Question about Covercraft Block-It 200 Custom-Fit Car Cover for a Chevrolet Cavalier
2001 chevy fuel pump relay switch location - Covercraft Block-It 200 Custom-Fit Car Cover for a Chevrolet Cavalier
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
The wire for the ignition switch is often located on the starter. It's a thin wire. If you disconnect that, then turn on the the ignition key to run position. Then go back under the hood and touch that thin off wire to the positive post of the battery. You should hear the fuel pump relay click on and off. If no click, then your relay is either bad or it has a bad ground wire. I've had to add my own ground sometimes, directly to the relay.
Posted on Nov 28, 2013
Malfunction indicator lamp lit on 2013 chevy equinox. immediately engine stalled. was told it is the fuel pump.Where is fuel relay switch located to rule out a fuse problem b4 I change fuel pump
Your vehicle does not have relay switch ! Fuel pump controlled by a fuel pump driver control module . ( computer ) Who ever told you that it needed a fuel is probably wrong !
Malfunction indicator lamp lit ??????? What code ?
Mar 20, 2017 | Cars & Trucks
2002 Chevy express 1500 fuel relay location
    images for 2002 Chevy express 1500 fuel relay location
    More images for 2002 Chevy express 1500 fuel relay location
    GM Fuel Pump Relay Testing - YouTube
    ? 27:40
    www.youtube.com/watch?v=McnXLcJNVfI
    Mar 14, 2012 - Uploaded by ScannerDanner
    1999 Chevy Suburban with no fuel pressure. The following is covered in this video: 1. How to test a fuel pump relay in a power distribution box.
Oct 23, 2015 | Cars & Trucks
91 chevy Corsica fuel pump relay location
91-chevy-corsica-fuel-pump-relay-10thp3u1urk50x2lc0as22df-3-0.gif Here it is. Also The procedure
NOTE: The fuel pump relay is located in the engine compartment, attached to the relay bracket mounted on the front of the dash. Other than checking for loose connections the only service on the fuel pump relay is replacement.
PROCEDURE
  1. Verify that the ignition switch is in the "OFF" position.
  2. Disconnect the wiring harness plug.
  3. Remove the fuel pump relay.
  4. Install the new fuel pump relay.
  5. Connect the wiring harness plug securely.
-Tim
Jun 30, 2015 | Cars & Trucks
2008 chevy cobalt fuel shut off switch location
fuel pump relay located under hood in the fuse and relay box.look on other side of cover of the fuse and relay cover it will show fuel pump fuse and relay location.
Apr 17, 2013 | Chevrolet Cobalt Cars & Trucks
Fuel relay switch in 2001 Chevy Blazer
What problem are you having?
Have you checked for power to the pump?
If you do not have fuel pressure it is more common to suspect a pump failure. Checking for power at or as close to the pump as possible will quickly identify which direction you need to go.
Sep 21, 2012 | Cars & Trucks
Where is fuel pump relay is location on Ford expedition 2001 4.6
It is located in the relay and Maxi fuse box under the hood near the battery, both the fuel pump fuse and relay are in this box, the fuel pump fuse is a 20Amp and is marked #10, the fuel pump relay is is marked as relay #301.
There is also a fuel pump cutoff switch (triggered by an accident exceeding 3 G's)
The fuel pump shut-off switch is
located in the passenger's foot well,
by the kick panel.
Jul 19, 2011 | 2001 Ford Expedition
Where is the fuel pump relay on the 2001 Chevy Tracker?
Hi, here is the location of the fuel pump replay below....
Hope it helps....
Jul 12, 2011 | 2001 Chevrolet Tracker
Fuel gage is not working properly
you might have a problem with the gas meter located inside the gas tank with the fuel pump.
It is a common problem for most chevy trucks and smaller chevy SUV's.
Before doing this big job! locate the fuel pump relay + the fuse, take them out to restart the fuel pump. this might work.
hope this helps.
Dec 01, 2009 | 2001 GMC Yukon
2001 chevy s 10
Find power wire coming from relay to pump when key switched on, & follow it back to pump. If you have power out of relay & nothing at pump, then I'd look for a break in wire to rear, or just run a new one. Double check your ground as well.
Jul 05, 2009 | 2001 Chevrolet S-10
Is their a fuse for the fuel pump ( not the fuel
it appears that fuse 30 and the relay right beside it are for the fuel pump. the relay is definately for the fuel pump tho. it's located in the fuse panel inside the engine compartment near the battery.
Robert
Please take a moment to rate this solution.. thanks
Mar 04, 2009 | 2001 Chevrolet Silverado 1500
Covercraft Block-It 200 Custom-Fit Car Cover for a Chevrolet Cavalier Logo
70 people viewed this question
Top Driving Comfort Vehicle Parts & Accessories Experts
Robert Plante
 John
John
 AEpittsburgh
AEpittsburgh
Are you a Driving Comfort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
