Question about ViewSonic N3235w 32" LCD TV
My viewsonic keeps changing channels which makes it impossible to use. We've unplugged it and everything. once you power it on, thats all it does. it continueusly changes channels. please help
  • 59 Answers
The first thing to try is to see if a button is stuck on the remote or on the TV.
Remove the batteries on the remote and see if that helps. If it fixes the problem, you'll need to replace the remote.
If that doesn't help, look close at the buttons on the TV to see if one is jammed on. If changing channels continually up, then check the channel up button on the TV, if down then check the down button.
Worst case, you might have to take the back off the TV and unplug the cable feeding the external button panel on the TV and only use the Remote (for safety, rememeber to unplug the TV while doing any work on it).
Posted on Nov 28, 2013
  • Anonymous Oct 29, 2017
    Have the same problem. It is now 2017(LOL). Rubber buttons I see eventually will get stuck.It's a pain.
3 Suggested Answers
  • 139 Answers
SOURCE: How do I change the power supply for my Viewsonic N3760W TV?
YOU HAVE A VOLTAGE/CURRENT LIMITER PROBLEM THAT IS PROBABLY CAUSED BY A LEAKY CAPACITOR IN THE FEEDBACK CIRCUIT IN THE POWER SUPPLY. THIS CAN BE FIXED. I CAN GUIDE YOU IF YOU CAN SOLDER AND FIND THE PARTS- RADIO SHACK OR MABYE AN OLD TV AROUND?
Posted on Dec 27, 2009
Testimonial: "Awesome help."
HnstTrstMe
  • 12 Answers
Very carefully. I only would do it after you have verified the warranty is expired per Viewsonic. If it is OOW, then you can call them for a service manual that contains schematics, troubleshooting flowcharts, etc.
Posted on Aug 20, 2010
Power locked viewsonic n1930w
On the tv itself hold down CHANNEL button and hold the MENU button then press the POWER button, You will get into the service menu. from here I went in to the CARNIVAL menus and changed the PW setting then backed out... Power button worked. Then I went back in and played with everything else... but in the end left everything the way it was in the end. I suggest you do the same. Good luck.
Jun 10, 2012 | ViewSonic N1930W 19 in. LCD TV
Hello, I'm currently running dual monitors - my main being a samsung syncmaster 2433 and the other being a viewsonic vx2255wmb. I've recently switched the viewsonic over to DVI, it was fine then...
Have you tried changing the input on the monitor? I've seen many times where people go all through the troubleshooting steps on monitors but forget to check that. Look for a button on the monitor that says "Input" and/or go through the menu and find the input section and make sure to check all of them, just in case.
Sep 08, 2011 | ViewSonic Computers & Internet
I have a small magnavox HDTV. I unplugged it to watch it in another room. The next day when I moved it back into the living room I turned it on. Every time I try changing the channel it changes the source...
Is it a multi-function remote? If it is, make sure you've punched the TV button before using it. Also, make sure none of the buttons on the remote or the TV have accidentally been pushed down and are stuck.
Jul 05, 2011 | Philips Televison & Video
I have a view sonic N2230w and its lock it says menu lock and I cant get it unlock. What can I do?
Press the Channel + and Channel - buttons at the same time. You should see a message stating the menu is unlocking. Once it clears you can use your remote control to make any necessary changes to the TV.
May 12, 2011 | ViewSonic N2230w 22 in. LCD TV
My ViewSonic N2230w 22 in has a menu locked and it cant change to a different input and im trying to unlock it but i cant i need to get it to unlock
Nov 06, 2010 | ViewSonic N2230w 22 in. LCD TV
The menu button is locked on my view sonic tv how do i unlock it????
Depends on the model of TV. Some ViewSonics will unlock the menu if you Press the Channel + and Channel - buttons at the same time. You should see a message stating the menu is unlocking. Once it clears you can use your remote control to make any necessary changes to the TV.
Sep 25, 2010 | ViewSonic N2230w 22 in. LCD TV
My viewsonic N3751w LCD TV won't receive air signal. It has a built-in digital tunner so it should be able to receive several air signal without a need to have a digital to analog converter
Check that your antenna is sufficient for your location and oriented correctly. Try antennaweb.org for the most likely channels; tvfool.com has a much greater list of channels and the antennas needed to receive them. Both sites assume external antennas and warn that trees and buildings around your location may cause interference.
If you have a splitter connecting one antenna to several TVs, consider using an amplifier to ensure that the TV gets sufficient signal strength. Remember digital TV is has all-or-nothing reception issues.
If you previously could pick up the stations with this TV and suddenly lost them, try resetting your TV. Unplug the unit for at least 10 seconds. Also restore the factory default settings and then rescan for all channels. The reset is possibly Menu, Options, Restore Default or Menu, Setup, Memory Recall. (Viewsonic has changed its menus at intervals so look for something similar). Once you find it, click enter then left or right arrow to YES, hit enter again. Then hit menu twice to exit the OSD menu and then re-enter the menus before trying to rescan channels.
Also check that the TV is looking for OTA and not cable signals. Check that the tuner is still working by retrying the scan in a spot you know that the antenna captures a stations signal. Make sure your antenna cable hasn't been damaged by anything.
If you recently had a power surge (lightning strike) near the antenna or cable, you may be in need of a new tuner. (BTDT with an older TV)
I hope this helps.
Apr 24, 2010 | ViewSonic N3751W 37 in. LCD Television
How do I change the power supply for my Viewsonic 37'' Model # N3760W LCD TV. It keeps turning off when I change channels and adjust the volume. I cant order one from Viewsonic.
Dec 27, 2009 | ViewSonic NextVision N3760W 37 in. LCD...
Impossible to change channels, turn TV on, Power and Opc blinking
go into programming mode and search for channels   it will do this automatically to find all antennae and all cable channels    if this is hooked up to a receiver box then only channel 3 will be found or used    also most tvs are computerized these days and at times it will need to 'rebooted'     unplug the power and wait 10 seconds and plug it in again    this may have to be done whenever you are locked out from changing channels or using the volume controls
Nov 05, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV won't come on!
your system control section has failed due to sudden power failure. 1please check power to system cotrol. 2check tunning &aft ckt in system. 3check memory ic & its section 4check system ic & its section regards
Sep 12, 2007 | RCA F32650 32" TV
ViewSonic N3235w 32" LCD TV Logo
142 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
