Question about Sony Computers & Internet
I want to know how to connect the cable colors of the on/off button, Can you helpme?
  • dmallenw May 09, 2009
    In this case, have not text, and that colors are not in the same jumper,send to you a couple off pics about it, thanks for your help
  • 3,267 Answers
It should be written on the jumper like plug at the end of wires as 'power', however if I remember correctly its colored green/white.........sodeep
Posted on May 09, 2009
  • Sudeep Chatterjee
    Sudeep Chatterjee May 09, 2009
    The green & black combination is for power...........sodeep
How to tune up dvd player
  • Plug the power cable of the Samsung VHS/DVD player into an available power outlet near the television.
Connect a set of RCA audio and video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. The colors of these cables are yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to the color-corresponding inputs on your television. When plugging in these cables, look for a label for the input, such as "Video 1" and "Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step 3. If you did not take note, you can also tune through your television's input channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Component Video
Connect a set of component video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. These cables will look similar to composite audio and video cables, but they are instead color-coded as red, blue and green.
Plug the other end of the component video cables into the color-corresponding inputs on your television. Take note of what input number you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your VHS/DVD player, then connect the other ends to your television. These cables are color-coded as red and white and must be plugged into the same input number as the component video cables.
Tune your television to the component video input channel where you connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Jul 10, 2012 | 2005 Toyota Caldina
My dvd player only plays back in black and white, no color. any ideas?
If you haven't done so already try connecting a different DVD player (or some other device) to the same part of the television to see if there is color. You can also try changing the cables connecting this dvd player and the television. If there is color on another device then you know that the problem is with the DVD player. If there is color with the same DVD player when you have changed the cables then you'll know that they were the problem. If the television does not play in color no matter what (DVD player or tv channels or anything connected to the television with all different cables) then you'll know it is at fault.
Apr 05, 2011 | Onkyo DR-C500 Multi-disc DVD Player
CAN YOU HELPME, MY DAUGHER PUSH THE PANIC BOTOM, KNOW MY CAR DONT TO power!! CAN YOU HELPME
If it is a factory system put the key in the driver door and turn it all the way left then all the way right should disarm it! If it is an after market system their should be a button under the dash on the drivers side to disarm it!
Jan 11, 2011 | Chrysler PT Cruiser Cars & Trucks
My w800i lock code, i dont know it. and i want to reset it.. pleaseeeeeeee helpme
my w800i lock code,i dont know it. and i want to reset it.. pleaseeeeeeee helpme
Dec 09, 2010 | Sony Ericsson W800i Cellular Phone
I have a Prima LCD T.V. and i have a PlayStation 2,3 And i need to know were to plug in the red yellow and white wires in too the back of the tv and also what channel to put it on so that i can play.
the cables and the connections are color coded..just connect the matching color cables to the back of the tv..power both ps3 and the tv on..use the AV settings on the tv to change to AV1/AV2 etc ,in some tv the button on the remote is labeled as 'source'..hope it helps..
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
When connected DCR-SR42 to TV, video and images showing in B&W
yes ur TV might be set to color system PAL /NTSC and ur cam corder in opposite format there is color system changing button on every tv remote just try changing it to PAL or NTSC see if colors work and let me know and pls rate me if i fixed ur problem
Feb 25, 2009 | Sony Handycam DCR-SR40 Camcorder
DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
Jan 31, 2009 | GE 27GT619 27" TV
I have just put in a new color cartridge, and now I can only print magenta. I know that the other colors are flowing, because when I tried to wipe them off with a cleaning solution, there was color from...
try cleaning the print heads and disconnect the power and usb cable from the back of the printer and press and hold down the power button for 30 sec and then reconnect the cables and try again...open the backdoor and try to move the rollers in upward direction.Make sure the unit is connected directly to the walljack.
Nov 27, 2008 | Canon Office Equipment & Supplies
HelpMe plz
As far as I know, wired or wireless modem don't have any time limite set. unless it is set by the user.
check with your IPS (Internet Provider).
are you using dialup or cable???
Nov 10, 2008 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
