1997 Volkswagen Golf Logo
Posted on May 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Install an ac in a 1997 vw golf
Hi I have a 1997 golf vw with no ac at 150000 on it - the car is well maintained, but i need to know how much I should expect to pay to install an ac.
Colin Stickland
Level 3:
  • Volkswagen Master 22,516 Answers
  • Posted on May 09, 2009
Colin Stickland
Volkswagen Master
Level 3:
Answers
22516
Questions
Helped
6993228
Points
66324
Buy another car,to fit A/C now is more than the car is worth,install a sun roof instead
I need to find out what the symbols mean on my 2003 VW golf fuse card
Volkswagen Golf IV / Bora (mk4; 1997-2004) fuses ...
https://fuse-box.info > volkswagen > volkswagen-golf-i...
Here you will find fuse box diagrams of Volkswagen Golf IV 1997, 1998, 1999, 2000, 2001, 2002, 2003 and 2004, get information about the location of the fuse ...
Fuses and relays Volkswagen Golf 4, 1997 - 2004
https://car-box.info > fuses-and-relays-volkswagen-golf...
25 Jan 2021 - Fuse box diagrams for Volkswagen Golf 4 (1997, 1998, 1999, 2000, 2001, 2002, 2003 and 2004 model year). Photos, layout and assigment of ...
2helpful
Hi i hit my mark 3 vw golf into a ditch and now the left hand side wheel is bent and possibly the ball joint or drive shaft. Will i be able to use parts from a vw polo of similar age. Will the vw polo...
Simple answer: No. Polos and Golfs use different mechanical components.
More complicated answer: If there is that much damage then the bodyshell mountings are also quite likely to be distorted which will make any repair attempt futile. Ideally you must get the damaged parts stripped off and then get the mounting points accurately measured. This can only be done using specialised measuring equipment. The alternative is to invest in the parts needed for your repair and to fit them with an immediate alignment check at the nearest suitably equipped garage. If the alignment of the body is off then the car is effectively a write off as repairs will exceed the car value.
Head gasket on vw
35lbs, 45lbs, 90 degree turn, 90 degree turn
Hi, need diagram of 1997 VW Polo diesel gearbox
Hi Paul, Most of these gearboxes were almost identical for vw during the those years, some manuals are available free from this site
http://carservicemanuals.blogspot.com/search/label/Volkswagen
Hope it will help you out.
Dave
1997 VW Golf A/C Problem
it is low on freon you need to find the leak
97 vw golf
i have a 1997 Golf GTI 2.0 liter engine the motor was replace and has 40,000 on it but the body has close to 150,000 on it everytime i shift 1st to 2nd somethings hitting the ground somewhere and secondly the intake maniflold has like a rattle in it or something of that sort and i dont know where its coming from its sounds like a missfire but im not 100% sure yet can someone help me and oo and 4th and 5th gear the clutch makes a biut of grinding noise like not loud and only when your fully in gear and the clutch is all the way out any ideas
Speed sensor on 1997 golf
I clipped this from my Mitchell manual:933b3d6.jpg
Engine Maintainance light on
This could most likely be one of 2 things, 1. if it is your maintainance light, it is probably one of your sensors, possibly the mass air filter sensor, oil pressure sensor, and 2. If it is a diesel engine and its the glow plug light, you would need to replace your glow plug relay because it telling you that the glow plugs are still on when the engine is running, which you should take care of asap before you have to replace the glow plugs themselves.
My clock resets to 0 after 300 000km
I believe all the 1997 VW's reset to 0 after 300k. I had a 1997 diesel jetta that did the same thing.
3answers
VW Golf maintenance instructions
www.ebookmanual.net/vw-golf-jetta-service-and-repair-manual.html
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
