Question about Sabrent Televison & Video
I have a Sabrent CRW-EXT USB card reader/writer. When connected to pc get message that driver was not installed correctly and windows does not recognize it. What to do to fix problem?
  • 59 Answers
Go to the Sabrent website and find an updated driver that matches the version of Windows you are running.
Posted on Nov 28, 2013
Mesmo
  • 164 Answers
SOURCE: Sabrent TV-BOX USB2.0 Windows Vista x64
Try this website
Both vista and windows 2000///XP are located on here
Click here
Posted on Oct 23, 2008
  • 565 Answers
SOURCE: Can´t found drivers for Windows Vista x64
u can try the x32 driver - here
if helped rate fixya
Posted on Dec 29, 2008
  • 13 Answers
SOURCE: Sabrent USB-AVCPT on a Vista not installing
Try installing the drivers first before plugging in the device.
Posted on Jul 25, 2009
  • 49 Answers
SOURCE: Windows 7 x86 do no detect correctly the audio
U should check the recording device properties have not muted ur line in volume and then enable the speakers to listen the microphone's voice
Posted on Jan 20, 2010
  • 151 Answers
SOURCE: I'm attempting to use a Sabrent USB-DB25F cable to
print driver is possibly looking for a specific printer port like lpt 1 or two with the specific address and interrupt.
or you have to find a setting to change to or from ecp, epp, bidirectional or standard printer port,
Posted on Mar 16, 2010
I bought CRW-FLP2 12/2013.HAVE NOT BEEN ABLE TO FIND A CABLE FOR INTERNAL FLOPPY DRIVE. WILL Mfg Part No: ULT40112; UPC No: 022769401126 CONNECT TO BACK OR DRIVE AND TO USB 2.O? I HAVE ASUS PC WITH N
Hello there Bill,
This takes me back many years. !!!!
It is most odd these days to find people still using Floppy Drives. Are you SURE you want a floppy disc drive ? They cannot store very much at all.
First of all, before you do anything, Open your PC and MAKE SURE you have a socket on it for a floppy drive. !!!!! If necessary get the model and make of the Motherboard and check on its manufacturers website that it has a socket.
THIS IS IMPORTANT as modern computer motherboards DO NOT provide floppy interface sockets. and you cannot run a floppy on them.
Right, the Floppy needs a 34 way cable with connectors both ends
There is no USB connection for a floppy disc drive.
If you bought a floppy and all-in-one card reader item then the usb is for the card reader and NOT for the floppy..
A picture and explanation of it are here http://pcguide.com/ref/fdd/confCable-c.html
This is what you need to buy. Dont worry it looks long at complicated, it is just that it has extra connectors .
Install the cable in to the motherboard and floppy, Your computer will recognise the floppy automatically and off you go.
Good luck
Sep 21, 2014 | Sabrent CRWFLP2 Internal Floppy Drive
Running windowsXP pro sp3 ids TEAC floppy in CP sys but no A drive in explorer
I too am having a problem with the Sabrent floppy drive.
I'm running a windows 7, 64bit system, everything installed ok,
but I kept getting a "install disk" message every time I tried to
access the drive. (I did have a disk installed.)
Any thoughts?
Thanks
Feb 21, 2012 | Sabrent External Floppy Drive
I have not used my Husqvarna reader/writer for a while. I put the program on windows 98 because I bought a new Mac, and it says the reader/writer cannot be found. Therefore I cannot get my embroidery on...
You might just need new drivers for the reader/writer. Try the Husqvarna website first, or else do an internet search for "Husqvarna Reader/Writer drivers" or something similar. Is the reader/writer a USB or serial connection? You are going to have problems if it is serial and I am not sure there is a solution, but USB connection should definitely be able to get working.
Nov 14, 2010 | Husqvarna Designer I
4D d-card reader/writer - seems to be installed but not working
I have been having the same problem. I was told that the 4-d software is not compatible with Windows 7.
Mar 23, 2010 | Husqvarna Designer I
3.5'' internal memory card reader/writer installation problem
Your reader/writer is set up for use on 2 USB ports (hence the 9 pin connector), one port for the reader and one for the externak USB port. This has nothing to do with the port version. The long and short of it is you need a card with a matching internal header. NEVER break off a pin! Some of these headers have reversed connectons so you probably broke of one of the data pins and runed that header's ability. Typically the readers like you have come with several cables, so that they can match the headers you have available. Older motherboards and add on USB cards did not use standardized header configurations aas you seem to have found out. Your best bet at this point is contact the manufacturer of the reader and find out what brand of add on USB cards they recommend and go with that. AND AGAIN NEVER REMOVE ANY PINS FROM A HEADER !!!
Feb 11, 2010 | Computers & Internet
Imstalling internal card reader
Well, installing an internal card reader without a spot on the motherboard, is a little hard to do. I would suggest buying an external card reader. They are a little cheaper, and a lot easier to setup and use, since they just connect to a USB port which all computers have.
Feb 23, 2008 | Dell Dimension 3100 PC Desktop
Internal USB Card Reader
Most add-on USB2.0 cards have the standard USB header on them if you have the room for a PCI card.
Feb 15, 2008 | Sabrent (USB-2535) (USB2535) IDE...
Televison & Video Logo
Top Sabrent Televison & Video Experts
Lawrence Oravetz
Martin Murray
Are you a Sabrent Televison and Video Expert? Answer questions, earn points and help others
