Rca xy-2300 to make compatible with westinghouse 13in tv
5 Suggested Answers
gopakumarg43
  • 74251 Answers
SOURCE: How to do code search on my rca xy 2300 remote for
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Posted on Aug 25, 2012
gopakumarg43
  • 74251 Answers
SOURCE: How to program my rca xy 2300 remote
Check this link to download it.
  • 879 Answers
SOURCE: RCA remote #xy-2300 need codes for zenith tvs
004/ 005/ 009/ 015/ 104/ 105/ 106/ 109/ 133/ 172 These are the codes to check. If you want to get more codes, check these links
Posted on Feb 21, 2013
  • 879 Answers
SOURCE: rac remote codes for zenith tvs
http://electrohelponline.blogspot.com/ Check these links.
I have a westinghouse tv vr-6025z and I want to hook up external speakers.
most set have jacks marked "audio out" which could be RCA type jacks, or a coaxial or optical output . Connect a cable or cables from whichever one of those is compatible with the inputs on the back of your stereo receiver.
Dec 22, 2016 | Westinghouse VR-6025Z 60" LCD TV...
How do I replace control board?
RCA/Westinghouse HV320WXC1007061 T-Con Boards ...
? 4:35
https://www.youtube.com/watch?v=5jO_TZfplR0
Jan 21, 2013 - Uploaded by ShopJimmy.com
RCA TV Repair Westinghouse TV Repair T Con Board Tutorial & No Picture ... Top Common LCD TV problems for bad TimingControl T-Con Boards: .... VR-3215 with no picture no sound but the power LED is solid green, any ...
RCA 276046 Power Supply Unit (PSU) Boards ... - YouTube
Nov 24, 2015 | RCA P52927 52" Rear Projection TV
Feb 20, 2013 | RCA Televison & Video
Need to find code for RCA universal remote, Westinghouse TV
Go to
http://rcaaudiovideo.com/
On the left side select 'remotes' and then your remote type. You will be able to download the manual and codes for your RCA Remote Control.
Let me know if you have any other questions. Please rate this solution. Thanks.
Mar 09, 2011 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
How do you hook up a sound bar too a westinghouse TV
Usually on newer westinghouse tv's the only audio output on the tv is the headphone jack so you will need to buy a 3.5 mm stereo to rca converter and use that instead of the rca cables provided with the sound bar.
Jun 12, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Remote code
Try this code
0096
Feb 29, 2008 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
