Question about Bose 901 VI Main / Stereo Speaker
Just purchased Sony DA5800 ES reciever will my Bose 901 speakers work with this? Need help
    Scholar:
  • 65 Answers
Bose 901 speakers are designed to use with the Bose equaliser patched between the pre-amplifier out and power-amplifier in of your receiver. Having said that, Bose did not invent EQ, neither is EQ a mystical process. Not sure which series 901s you are talking about, but I would definitely be experimenting with the built-in EQ supplied with your Sony DA5800 ES. The manual says you have +/- 10 dB of adjustment for treble and bass for each of the surround channels. That is not really adequate in my opinion, not only would I be seeking +/- 15 dB, but I would also like to be able to apply those adjustments at frequencies chosen by me, not just 'treble' and 'bass' To use the Bose EQ, it needs to be patched between a preamp output and power amp input. The Sony DA5800 ES has preamp outputs, so you could use these (Note that the built-in EQ is disabled when using these outputs) In this case you could either feed the signals back into the Sony (post Bose EQ) perhaps using a different 'Zone'. As an alternative option, you could power your 901's with a stand-alone two channel power amplifier. Then you get the full benefit of the Bose EQ as well as the surround sound from your Sony (front L+R speakers off) It all sounds like a lot of fun. Happy listening! Cheers, Don.
Posted on Dec 14, 2013
SOURCE: bose 901 v1 adding a amplifier
You may connect an additional amplifier to the Rec Out or Line Out from your existing receiver.
Please note the Bose 901 equalizer can be used to connect to one amplifier only.
Do let me know if you have any further questions.
Posted on Dec 18, 2007
harishu
  • 18 Answers
SOURCE: Will Bose 901 active equialiser connect to SONY AV1100 Receiver
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Posted on May 22, 2008
SOURCE: BOSE 901 ACTIVE EQUALIZER
i, trying to hook up a powered subwoofer to my hafler dh 110 and dh 500 running a bose 901 series v active equalizer and series v 901s any info would be appreciated
Posted on Oct 20, 2008
SOURCE: compatable receiver list for Bose 901 series VI
I contacted the Customer support folks at Bose. Here is what they said: With a stereo receiver, the equalizer is run through the tape monitor section in the back of the receiver. The receiver's tape monitor output, left and right, runs to the amp input section of the equalizer, left and right. Then the amp output section of the equalizer, left and right, runs to the receiver's tape monitor input section. With a surround sound, home theater, type of receiver, the theory is the same, but the connection is through the preamp-out/ main amp-in section of the receiver. Not all receivers have this feature. Most, in fact, do not. Check the back of the receiver. There would be a connection made by two U-shaped clips. The plugs would be pulled out. Then connect from the preamp-out to the equalizer's amp input section; and from the equalizer's amp output section to the main amp-in. This effectively isolates the equalizer so that it is not affecting the other speakers in the system or the receiver's surround processing. Attached is a current list of known 901-home theater compatible receivers:
Note: Specifications subject to change without notice. Bose Corporation is not responsible for any inaccuracies due to manufacturer changes. Inclusion in this list does not indicate an endorsement by Bose Corporation. When in doubt contact the manufacturer of the equipment.
I have the list in a pdf document but do not see a way to attach it.
Contact me at danmc@uwyo.edu and I'll forward the pdf.
1-30-2009
Posted on Jan 30, 2009
dunnbiker
  • 8546 Answers
SOURCE: how to connect bose 901 speakers to 5.1 setup?
The solution is simple and cheaper than you think.
The analog 5.1, 6.1, 7.1 outputs on your receiver should be active even with digital inputs that you want to hear. Your receiver turns everything it processes into analog output just before the speakers anyway so there's no loss of access to multichannel sound this way.
What I did was to buy a separate amp for the 901's and feed the Front L&R analog audio out to the EQ which is directly in front of the amp. The Active EQ is only for the 901's which don't have woofers or tweeters so Bose flattened out its final response electronically with some serious boosting at both ends. Having it in line with any other speakers would feed them a grossly over-compensated signal.
Your receiver will drive the rest of the speakers.
This is the cheapest way to have your 901's and hear them, too. Since the 901's are really efficient you don't have to buy a big amp that would heat the room. I'm using a separate Carver amp with 2x100w for mine.
Posted on Apr 13, 2009
Hey i just bought a pair of bose 901's and was wondering what system would provide enough power but still cheap and mp3 compatable???
Keeping in mind that the 901's and multichannel recievers won't work unless you use an outboard amp for them, that should open up the choices pretty wide. But your MP3-compatible AVR MUST have front channel pre-outs. Any solid 100 watt x 2channel amp will drive them.
Sep 23, 2010 | Bose 901 VI Main / Stereo Speaker
901 VI Main / Stereo Speaker: Good evening...I recently purchased a pair of used...
I believe there are two nuts on each post. The first one locks up against the firewall and the second secures the speaker wire against the first nut. Tighten the lower nut snug against the enclosure.
May 06, 2010 | Bose 901 VI Main / Stereo Speaker
Proper wiring connection on bose 901 speaker with onkyo tx-sv424 purchase 5 years ago
trying to hook up sereas 2 901 to onkyo sx 424 i have access to carver c 1 if that will help
Nov 29, 2009 | Bose 901 VI Main / Stereo Speaker
901's directed to TV
Yes, you can plug your TV directly into the Bose 901 Equalizer, but you will still need to go from the EQ into an amp to drive the speakers. The Bose EQ basically is for the speakers, not the signal coming in to it. Because of the speaker design, the EQ "shapes" the sound to compensate for the speakers. Please rate my answer, thanks.
May 22, 2009 | Bose 901 VI Main / Stereo Speaker
How do i hook my bose 901 equalizer into deno
The Bose EQ connects to the tape out and tape in on the amplifier or reciever. If you were using these for a tape deck, you will then have to connect the tape deck to the tape in and out on the Bose EQ.
Beemer530
Mar 22, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Mar 29, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
76 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
