Question about Empire Comfort Systems Empire Battery-Operated Remote with Thermostat Control - FRBTC
The LCD screen is not functioning...it is blank. What steps do I need to take to fix the problem?
The LCD screen will not display there for I am not able to use the thermostat functions/features. What can I do as it cost over $200 for a new one?
    Top Expert:
  • Empire Comfo... Master
  • 74,482 Answers
If it works functionally, but there is only no screen, the back light inverter board should be checked. To get more details, http://electronicshelponline.blogspot.com/
Posted on Nov 28, 2013
Htc blank screen
If the phone is powered on and there is no display(Blank screen) your LCD most likely is bad and needs to be replaced. I have worked on two phones that had blank displays and a new LCD did not fix the problem(main board problem) but this is extremely rare.
Jul 15, 2014 | HTC Cell Phones
This monitor gives me a complete blank white screen when plugged in even after checking with multiple computers what part would need fixing or replacing for it to function properly?
check first any broken ribbon wire going to lcd panel or broken screen display. if those are good, the cause of white screen would be bad lcd controller board.
Dec 28, 2012 | Computers & Internet
Code 68 appearing on LCD screen off a brivis LPG ducted heater
This is a error that can be fixed with a specific reset sequence. Follow this process carefully. The unit will not turn on for long and turns itself off after about a second so you need to execute step 2 immediately after step one.
Step 1 - Turn on heater
Step 2 immediately press no 1 on the keypad - this will display the error code H01 #68
Step 3 Hold down no 4 for approx 5 secs till the screen goes blank
Step 4 The screen displays all of the settings and resets
Note: you may need to do this a few times before it works - wait some time before retrying. If a reset will fix the problem this is the solution - if it is hardware a service call is required.
Jul 18, 2011 | Heating & Cooling
The touch screen display does not work. It turns on but you cannot give the unit a command through the input panel.
Is the lcd screen completely blank? Or does is it just the touch functionality that is not working?
If the screen is blank, though the copier still turns on and appears to function (test it by printing to it,) then you most likely have a failed power inverter board. This board provides the current needed to operate the lcd screen and is a rather common failure. However, if it is just the touch feature that is not working though the screen lights up, then you most likely have a ripped ribbon cable that connects the lcd touch function to the main board on the lcd screen.
Keep my updated.
David R.
Dec 11, 2010 | Xerox WorkCentre M-24 Color Copier
Screen gone blank, won't display nokia n96. the phone functions, but the screen remains black, and won't display anything.
There is one of the following problems with your phone.
  • LCD of your phone disconnected from the connector inside the casing.
  • LCD had been damaged and need to replace by a new LCD.
Nov 05, 2009 | Nokia N96 Smartphone
Blank screen
probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver IC thus you could only see white display. A replacement of LCD panel is the best solution. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 21, 2009 | ViewSonic OptiQuest Monitor
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Blank white display on Nokia 3230
This is a major fault, screen gets blank white because of some problem in its display panel which is right behind the LCD screen. Rush to the nearest Nokia care centre and explain the problem to them.After the repair if you experience this problem again and your phone is within the warranty period you can demand a brand new box piece!
Sep 03, 2007 | Nokia 3230
LCD Blank
the flex wire of the lcd monitor is already cut and already left is on the touch screen that why is functioning ...go the sony service for the replacing flex wire...or to the other service center for fixing the flex wire....
May 02, 2007 | Sony Handycam DCR-HC40E Mini DV Digital...
Empire Comfort Systems Empire Battery-Operated Remote with Thermostat Control - FRBTC Logo
159 people viewed this question
Top Empire Comfort Systems Televison & Video Experts
Electro Med Services...
Are you an Empire Comfort Systems Televison and Video Expert? Answer questions, earn points and help others
