Question about Sony VAIO VGN-NR498E/S Notebook PC
Recovery error 320 on sony vaio laptop
I am trying to recover my sony vaio laptop vgn-cr36 series, came with vista home preinstalled, i have created the recovery disks, trying it with recovery disk but, at some point of time it gives me error 320 and then error 330, while recovering the complete system, any help please
Ketanvasu your an idiot....If he's trying to recover the laptop obviously the thing isn't working...so how the hell is he supposed to burn cd's genius?
Posted on May 18, 2010
I was getting the same error codes and the system would not reload from any recovery disks. I discovered a RAM chip was faulty and when I removed the faulty chip I was able to reload the OS onto the system without a problem.
Posted on Jan 12, 2011
    New Friend:
My laptop sony vaio vgn cr35g is shuting down automatically at any time i change the bettry change the ram change the hard disk and also do the service of the laptop but problem is not solve plz help me what should i do????
Posted on Aug 03, 2013
  •  John A. Crowder
    John A. Crowder Nov 02, 2013
    It may be shutting down due to dust packed within the cooling fan and copper heat shield. Their are monitored thermostats that auto kill for good reason. I would also place some new heat sink compound on top of the CPU. So start there you will have to be careful when accessingbthis area..
    Novelist:
  • 92 Answers
1. For Error 320 or 330 , if possible, run the RAM hardware diagnostics to determine if the RAM has failed.
2. If the RAM passes the test, only the HDD requires service.
Below is the detailed list of all error codes.
Error Code Part Failure 1 Part Failure 2 41 return error task failed error -1 or just Error 41 HDD 320
(When using the Recovery discs)
Recovery Discs
(Try using F10) Optical drive
320
(When using F10) RAM and/or HDD
(See the important notes above) 400 RAM 305:64
(When using the Recovery discs) Recovery Discs
(Try using F10) Optical Drive 305:64
(When using F10) HDD 305:69
(Try using F10) Optical drive 305:69
(When using F10) HDD 330
(When using the recovery discs) Recovery Discs
330
(See the important notes above) 332 HDD 403
Posted on Jul 23, 2011
  • ABDULLAH RIPEN
    ABDULLAH RIPEN Oct 20, 2013
    All the test for HDD and RAM is PASS, but the error (320) still occur. Any solution?
    Problem Solver:
  • 17 Answers
Create new recovery disk from ur laptop again and try
Posted on May 10, 2009
  • ABDULLAH RIPEN
    How can you create new recovery disk when you laptop fail to boot and the previous recovery cd has corrupted.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
Push enter to get past it
Posted on Mar 03, 2013
  • 470 Answers
After you have gone through all of that information above the next time this happens to you with Windows 7 make a back up image file and a recovery boot disk everyone please do this right away when the system is in good working order it will save you hours of headaches and trying to cipher through all these explanations. Also you will want to use a software program to totally erase the hard disc and really start fresh. Hirens or Dban there are others out there free. Just go to Google and type in free hard disc eraser software.
Posted on Jul 25, 2012
  • ABDULLAH RIPEN
    But all the recovery CD back up both image file and boot disk was fail, what solution you can do?
  •  John A. Crowder
    John A. Crowder Dec 13, 2013
    There are a huge amount of solutions here. What's most likely corrupt is the hard drive. If you do not wish to purchase another one. And get a original factory recovery disc. Or have another computer handy online and if there is no hardware issue. Then you may consider shopping it with a repair place. Or purchase another lap top.
I CANT LOAD MY VISTA DISK im trying to re install vista home but my computer keeps looping
If you have not changed the preinstalled OS in the computer, the recovery partition in the computer will be still intact. In that case, you can use the recovery partition to perform a system recovery. Please restart the computer and press and hold the F10 key. This will launch the recovery partition and from there, you can select "Restore C Drive" to perform a system recovery.
As you have mentioned that you are trying to perform a system recovery using the discs(which i understand is recovery discs for the computer), I suggest that you check if the Boot sequence is set to CD/DVD Drive in the BIOS and then try again.
Thanks!!!!
Dec 30, 2010 | Sony VAIO VGN-NR285E/T Laptop
Laptop: Sony Vaio Serial Tag: C3LRMD7Q Model: PCG7133L Need information for recovery disks for the foremention laptop. The OS is Windows VISTA Home Premiun.
The VAIO Model VGN-NR498E/S is shipped with Recovery partition in the hard drive. It is required to create the recovery discs as soon as you get the notebook. Using either recovery discs or the recovery center you can reinstall the preinstalled OS in the computer. But, it depends if you has changed the preinstalled OS, the recovery partition will be erased and no longer be accessible.
However, in your case, if you not made any changes to the preinstalled OS, restart the computer and press and hold the F10 key. this will launch the recovery tools. On the next screen, press Enter key. Then you will be able to view options such as "Restore C Drive", "System Restore" etc. There select "Restore C Drive" to reinstall the preinstalled Vista OS in the Computer.
If you have changed the preinstalled OS in the computer, then it is requires to purchase the recovery discs from Sony's parts center:
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=partSearch&searchText=Y8318272A&sessionId=pfBoWO6gh7vj_fseXl4oiMI
The above part is no longer available with them However, you can use the part #Y8318272A to search for the recovery discs with online retailers and others.
Thanks!!!!
Dec 16, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
I lost all data from my sony vaio vgn-nr498e even original windows(home premium) and recovery partition.how can i recover it if i am using another windows at present
You will need a good disk recovery software. These utilities do come at a price. Email disk recovery experts such as Recover Data or Sony Vaio data recovery if they can help you.
Please share your feedback to help others.
Feb 07, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
Same problem with sony vaio laptop but O/S is vista...sure cud use some help.....tks forgotten password
At one time I forgot my vista password and I use Windows Login Recovery to create a password reset disk. With the disk I successfully reset my forgotten password. Hope to help you.
Nov 08, 2009 | Sony VAIO SR Series Notebook PC...
Hi what is the buttom i press while i turn on my laptop to recover vista vgn cr490 i try but didnt work
Try with F10 key at start up.
Restart the System, tapping the F10 key immediately. This should trigger the System to boot directly to the Recovery Partition, and initiate the VAIO Recovery Center, without requiring the Windows Operating System to load.
In the VAIO Recover Center, select the option 'Restore C: Drive' and follow the onscreen instructions to perform a C: Drive Recovery.
Performing a C: Drive Recovery will erase all the data present in the C: Drive and will reinstall the preinstalled Operating System, Applications and the original Drivers.
Good Luck!!!!!!!!
Oct 13, 2009 | Sony VAIO CR Series Notebook PC...
I need VAIO® VGN-FJ170/B Restore Disks
You can create your own disc from the Vaio recovery center.
If the computer is no longer booting up and the Vaio Recovery center is no longer accessible, you can call sony parts center to check if you can buy a recovery disc for your unit
parts center 8004887669
Sep 23, 2009 | Sony VAIO VGN-FJ170/B Notebook
How I can get recovery disc for my laptop Sony Vaio VGN-SR 26GL?
You probably need a recovery disk because you dont have the necessary drivers and the software that came pre-installed on your laptop. but instead of worrying about that, why not just get any operating system disk of your choice, install it, download the drivers for your laptop online and install them too, and interestingly you can also keep all the drivers you downloaded with the OS Disk incase of future necessity for your laptop repairs.
In case your decide to do this, the link to download the drivers for your laptop is :
http://www.laptopdrivers.net/sony-vaio-vgn-series-laptop-download-vista-to-windows-xp-drivers/
Happy Installation!...lol
Jul 10, 2009 | Sony VAIO VGN-CR220E/P Notebook
Can't restore factory intallations and settings: Vaio VGN-FE880E
Are you doing DESTRUCTIVE recoveries or are you doing NONDESTRUCTIVE recoveries? Try another hard drive in the machine and recover to that. Nondestructive recoveries replace the operating system without destroying the personal data. Its possible the original problem is propagating over to the recovered systems. Do a destructive recovery. Understand any data not backed up will be destroyed. Possible the original problem was a trojan virus.
Mar 23, 2009 | Sony VAIO VGN-FE880E/H Notebook
Sony VAIO VGN-NR498E/S Notebook PC Logo
17,499 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
