Question about Toshiba Satellite A215-S4747 Notebook
Computer just shuts down for no reason. fully charged
  • 1 more comment
  • gflicker May 09, 2009
    thanks will try this. I wonder if it was overheating.
    thanks
    thanks
    Problem Solver:
  • 5 Answers
I Have encountered 2 x problem on toshiba laptops. at first i thought its about the fan/cooling system. just reformat your laptop and that will solve the problem.
Posted on May 09, 2009
  • 68 Answers
Myself, my fiance, and my brother all have satellites and all three of ours have had that problem at one point or another. The problem with my computer was that it was overheating causing the shut down. Is the top of your computer hot to the touch when this happens? If so, I'd recommend propping it up on something to allow the air to escape from the cooling fan on the bottom of the unit. I hope this helps you.
Charging light flashing orange, but computer is fully charged.why won't it shut off..been doing this for 3 days?
How old is the battery? Is it the newer Ion type you find inyour phone? It is a common problem for a battery to get as fully charged as it can be an still be charging. Because the capacity of the pack is no longer as high as it was new. Not sure if this is your problem, but open battery case, check contacts, make sure they are clean, inspect battery to see if there are bulges, etc. does the battery still run the computer as long as it did before, if so battery might not be the problem. Changing battery packs have solved all my problems in the past. Also do a complete shut down, many people just let computer go to sleep an never restart. Sometime windows just loses drives an for no reason. Check all these first.
Mar 19, 2015 | Acer Aspire One D255 Netbook
Tip
How to get the most out of your iPod battery
When you first get the iPod make sure to fully charge it. Then only charge the iPod when it is so dead that it will not stay on long enough to play anything. Then allow the battery to charge until a screen appears saying fully charged. This may seem redundant but it ensures the batteries capacity will be maximized for as long as possible. There are only about 1800 charge cycles in an iPods battery life. This may seem like a lot of charging ability but when you wish to keep the iPod for more than a year and a half it becomes more realistic that it is not.
Above all else, never ever remove the iPod from the computer without ejecting it first.
If you are for some reason unable to properly eject the iPod, first shut down your computer before removing the iPod.
on Jan 14, 2010 | Audio Players & Recorders
Computer will not turn on
If your computer is plugged into a power source, you may have to do a "hardboot" or reset ... if it has already shut down (for whatever reasons). Try pressing the Power (on/off) button down for a while (up to 15 seconds) ... or until you see it start up ... or, release and then press the power button again (normally) to see if it powers up.
If your computer is not plugged into a power source, it may have shut down due to low battery. And, until there is battery power, it will not start up (or wake up from sleep/hibernate mode). First charge the battery up (preferably fully), and then press the Power button to start up the computer.
May 20, 2014 | Samsung XE500C21-A04US 12.1" Chrome OS...
Gps shuts off regularly
From what I've experienced, repeated restarting, and frequent shut downs, can be traced back to a defective power cord, and/or a low battery state. Garmins operate best with a full battery charge, regardless their connection to external power.
If you can get it to connect to your computer, and can see it as a device with removable storage, right clicking on it's icon, and select "properties" to show you the battery-charge state detected.
Mine won't charge when connected to the computer for some reason, and won't boot even if left for a few hours, but if I connect it to a dedicated usb charger, (the kind that plugs into an A/C outlet with a USB port) it will begin to charge. After fully charging it returns to normal operational state. If it still can't charge it may need a new battery...
Apr 06, 2014 | Garmin nuvi 2455LMT
Tomtom
My 2 year old TomTom gps Via 280 will suddenly not turn on
Jan 16, 2014 | Tomtom GPS
My Toshiba nb505 netbook run with the AC adapter, but will not run on the battery. The battery shows that it is charging but the charging percentage does not increase. Any advice?
I own the Toshiba NB505 netbook and the very same thing was happening to me. Here is what I did to fix my issue:
Step 1: Shut down the computer and remove the battery. Then turn it on but now with the battery out. It should say "battery not detected".
Step 2: Open control panel and open the "device manager". Under "batteries" (the first one), uninstall the one that says "Microsoft ACPI Compliant Control Method Battery". This is the battery driver.
(Don't worry. The computer will automatically re-install it)
Uninstall the driver and shut down the computer.
Then reinsert the battery and power on the computer. The driver should have re-installed itself. Check to see if the battery is now charging.
(It will take awhile for it to fully charge to 100% Best to shut it down and let it charge. The far left indicator light on the front of the Netbook will turn green when it is fully charged)
Hope this helps. Yeah I had to figure this one out on my own. Toshiba support staff over the phone were useless!
Good luck!!
Sep 24, 2012 | Toshiba Turquoise 10.1" NB505-N508TQ...
Problem with a IBM ThinkPad T20 2647 PC Notebook
check ur hd for bad sectors...shutting down for no reason is usually this(bad sectors)
also check system information and check device manager..could be software problem/incompatabilty/no drivers installed/or two devices trying to use same resource and shutting down cos cant.
Jan 07, 2009 | IBM ThinkPad T20 2647 Notebook
Garmin 320 shuts down
I suggest you take it to the store. Probably an internal errorr
Mar 02, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
Toshiba Satellite A215-S4747 Notebook Logo
152 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
