Question about Seville Classics Dryers
10187b Seville classic tower fan rotating but blades not working. No air. Not even a noise. All the lights on the control panel working. A piece of plastic holding the blade assembly to the top of the tower has come off, but I don't see how that can impact the performance. What else can cause it?
Buffalo12980
  • 625 Answers
SOURCE: blade is loose
on the inner part of the motor [fan side] look for an external snap ring and a fiber spacer. the armature fits all the way into the rear part of the housing, the other housing goes over the motor shaft and must press against the snap ring and fiber washer.
Posted on Sep 07, 2007
  • 178 Answers
SOURCE: Ceiling fan replacement parts
Here is the link for SOME parts for Minka Aire Fans. They don't necassarily need the model number, just the balde dimensions for replacement. Hope this helps you.
Posted on Mar 24, 2008
  • 8 Answers
SOURCE: Maytag electric dryer makes noise
I don't know that I can help you in any way other than to say that you are probably right. But some times the blower wheels do come loose and spin somewhat freely on the shaft and make a similar noise. But when that happens, you will usually notice a vibrating sound right after the drum stops spinning. Because the blower wheel continues to spin for a second or two. But I have seen, popsicle sticks, jewelry, bobby pins,those plastic white things that are under the collar in shirts and all sorts of other things in those blower wheels making noise.
Good luck
Posted on Jul 28, 2008
SOURCE: Seville Classics MSC10166 Tower Fan
Possible Solution :
Taken From :
http://www.fixya.com/support/t193631-am_trying_fix_oscillating_tower_fan
"Most fan motors for fan over running have an internal overload. once it trips, it will not reset. it is a solid state device. it looks like a flat device or a small bullet device. if you've figured out how to take the fan apart, you could just remove the device and connect the two wires together and the fan will run. you won't have any protection on the motor however. the windings run warm, but if the bearings run dry the motor will slow down and the windings will get hot. this is the reason for the overlaod device - protection. its your call what you want to have."
Posted on Aug 22, 2008
SOURCE: Fan Blade came off - Aloha Breeze Model 12001 20" floor fan
If the fan has a metal blade set... to quote a previous post.. there should be a set screw that keeps the blade in place. it should be behind the hub, and is most likely a small allen (hex) screw that fits into a small threaded hole. If there's just a hole the screw is lost.. you could probably substitute it, by finding a short machine screw with a small head (so it doesn't mess up balance) and the same thread type and size at a hardware store. You might even be able to find an identical one at Ace hardware or the like, since they tend to stock odd little parts. Issue will be finding the right thread type (coarse, fine, etc).. if it has a plastic blade set.. it'll most likely have nothing by but a hole in the back of the hub where the motor's shaft fits into (or the blade hub is forced onto). some of them have a spring clamp around the plastic. many don't, and over time, they do fall off (even the ones with the spring clamps). just stick em back on. Usually if they're falling off regularly, the motor is running hot and either the fan is not in a good place (not enough open space around it, both the front and rear need to have some open space) or it needs oiling. Issue with the latter is, you'd have to disassemble the motor, oil it (with SAE-20, 10W30, or 3-in-One, most anything works well), reassemble it, and whack it back into alignment. though if you're willing to do this once every 2 or so years (depends on the oil you use, SAE-20 and 10W30 can last up to 5 years), or once every year for fans running 24/7 or 12/7... you can get way more life than the manufacturers expect you to get out of the things. it's messy, takes some practice, but it isn't very dangerous (long as you unplug the thing before opening it up) and it'll save you money in the long run (oil costs less than fans and motors). (and yes, I know all modern fans contain a "permanently lubricated" motor. and did you know that is bupkis? as in bovine pudding.. or horse ****.. the current generation of fan motors use the same "technologies" as the ones made over 30.. even 40 years ago. the only difference is the size per watt ratio. they required regular oiling then, and they do now. they {the manufacturers} don't want you to oil them {and manufacture the motors so it's difficult to do so} because they don't want the things lasting very long. it's one of those conspiracies that no one really cares about because 'eh, screw it, i'll buy a new fan.' meh. I just don't think like that.)
Posted on Oct 17, 2008
Seville classics fan turns on and oscillates but does not blow air
Fan blades installed backwards? I assume the blades are rotating?
Aug 03, 2014 | Dryers
My seville classics tower fan no longer oscillates - how can that be fixed?
Throw it away and buy a new one for 20 box at Wal-Mart. It's as simple as that cause to fix it, it'll take a new machine which cost twice the price. I think they made it to last one summer max. Friendly yours
Jul 01, 2014 | Seville Classics MSC10166 Tower Fan
Why blades are not rotating or throwing air?
some of these have a expansion pin that holds the fan blade assembly onto the shaft, this may have fallen out or ? broke,,,
May 13, 2014 | Seville Classics MSC10166 Tower Fan
The fan has power and will rotate, but no air is being blown out. any troubleshooting tips or is it a goner?
Try to free up top fan bearing, it is under switch cover. Pry cover with small screw driver, insert screw driver blade in access hole and pry, top fan bearing is held by two screws, remove, clean and lubricate with oil or grease. It works!
Sep 29, 2010 | Seville Classics MSC10166 Tower Fan
How do you clean it? It shoots out dust!!
You need to change the air filter, make sure you clean out the air filter chamber before installing a new one. it should be fine then, Good Luck
Feb 07, 2010 | Seville Classics MSC10166 Tower Fan
Fan vibrates either in stationary or rotating position
Vibrations are a cause of friction. I can only assume that the motor or the fan veins are being interferred with. If you feel comfortable you can take the case off and look or take it to a repairshop and have them look it over.
Aug 20, 2009 | Seville Classics MSC10166 Tower Fan
Dust inside the fan
you can remove the topcover and can be cleaned using the brush and or vaccum cleaner/ even blower
Jun 01, 2009 | Seville Classics MSC10166 Tower Fan
To take apart: see solution #1 (not a complete disassemble but helps)
Aug 15, 2008 | Seville Classics MSC10166 Tower Fan
Seville classics model 10166
bottom stand was broken. how to get new bottom part.
Dec 06, 2007 | Seville Classics MSC10166 Tower Fan
Dryers Logo
Top Seville Classics Dryers Experts
Dan Webster
Dan Webster
Are you a Seville Classics Dryer Expert? Answer questions, earn points and help others
