Question about Garden
Komatsu leaf blower eb4401
Engine working only on very lo RPM in the mid position .puling down or up engine stop. What could be wrong. Thank you.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Bad fuel, carb adjustments, plugged exhaust port
Posted on Dec 30, 2013
boscia
  • 163 Answers
SOURCE: Leaf blower will not achieve full RPM's
try removing the muffler and scraping out any carbon build up in the exhaust mouth of the block. if that doesnt help you will probably need to replace the carb.
Posted on Nov 29, 2008
  • 398 Answers
SOURCE: Homelite 26D leaf blower bogs down in Run position
check the air filter.
Posted on Mar 02, 2009
  • 257 Answers
SOURCE: Kill switch on Stihl BG 75 leaf blower not working
when engine cool,, spray wd 40 into the switch and work it a dozen or so times and clen it out
Posted on Aug 12, 2009
bbreton
  • 437 Answers
SOURCE: BX 90 homelite leaf blower two idle screws
The initial setting is 1 1/2 turns out. Screw them all the way in and them turn them 1 1/2 turns out. This is the starting position and should start, it may need some final adjustments to run like you need it to run.
Remember more the screw is out the more fuel it will get.
Good Day.
Posted on Oct 14, 2009
  • 4 Answers
SOURCE: My Ryobi RBL30MVA. leaf blower will not start,
I have had this exact same problem with the same model after just one hours use.
Returned it a week later and after 2 months the replacement did the same thing.
Returned that one and got a third. A week later that ones doing the same thing again after only an hour or so use.
Obviously some defect in them.
I'll be getting my money back and visiting the local mower center to get their help rather than doing the guess work my self and ending up with a dodgy model
Posted on Dec 24, 2009
Pull cord binding when mounted on engine but not when removed from engine
When you assemble the Recoil Starter, push it down onto the blower easily and then pull the cord slowly. It should drop into position as you slowly pull the cord.
May 07, 2015 | Poulan Garden
Engine run on very low rpm in mid position
check carb, exhaust, fuel and air filter
Nov 28, 2013 | Garden
Turn off choke, engine stops
You may need to adjust the carb.
Jan 03, 2013 | Garden
Leaf blower that wont run at high rpm
You need to replace your fuel lines.
Nov 09, 2009 | Garden
Engine starts easy. Engine can only achieve high
eitrher a clogged fuel filter thats in the tank, old gasoline or the fuel pump daiphragm in the carb has hardened
Oct 30, 2009 | Echo Inc. 25.4 CC Backpack Blower
How do I adjust needle valves on a 25cc Homelite UT08111A Backpack leaf blower?
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
http://tech.flygsw.org/walbro_tuneup.htm
hope this helps :)
if it does please vote
Oct 23, 2009 | Homelite Consumer Products Backpack...
I NEED A PARTS MANUAL FOR A HONDA LEAF BLOWER # GX240MAX. THANK YOU
HONDA DOSENT MAKE A LEAF BLOWER , JUST THE ENGINE DO YOU NEED ENGINE PARTS OR LEAF BLOWER PARTS
Sep 22, 2009 | Garden
Aug 12, 2009 | Garden
Blower does not stay running
Make sure you have the propper mix of gasoline and oil. If the fuel is old mix new fuel to proper ratio. Find your manual and find the low speed fuel adjustment and the high speed fuel adjustment on the engine. First, turn the screws in and count the turns so you know where you started. Return the screws to the origional position. Usually 2 to 2-1/2 turns are a good starting point if you get them messed up. If the engine runs with the choke on you have to open the high speed jet a bit, 1/4 turn CCW. Keep trying this and get the feel of the change in the engine performance. If you have too much fuel the engine will not get to peak RPM. The low speed jet works similar but you have to adjust it so the engine idles at a decent RPM. This should get you on the path.
Mar 15, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
