Fujitsu air conditioner error codes
Code EEE
SOURCE: Fujitsu wall mounted air conditioner.
Is it a split system? I had the same problem with my split system and and it was because the condenser line was mounted wrong. The line was mounted so the water had to go uphill and it was causing the condensation to leak through the front of the unit.
Posted on Aug 14, 2007
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
  • 68 Answers
SOURCE: Error code of E4 on Dometic HP air conditioner ??
16. SYSTEM RESET
a. Turn the ON/OFF switch to “OFF” position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to “ON”.
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released.
c. When a dip switch is turned on or off after initial configu
ration, a system reset will need to be done before the
Comfort Control CenterTM will recognize the updated selection. Try this. This is for the five button thermostat. Did you check the dip switches to be sure the proper ones are turned on? I need to know which stat you have 4 or 5 button. I have trouble shooting for both.
If you notice reset needs to take place after a dip switch is turned on or off. The dip switches are on the circuit board. You need to drop the lower cover. the dip switches will read in this order #1 heat strip/ #2 zone2/#3zone3/ #4 zone4/#5 furnace/#6 differential/#7stag/#8 gen start. Check this out and be careful. Turn off the stat to change dip switches. On will be toward the description. If you don't have remote start gen set the dip should not be on. If you dont have a Zone 3 the dip should not be on, etc.
Any questions feel free to post back
Thank you for using fixya
Jerry
Posted on Mar 26, 2009
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Posted on Apr 18, 2009
SOURCE: E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Posted on Jul 27, 2010
My fujitsu abt18lbaj won't go, the red light flashes constantly and the green light flashes 4 times
Hi Russell,
I hope the following link is of some help to you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.htmlNIGY5Q
Jan 25, 2015 | Fujitsu Heating & Cooling
I have a fujitsu inverter asta 24jcc every eight seconds the red and green light flashes about five times
Hi Ken,
I hope the following link will help you?
Good luck
Dec 13, 2014 | Fujitsu Heating & Cooling
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
Eee code
error code 01 reset? indoor signal sensor
Apr 08, 2011 | Fujitsu 36CS Air Conditioner
I have a fujitsu invertor AOT54LJBYL and the key pad comes up with EEE
When EE:EE is displayed on remote control , press "Energy Save" &"Zone Control" buttons simultaneously for longer than 3 secs. The error code will then be displayed on the LCD.After getting error code, please write here to get solution. Thanks.
Feb 04, 2011 | Heating & Cooling
I had a power failure and my Fujitsu Ducted R410A is showing an EEE code in the clock side of the display unit... we are in a heat wave and melting help!!
Towork out what the error code is press the orange start/stop button on theremote controller so unit operation is stopped.
Then press and hold "energy save" and "zone control" buttonsimultaneously for at least five seconds, the error code will be along thelines of En:nn where the "En:" is the error code and the":nn" indicates the indoor unit address if there are multiple indoorunits connected to the one controller. If the upper vertical bar on the capitalE is missing so it looks maybe like a 2 or something don't worry for somereasons they just do that
Dec 27, 2010 | Heating & Cooling
Eee code displayed
To work out what the error code is press the orange start/stop button on the remote controller so unit operation is stopped.
Then press and hold "energy save" and "zone control" button simultaneously for at least five seconds, the error code will be along the lines of En:nn where the "En:" is the error code and the ":nn" indicates the indopor unit address if there are multiple indoor units connected to the one controller. If the upper vertical bar on the capital E is missing so it looks maybe like a 2 or something don't worry for some reasons they just do that
Some common error codes are:
E0 Communication error between indoor unit and wired remote control, check if there is 12VDC between terminal 1 + 3 at remote control and 8-9VDC pulsating between terminal 2 + 3. If DC volts out of Indoor pcb is below about 11.6VDC it will cause this error, the problem is normally dry capacitors in the 12 VDC power supply section. This model has two power supply sections on indoor pcb.
E1 Communication error between indoor unit and outdoor unit,
EF Discharge temperature abnormal
Dec 25, 2010 | Fujitsu 36CS Air Conditioner
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
