Question about Pool & Spa
Remove pool pump motor jacuzzi magnum force
Do I have to disconnect the power to get the retaining nut, or is there something that can be removed from the pump to get the nut on?
  • 372 Answers
It may be easier to disconnect the power, depending on access. You can also remove the impeller, seal plate and mounting bracket. Which ever way is easier.
Posted on Nov 30, 2013
  • 6 Answers
SOURCE: Pump noise
sounds like it needs new bearings, take it to a pool professional.
Posted on Jun 09, 2009
  • 17 Answers
SOURCE: Jacuzzi Magnum Force Pump not working
The number one problem is air leaks.......check all connections to see that they are tight, and rubber seals. The intake side would give you trouble with air leaks. If you dont find any leaks then I would pull the pump cover and check the impellor. Pool stores have parts and lots of knowledge.
Posted on Jun 25, 2009
  • 366 Answers
SOURCE: We are having issues getting the impeller apart on
I believe the jacuzzi pump impeller has a locking screw directly in the middle of the impeller. You'll have to turn it clockwise to remove it. Then you'll need to remove the cover from the back of the motor using a 1/4" nut driver. Depending on the motor, you should be able to use a 7/16" open end wrench to hold the motor shaft from turning as you turn the impeller counter-clockwise to remove it. Some motors are different, some have a keyed shaft or require a special tool to hold the shaft while the impeller is removed. Hope this helps.
Posted on Nov 22, 2009
  • 366 Answers
SOURCE: I have a jacuzzi magnum force pool pump. A leak
you need to replace the shaft seal.
Posted on Nov 30, 2009
  • 12650 Answers
SOURCE: Hi I have a magnum 1000 Jacuzzi pump for my
alot of companies use to have a damper ring on pump shaft which would knock down some of the noise a pump motor made pumps make noise and the bigger the pump the louder the noise if its not vibrating or clunking then its running as it should
Posted on Apr 21, 2010
I need a motor end cover, where can I get one? Thank you!
Jacuzzi (Carvin) Magnum, Force & Plus pump parts are hard to find.
Here is a link to our site which has a parts explosion/diagram for those pumps.
Jacuzzi Magnum, Magnum Plus, and Magnum Force Pumps
Jun 08, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
How do you get the pump out of the housing on a jucuzzi magnum force pump
If yours is the model with the big round ring around motor, it is a large retaining nut. Remove this nut and the motor should come from the pump housing. Don't be too rough, plastic breaks.
Jun 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Motor removal on a Jacuzzi magnum force pump.
The impeller is threaded onto the end of the motor shaft and the housing (pump body) is attached to the motor with the same bolts that hold the rear cover on the motor they run all the way through on most pumps.
May 27, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
We are having issues getting the impeller apart on the jacuzzi magnum force pool pump and need some instructions on how to proceed.
Nov 22, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi Magnum 1000 - overheating & looking for manual
Loosen the motor and impeller from the pump by backing off the large plastic nut and take that whole section to an electric motor repair shop for inspection. If the motor is salvagable, they can quote the repair or replacement.
Jul 05, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Getting to impellre
the impeller is what is holding it in on the end of motor is the impellel the impeller is in a houseing right off motor that is held togethere by screws you should disconect power then power for motor then remove water in/outtake there may be some kind of strap holding it down
Feb 25, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Do Magnum Force Pumps have a reset switch ?
No jacuzzi magnums do not have a reset button. First make sure breaker to pool is off, then remove rear motor cover, and take a look. Popping noise sounds like an arked wire. Could be a bad terminal or just aloose power wire. JACUZZI PUMPS ARE GOOD QUALITY, AND USSUALLY RUN FOR MANY YEARS. Pump can be removed for repaair, or motor replacemant by a qualified, and republe pool shop, for rebuilding Ussually rebuilding is about half the cost of new. Kirk
Feb 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Pool & Spa Logo
18 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
