Question about Sony VPD MX10 Multimedia Projector
Problem using the MS port - MS Error
Hi guys,
Does anyone know why I can't load a memory stick into the projector to run a .ppt presentation? Every stick I use comes up with the MEMORY STICK error. I try to format on the projector, but it won't allow me to enter that section of the memory. Even formatting on PC doesn't help.
HELP!
SOURCE:
  • 215 Answers
SOURCE: "No Memory Stick" errors
Due to the length of the memory stick it rarely causes bent pins sideways but they can over a long period lose their tension and fail to make contact with the memory. Also, more commonly they can tend to get a build up of dirt on them. Try using an old memory stick and quickly push the stick in and out of the camera as fast as you can and do this for about 15 to 20 times (with the camera off of course) this should clean any gunk built up on the contacts. Now switch on and use the new stick to see if it's working. If not try the exercise again. If it still doesn't work try sticking 2 layers of sticky tape to the front (the side opposite the gold contacts)Run the tape from the bottom (the contact end) to the top. Running it to the top will ensure it comes out with the stick when you eject it and it doesn't stay inside causing problems. Doing this will marginally increase the size of the stick and put a little more pressure on the contacts. Just nake sure the sticky tape comes nowhere near touching the stick's contacts as this will tend to make them pick up dirt. Also this trick is only to see if it's you camera's contacts have lost tension, its not meant as a permanent fix. If neither of these tricks work I'm afraid it's a trip to the camera hospital.
Posted on Jul 20, 2006
  • 17 Answers
SOURCE: Format error in Sony Cyber-Shot DSC-S650
Format the memory stick via setup menu inside the camera. Let me know if this works.
Posted on Nov 11, 2007
SOURCE: memory stick format error
I got a msx-8mgs of sony memory stick duo
how to format?
Posted on Apr 13, 2008
SOURCE: Memory Stick Formatting Error - Sony Cyber Shot DSC T-20
I have had the same problem. Contact your camera via USB to your PC. Click on MENU. You do see "USB Connect" and "folder" at the bottom. Make sure that it stays on "USB Connect" click on round button in the middle and you will get 4 options. It probably stays on AUTO. Select PTP and see what happens. Adobe Photo Album started up and I got to see the pictures till the moment that the stick got the format error. I lost a couple of pictures, but got a lot back.
I'm not sure what the problem is, however realized that if this happens again. Shut your camera. Start it up again. Go into MENU, SET UP, Memory stick tool, chnage Rec folder and create a new. This way you keep the folders smaller and do not loose that many pictures.
I hope that it helps.
Pepe
Posted on Jun 05, 2008
SOURCE: sony memory stick pro duo format error
when i turn my camra on its does nothing it has a black screen and it don't turn off then when i take the memory stick out it works and turns off with no problem
Posted on Sep 21, 2008
How do I recover a corrupt PowerPoint file?
If there was such problem, the simplest decision is described here:
Method 1:
Move the PowerPoint to different location : this is first and very useful troubleshooting method to repair PPT problems . Copy presentation and paste it on other computer hard.
Method 2: Open presentation in MS word document:
If you have tried above method, but still facing same problem then try to open corrupt PowerPoint in MS Word. Follow this below steps:
•Open MS Word.
•Click on Open button of File menu.
•Select Files of type box and navigate to your corrupt file, Open it.
Method 3: Use Safe Mode
To see your presentation in safe mode, first of all you will have to run PowerPoint in safe mode. Follow these steps to do it...
•Click on Start button.
•Select Run & type "C:\Program Files\Microsoft Office\your MS office version\Powerpnt.exe" /safe".
•Now press OK button.
•Restart your system, during restart press & hold F8 button to start window in safe mode.
•Open & see your presentation.
If at you it didn't turn out to solve a problem, it is possible to try to solve it otherwise, for example as it is described here:
https://social.technet.microsoft.com/Forums/en-US/50c99db5-9167-44fe-b625-e2682fa682ca/corrupt-powerpoint-file?forum=officeitprolegacy
And also there is a universal decision and "an edition choice" it watch it here:
Online PPT repair tool
Sep 10, 2015 | Microsoft PowerPoint for PC
How do I recover a corrupt PowerPoint 2013 presentation?
You can try:
PowerPoint Repair Toolbox is powerful .PPT repair software, resolving any problem, causing the damage of PowerPoint files. This tool guarantees the compatibility with all available software configurations therefore PPT on repair of reinforced concrete structures works anywhere in the network.
For more information: https://www.pptrepairtoolbox.com/
Mar 02, 2015 | Microsoft Office Computers & Internet
Message in Powerpoint: Part of the file is missing. How to fix it?
your powerpoint file seems to be severely corrupted. You may try to open this file in PowerPoint Fix Toolbox http://www.powerpoint.fixtoolbox.com/
If if it useless follow the steps 1) Open a new presentation and use Insert --> Slides --> From existing presentation to pull in the slides from the corrupted file. This works about 50% of the time.
2) Try using the Clone Me add-in from Microsoft. It may work, it may not.
Or see more http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/679-could-you-help-me-with-recovering-ppt-file
Feb 06, 2015 | Microsoft PowerPoint 2007 for PC
How do i fix ppt file? Please help
Hello. There are different methods available to recover corrupted PowerPoint files.
Open presentation in MS Word document
and follow this steps:
- Open MS Word.
- Click on Open button of File menu.
- Select Files of type box and navigate to your corrupt file, Open it.
Also you can try Recovery Toolbox for PowerPoint https://powerpoint.recoverytoolbox.com/
More information see here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/677-how-to-recover-powerpoint-file
Feb 05, 2015 | Microsoft PowerPoint for PC
How to restore all powerpoint 2010 files?
Hii..
There are different methods available to recover corrupted PPT.
Method 1:
• Open MS Word.
• Click on Open button of File menu.
• Select Files of type box and navigate to your corrupt file, Open it.
• Click on Start button.
• Select Run & type "C:\Program Files\Microsoft Office\your MS office version\Powerpnt.exe" /safe".
• Now press OK button.
• Restart your system, during restart press & hold F8 button to start window in safe mode.
• Open & see your presentation.
Method 4: Try Third part repair Tool: If all above method fail to fix corrupted presentation then you can try third party PowerPoint Restore Toolbox
http://www.powerpoint.restoretools.com/
Feb 02, 2015 | Microsoft PowerPoint for PC
Wrror message C13:01. Keep saying insert memory
First you have to find out if the problem is caused by the camera or by the MS. Replace the MS. In case of wrong MS you may restore photos in some card reader using some freeware restoring SW. In case of wrong camera check pins for MS in the slot.
Oct 18, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Problem running power point with embedded video file on projector
I too got the same problem once.But some how i had managed to solve it.Actually it is due to the corrupted header of the ppt file i.e the system can read ppt location of the memory but unable to reach the video file .The solution is you just need a powerpoint 2007 file recovery tool.The tool i used is provided here.Why i am recommending the tool is it makes a copy of the ppt and then repairs it .so there wont be any further damage.The demo version is here.If satisfied with demo reach the full version of it as i did ...
Feb 26, 2009 | InFocus ScreenPlay 4800 Multimedia...
Not enough space or memory to run Word 12.0
Could you please let me know what operating system present on your PC?
Antivirus/Firewall and other spyware/adware utilities present on your PC.
I would suggest you to make a complete uninstall of MS OFFICE (including all components of Ms Office 2003 & Ms Office 2007 if present anyone ) then go for fresh installation of MS Office 2007.
Let me know if the problem still persists. Dont vote till you get the solution for this problem.
Thanks
Scott
Nov 12, 2008 | Microsoft Office Professional 2007 Full...
Memory sticks
First you have to make sure there is enough room on the memory stick. Plug in the USB stick and open My Computer. You should see a "removable device" on E or F. That is your memory stick. Right click and select properties. It will tell you how much free spce there is. Now check the size of the powerpoint presentation the same way: Navigate to it and right-click.
If there is enough free space, you're almost there. Right-click on the powerpoint file (ending in .ppt) and select copy. Then go back to my computer and open the F:\Removable device icon. Once inside the device, right-click and hit paste. You should see the .ppt file being copied onto the memory stick. When it is finished, right-click the F device again and hit eject.
Jun 05, 2008 | Electronics - Others
Powerpoint 2003 needed, not ppt viewer
Unfortunately, you are going to need to purchase Power Point 2003.
You can still purchase Power Point 2003 from a number of sites like
Yahoo shopping, MSN shopping etc.
http://shopping.msn.com/results/presentation-software/bcatid5562/forsale?text=category:presentation-software&ptnrId=178&ptnrData=38570
Apr 09, 2008 | Microsoft Office Standard for PC
Sony VPD MX10 Multimedia Projector Logo
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
