Question about Delta Faucet Delta T13422 13 Series Classic Monitor Tub/ Shower Trim In Chrome
I am trying to replace an old delta monitor 1300 diverter spout. It seems when I take off the spout it has a threaded part in the middle of copper pipe . The spout itself has a plasticinsert with threads. I want to change from the plastic chrome to actual metal spout. What do I need to do? Is there a replacement that I can just screw on or do I have to do something with the copper pipe with threaded middle?
    Top Expert:
  • 45,115 Answers
Tub spouts are pretty much interchangeable although you may find the replacement spout cannot be installed easily because the threaded copper stub does not extend far enough to engage the threads inside the spout.
Posted on Nov 28, 2013
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
We have Delta brand tub/shower fixtures, the one handle kind. The problem is that water comes out of both the tub faucet and the shower head, even though the shower is not turned on. This happens every...
You need to replace the tub diverter/spout. There are two kinds, I hope you have the kind with
an allen head set screw on the bottom side of the spout near the shower wall. These are super
easy to replace ! Loosen the set screw, twist the spout a little and it should slide off. When installing
the new spout, smear some vaseline on the copper pipe sticking out, this will help seal the new O rings in the spout.
The other kind of spout has pipe threads in it. They can be a little more tricky. I got called to a
house one time. The plastic female threads on the spout cracked when the plumber installed it.
The water ran down the inside of the wall and did damage down stairs. The leak could not be seen
until the sheet rock down stairs fell down from being soaked. You need to put some pipe dope on the threads, then tighten the spout on by hand, so as not to scratch it with a pump pliers.
I hope this helps !
Nov 03, 2010 | Delta & Single Handle Shower Faucet
I have a Delta shower assembly with a pull-down diverter. When I engage the diverter for the shower, half the water seems to make up to the shower and the other half is forced through the back of the...
One of 2 things is happening. Either the o-ring is shot, or you have a hairline fracture of the plastic around the brass adapter. The o-ring is a #18, but if there's a crack in the plastic you'll need to replace the spout.
Oct 03, 2010 | Delta Faucet Delta RP17453 Pull-Down...
I have a garden tub w/o a shower attached. However, the fixture in the tub is the Delta pull down diverter (dont know why they would put that in a tub w/o a shower). Anyway, the diverter was pulled down...
If it was me... I would replace that spout...
the spout either is threaded on or it has a set screw on the bottom at the back that you loosen and then pull the spout off by pulling straight away from the wall...
Check and see if the spout has the hole for the set screw...if not then twist it counter clockwise and it will turn off...
then repalce the spout with a new one with out the diverter...
heatman101
Aug 05, 2010 | Delta Faucet Delta RP17453 Pull-Down...
Delta spout diverter broken cannot find direct replacement
I have a Linksys router WRT54G and i was used it on my verizon network, now i want to re-install it to another computer that i have with comcast network
The router was works well with the cable old attached, either the new one, but when I go to wireless it doesn't works
I get a strong signal but unable to get on the internet with WEP security.
With security disabled the wireless works fine. But will not connect to the
internet with WEP security on. I tried to use the CD install disk that comes
with the router but ir does not help. So i want to know what i might suppose to do?
Any help would be apreciated.
Mar 18, 2010 | Delta Home
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
Delta diverted spout is stuck! Can't pull it down
You probably have lime deposits built up which won't allow you to pull it down anymore. Try spraying lime away on it and use an onld toothbrush and work it up in there. If this doesn't work, you can replace the spout with a generic one. The spout should just twist off. Sometimes they can be stubborn. Hopefully this helps.
Apr 03, 2009 | Delta Faucet #RP320 Divert Assembly
Diverter Tub Spout stuck
Its probably just stuck on some lime and mineral deposits. You can try and spray some lime away on it and then try to loosen it. Or you can unscrew the whole spout so you can soak it. If that doesn't work, you can either contact Delta for an exact replacement or you can purchase a generic one.
Apr 01, 2009 | Delta Faucet Delta RP17453 Pull-Down...
Delta Faucet Delta T13422 13 Series Classic Monitor Tub/ Shower Trim In Chrome Logo
121 people viewed this question
Top Delta Faucet Home Experts
john h
bobalix
bcas6924
Are you a Delta Faucet Home Expert? Answer questions, earn points and help others
