if the "foil" or thin 2" long strip is serving as a fuse, it would still melt again even with my solder on the shorter section, in event of overload. Also seen on the plastic area directly behind where the circuit board would mount, and where the "foil" was blown, was a small blackened area as evidence of the blown foil. 2 new bulbs and all is well again Thanks!
Posted on Feb 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave oven - just stopped stopped working
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: ge spacemaker xl microwave oven turntable
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
If yours is a GE, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If yours is a GE, there should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
CHECK THE MAGNETRON SIDE OR HIGH VOLTAGE SECTION PROBLEM
Jan 09, 2014 | Microwave Ovens
My Microwave JVM1340 runs but does not cook anything. What part should need replacing?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Aug 31, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL JVM1340WW002 Exhast Fan does not turn off (ever). Light not effected, Door open/closed makes no difference.
Hi, you have a faulty control board as a result of a stuck relay on it which makes the fan to run continuously. The solution is to replace the control board....
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Spacemaker XL microwave model# JVM1340 WW that died. what current model# is an exact replacement?
if you want a replacement, check this link; http://www.nextag.com/ge-spacemaker-xl-microwave-oven/compare-html
But basically, if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Jan 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
A child burnt popcorn in our GE Spacemaker microwave. Now, everything works except for the heat. Panel works, light works, turn table works...no heat. Help pls.
Sadly popcorn kills more microwave ovens than peiple imagine. You can get an estimate on a repair but I believe you will probably decide in the end to replace it. Same exact thing happened to me............expensive popcorn!!
Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven stays on continuously and won't heat food.
Spacemakers have had problems with there magnatron, part is around 170.00. Depending on the year it is covered under a warranty however the labor is not. I have replaced 3 spacesavers for people already due to this issue. Unit runs but will not heat.
Jan 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1400
IF THE UNIT IS STILL UNDER THE 90 DAYS BRING IT BACK TO
WHERE YOU GOT IT BEFORE IT STARTS A FIRE!!
Jan 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
