Question about Garden
Tractor has been doing fine for three years, but foot pedal brake now has almost quit working. It will stop the vehicle if I push down as far as it will go with excessive pressure. Acts like something may need readjusting. Do not have a service manual yet, only the operator manual which has exploded views and part descriptions, but they are often non-legible for some areas. Thank you for whatever help you can provide. Charles A. Princeton, Texas
  • charlesand May 09, 2009
    Thanks, Mike. "Cable" - I don't think there is a cable actuated brake system on this tractor. From the poor drawings of exploded views in the owner's manual, all I see is a rod that connects the foot pedal to a lever and brake components on the transaxle (transmission). However, they give me no info on what and where a brake pad or adjustment mechanism is located.
    I don't have a problem fixing most things as long as I have enough info to know how the thing works and some decent descriptions of the parts involved.
    Any further suggestions are welcome and appreciate your taking the time out to offer them.
    Charles Anderson
    Problem Solver:
  • 12 Answers
I would follow the cable coming out of the brake in the engine compartment and trace it ti the engine and there will be an adjustment screw to tighten the cable to as not to require so much pressure.
Regards,
Mike
Posted on May 09, 2009
How to get locked rear wheels on ford tractor 1900
brake pedals are controlled by a lock pall attached near or on the pedal arm. This is the park brake part of a tractor. You may have to push the brake down and manually lift the pall out of the way as it will no automatically release.
Dec 20, 2014 | Ford Cars & Trucks
How do you know that a brake booster is bad?
Booster problems are rare but they do go bad sometimes.
A bad booster generally causes the brake pedal to feel hard to push down, and a lot of pressure on the brake pedal is required to make the car stop.
Rarely, a vacuum brake booster will develop a vacuum leak, which can cause engine performance problems, hissing or whistling noise, as well as requiring increased pressure on the brake pedal to stop.
The first test:
With the vehicle parked, turned OFF, and the parking brake set, pump the brake pedal 5 to 6 times. If the pedal gets harder to push after several times, your booster is probably good.
The second test (To make sure):
After the test above, without making any changes, press and hold the brake pedal with light to moderate pressure.
Now with your foot still on the brake pedal, start the vehicle.
If the booster is good, you will feel the pedal go down when the engine starts.
Hope this helps!
Jun 21, 2014 | 1993 Cadillac DeVille
Polo 1.4 - Im used to driving an automatic, but the Polo is manual. When I stall th engine, the foot brakes won't work. This is scary, especially on a hill!
Most likely the car has Power-Assisted brakes, Almost all vehicles today do. They allow us to stop the car with very little pressure required on the brake pedal, as the system uses engine vacuum to do the work of our leg. When you stall the car, you lose engine vacuum. This means that the brake pedal will still work, but requires far more effort to push since there is no vacuum assist. Most vehicles have a check valve at the input to the power brake booster to hold vacuum on the booster when the vehicle shuts down. This provides you with one last free press of the pedal. If you are not getting that, either your car does not have a check valve, or the valve is faulty.
Nov 14, 2013 | Cars & Trucks
My Hyundai 2003 front brakes overheat and stop the car from moving. What might be the course?
How far do you drive before it starts to happen? ....Do you use your Left Foot to push the brake pedal? Are you sure your foot is not on the pedal while driving?
It sounds as if the caliper is 'frozen' - the caliper is what squeezes the brake rotor/disc and slows down the car.
GL,
TD
Sep 04, 2013 | Hyundai Santa Fe Cars & Trucks
When coming to a stop, the brakes work fine until I get almost stopped, then the pedal will push down further and brakes will come on hard, and stop vehicle hard, what could be the problem?
Sounds like your master cylinder is bad on your brake system. If you are stopped in your driveway(not on the street) leave the vehicle in park. Start the car and place your foot on the brake with light pressure and keep this pressure on the pedal. If the pedal continues to drop slowly to the floorboard your master cylinder is leaking past the primary piston in the master cylinder. If this is the case have this repaired immediately. Your brakes could just all of a sudden not be there the next time you apply them when you need to stop.
Apr 05, 2012 | 1995 Buick LeSabre
Ignition switch will not turn on. Battery is good. Steering wheel is locked, What should we do?
Quite often that will happen when vehicle parked with wheels turned, and/or vehicle on a slope, so try to avoid that in future.If nothing else, when parked on a slope, stop, keep foot on brake pedal, apply parking brake, put transmission in neutral, then take foot off brake pedal and wait for parking brake to stop vehicle rolling, then shift it into park. When leaving, put foot on brake pedal, shift to drive or reverse whatever direction your going, then release parking brake. Sounds like a lot to remember but you won't have to pull hard on shifter as before, and it could save a lot of money on transmission repairs down the road. Always try to park with wheels straight as well.
Now, with that said, if you parked with wheels turned, try hard to turn steering wheel in same direction wheels are turning, just slightly, as you try to turn key. Sometimes a quick yank in that direction will do it. Also make sure shifter is all the way in park before you try it. If your on a slope try rocking vehicle slightly up slope as you push/pull shift lever in to park and try to turn key at same time. If no luck, try pushing brake pedal real hard and try to turn key. Let me know how it goes.
Nov 06, 2010 | 1999 Dodge Caravan
Craftsman garden tractor quits when brake released.
It sounds like your throttle cable is caught up with the brake pedal.
Oct 01, 2009 | Garden
No brake lights, rest of lights are fine
Look under the brake pedal, up near where it is connected. You'll have to get down in the floorboard. Push the pedal all the way down and see if the button contact is being pressed when you do. If it isn't, loosen it and move it up or down until it is. If it is being pressed in far enough for contact, it is most likely a faulty switch if you are certain the fuses are alright.
Jul 22, 2009 | 1991 Volvo 240
CAR suzuki swift 1.3 diesel 2008 (BRAKES)
this car must be under the factory warranty.
take it in this car is unsafe to drive
Sep 27, 2008 | 2002 Suzuki Aerio
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
